查看: 1678|回復(fù): 0
二驅(qū)智能藍(lán)牙小車程序(顯示屏,溫度監(jiān)測(cè))
ID:360192 發(fā)表于 2018-6-27 13:21 來(lái)自觸屏版 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
智能藍(lán)牙小車程序:
#include <reg52.H>
#include <intrins.H>
#include <math.H>
//**************************端口定義函數(shù)***************************/
sbit RS = P0^5;
sbit rw=P0^6;
sbit EN = P0^7;
sbit a1=P0^0;
sbit a2=P0^1;
sbit a3=P0^2;
sbit a4=P0^3;
sbit ds=P3^7;
uchar a;//接收藍(lán)牙發(fā)送的數(shù)據(jù)
//**********************2驅(qū)小車前進(jìn)定義函數(shù)***********************/
void go()//前進(jìn)
{  a1=1;//左前
        a2=0;
        a3=1;//左后
        a4=0;
//**********************兩驅(qū)小車前進(jìn)定義函數(shù)***********************/
void back()//后退
{        a1=0;
        a2=1;
        a3=0;
        a4=1;
void right()//右轉(zhuǎn)
{        a1=0;//
        a2=1;
        a3=1;//
        a4=0;
void left()//左轉(zhuǎn)
{        a1=1;
        a2=0;
        a3=0;
        a4=1;
void stop()//停止
{        a1=0;
        a2=0;
        a3=0;
        a4=0;
void delayus()
{  _nop_();
void delayms(uint a)
{   uint ii, jj;
    for(ii=a; ii>0;ii--)
    for(jj=100;jj>0;jj--);
//*******************LCD1602液晶顯示函數(shù)部分**********************/
void writeComm(uchar comm)
{   RS = 0;
    P2 = comm;
    EN = 1;
    delayus();
    EN = 0;
    delayms(1);
//寫數(shù)據(jù):RS=1, RW=0;
void writeData(uchar dat)
{    RS = 1;
     P2 = dat;
     EN = 1;
    delayus();
    EN = 0;
    delayms(1);
void init()
{ rw=0;
   writeComm(0x38);
   writeComm(0x0c);
   writeComm(0x06);
   writeComm(0x01);
void writeString(uchar * str, uchar length)
     uchar tt;
    for(tt = 0; tt < length; tt++)
    {     writeData(str[tt]);
//**********************DS18B20函數(shù)部分************************/
void dsInit()
{   unsigned int tt;
    ds = 0;
    tt = 100;
     while(tt>0) tt--;
    ds = 1;
    tt= 4;
     while(tt>0) tt--;
void dsWait()
{         unsigned int ii;
      while(ds);
      while(~ds);
      ii = 4;
      while(ii> 0) ii--;
bit readBit()
{    unsigned int ii;
    bit b;
    ds = 0;
    ii++;
    ds = 1;
   ii++; ii++;
    b = ds;
    ii = 8;
    while(ii>0) ii--;
    return b;
unsigned char readByte()
{    unsigned int i;
    unsigned char j, dat;
   dat = 0;
    for(i=0; i<8; i++)
    {      j=readBit();
        dat=(j << 7)|(dat>>1);
    return dat;
void writeByte(unsigned char dat)
{  unsigned int ii;
    unsigned char jj;
    bit mm;
    for(jj = 0; jj < 8; jj++)
    {    mm = dat & 0x01;
        dat >>= 1;
            if(mm)
     {      ds = 0;          ii++; ii++;
            ds = 1;
            ii = 8; while(ii>0) ii--;
        {         ds = 0;
            ds = 1;
           ii++; ii++;
void sendChangeCmd()
{    dsInit();
    dsWait();
    delayms(1);
    writeByte(0xcc);
    writeByte(0x44);
void sendReadCmd()
{    dsInit();
    dsWait();
    delayms(1);
    writeByte(0xcc);
    writeByte(0xbe);
int getTmpValue()
{    unsigned int tmpvalue;
    int value;
    float t;
    unsigned char low, high;
    sendReadCmd();
    low = readByte();
    high = readByte();
    tmpvalue = high;
    tmpvalue <<= 8;
    tmpvalue |= low;
    value = tmpvalue;
        t = value * 0.0625;
          value = t * 100 + (value > 0 ? 0.5 : -0.5); //大于0加0.5, 小于0減0.5
    return value;
void display(int v)
    unsigned char count;
    unsigned char shuju[] = {0, 0, 0, 0, 0};
    unsigned int temp = abs(v);
    shuju[0] = temp / 10000;
    shuju[1] = temp % 10000 / 1000;
    shuju[2] = temp% 1000 / 100;
    shuju[3] = temp% 100 / 10;
    shuju[4] = temp% 10;
    writeComm(0x80+8);
    if(v < 0)
        writeString("- ", 2);
       writeString("+ ", 2);
    if(shuju[0] != 0)
        writeData('0'+shuju[0]);
    for(count = 1; count != 5; count++)
        writeData('0'+shuju[count]);
        if(count == 2)
            writeData('.');
//*********************DS18B20函數(shù)結(jié)束**************************/
        uchar table[] = "OK Temp:";
    sendChangeCmd();
    init();
   writeComm(0x80);
    writeString(table, 8);
        //串口通信初始化
          TMOD=0x20;//定時(shí)器1工作方式2,8位自動(dòng)重裝
    TH1=0xFd; //11.0592M晶振,9600波特率
    TL1=0xFd;
    SCON=0x50;//串口方式1
    PCON=0x00;//SMOD=0
    TR1=1;//開啟定時(shí)器1
          ES=1;//開串口中斷
    EA=1;//開總中斷
        delayms(1000); //溫度轉(zhuǎn)換時(shí)間需要在750ms以上
  //      writeComm(0xc0);
                        writeComm(0x80);
        display(getTmpValue());
        sendChangeCmd();
                if(a=='A') go();//前進(jìn)
                else if(a=='B') back();//后退
                else if(a=='C') left();//左轉(zhuǎn)
                else if(a=='D') right();//右轉(zhuǎn)
                else stop();//停止
void chuankou()interrupt 4//中斷函數(shù)
        RI=0;//清0
        a=SBUF;
