查看: 8230|回復: 6
單片機液晶12864顯示器接口仿真+源碼
理解單片機的液晶顯示器接口原理,掌握基本編程流程。
  1. //函數庫名稱:12864顯示函數
  2. #include<reg51.h>
  3. #include<absacc.h>
  4. #include<intrins.h>
  5. #define uchar unsigned char
  6. #define uint unsigned int
  7. #define PORT P0
  8. sbit CS1=P2^4;   //左半屏片選腳
  9. sbit CS2=P2^3;   //右半屏片選腳
  10. sbit RS=P2^2;    //H代表數據輸入,L代表指令碼輸入
  11. sbit RW=P2^1;    //H讀取,L寫入
  12. sbit E=P2^0;     //使能,由H到L完成使能
  13. sbit bflag=P0^7; //忙標志位
  14. uchar code Num[]={
  15. 0x00,0x20,0x60,0xE0,0xE0,0xE0,0xF0,0xFC,
  16. 0xFF,0xFC,0xF0,0xE0,0xE0,0xE0,0x60,0x20,
  17. 0x00,0x00,0x40,0x30,0x3D,0x1F,0x1F,0x0F,
  18. 0x07,0x0F,0x1F,0x1F,0x3D,0x30,0x40,0x00,         //星號
  19. 0x00,0xf8,0x08,0x08,0x08,0x08,0x08,0xff,
  20. 0x08,0x08,0x08,0x08,0x08,0xfc,0x08,0x00,
  21. 0x00,0x03,0x01,0x01,0x01,0x01,0x01,0xff,
  22. 0x01,0x01,0x01,0x01,0x01,0x03,0x00,0x00,         //中
  23. 0x00,0xf0,0x00,0x00,0x00,0x00,0x00,0xff,
  24. 0x00,0x00,0x00,0x00,0x00,0xf0,0x00,0x00,
  25. 0x00,0x7f,0x20,0x20,0x20,0x20,0x20,0x3f,
  26. 0x20,0x20,0x20,0x20,0x20,0x7f,0x00,0x00,               //山
  27. 0x20,0x20,0x20,0x20,0x20,0x20,0xa0,0x7f,
  28. 0xa0,0x20,0x20,0x20,0x20,0x30,0x20,0x00,
  29. 0x00,0x40,0x40,0x20,0x10,0x0c,0x03,0x00,
  30. 0x01,0x06,0x08,0x10,0x20,0x60,0x20,0x00,                   //大
  31. 0x40,0x30,0x11,0x96,0x90,0x90,0x91,0x96,
  32. 0x90,0x90,0x98,0x14,0x13,0x50,0x30,0x00,
  33. 0x04,0x04,0x04,0x04,0x04,0x44,0x84,0x7e,
  34. 0x06,0x05,0x04,0x04,0x04,0x06,0x04,0x00,         //學
  35. };
  36. //****驅動函數****
  37. void Left()//選左半屏
  38. {
  39. CS1=0;
  40. CS2=1;
  41. }
  42. void Right()//選右半屏
  43. {
  44. CS1=1;
  45. CS2=0;
  46. }
  47. void Busy_12864()//判忙函數
  48. {
  49.   do
  50.         {
  51.           E=0;
  52.           RS=0; //讀狀態
  53.           RW=1;
  54.           PORT=0xff;
  55.           E=1;
  56.           E=0;
  57.          }
  58.   while(bflag); //若bflag=1則代表系統忙
  59. }
  60. void Wreg(uchar c)//寫指令
  61. {
  62.         Busy_12864();
  63.         RS=0;
  64.         RW=0;
  65.         PORT=c;
  66.         E=1;  //E下降沿,液晶模塊從數據總線寫入指令
  67.         E=0;
  68. }
  69. void Wdata(uchar c)//寫數據
  70. {
  71.         Busy_12864();
  72.         RS=1;
  73.         RW=0;
  74.         PORT=c;
  75.         E=1;
  76.         E=0;
  77. }
  78. void Pagefirst(uchar c)//頁設置
  79. //LCD12864一共可以畫32個字,4行,每行8個字,左半屏4個,右半屏4個;
  80. //每個字占2頁,第0頁顯示上半字,第1頁顯示下半字,畫1個字是16X16個點;
  81. //8小行為一頁,DDRAM共64小行,即8頁,Page0-7,所以只能顯示4行漢字
  82. {
  83.         uchar i;
  84.         i=c;
  85.         c=i|0xb8;//實際頁數和b8(即10111000B)的或運算就是要送的代碼,邏輯加法
  86.         Busy_12864();
  87.         Wreg(c);
  88. }
  89. void Linefirst(uchar c)//列設置,Y=0-63,左右半屏各64列
  90. {
  91.         uchar i;
  92.         i=c;
  93.         c=i|0x40;//實際列數和40(即01000000B)的或運算就是要送的代碼
  94.         Busy_12864();
  95.         Wreg(c);
  96. }
  97. //****清屏函數****
  98. void Ready_12864()
  99. {
  100.    uint i,j;
  101.    Left();
  102.    Wreg(0x3f);//左屏開顯示;0x3e為關顯示的控制字
  103.    Right();
  104.    Wreg(0x3f);//右屏開顯示;0x3f為開顯示的控制字
  105.    Left();//清左屏
  106.    for(i=0;i<8;i++)
  107.    {
  108.                  Pagefirst(i);
  109.                  Linefirst(0x00);
  110.                  for(j=0;j<64;j++)
  111.                  {
  112.                   Wdata(0x00);
  113.                  }
  114.     }
  115.     Right();//清右屏
  116.     for(i=0;i<8;i++)
  117.     {
  118.                  Pagefirst(i);
  119.                  Linefirst(0x00);
  120.                  for(j=0;j<64;j++)
  121.                  {
  122.                   Wdata(0x00);
  123.                  }
  124.          }
  125. }
  126. //****16×6漢字顯示程序****
  127. void Display(uchar *s,uchar page,uchar line)
  128. {
  129. //先上半字,再下半字;由左向右逐列送值
  130.         uchar i,j;
  131.         Pagefirst(page);
  132.         Linefirst(line);
  133.         for(i=0;i<16;i++)
  134.          {
  135.            Wdata(*s);//指針S指向數組Num進行抽數
  136.            s++;
  137.          }
  138.         Pagefirst(page+1);
  139.         //換頁,顯示下半字,一個字需要2頁才可以完成顯示,即16小行
  140.         Linefirst(line);
  141.         for(j=0;j<16;j++)
  142.          {
  143.            Wdata(*s);
  144.                 s++;
  145.          }
  146. }
  147. main()//主程序
  148. {
  149.   //在第2行(3、4頁)顯示6個字;
  150.         Ready_12864();
  151.         Left();
  152.         Display(Num+0,0x03,16);    //第3頁第16列(左屏第1個字位置)
  153.         Display(Num+32,0x03,32);   //第3頁第32列(左屏第2個字位置)
  154.         Display(Num+64,0x03,48);   //第3頁第48列(左屏第3個字位置)
  155.         Right();
  156.         Display(Num+96,0x03,0);    //第3頁第0列(右屏第0個字位置)
  157.         Display(Num+128,0x03,16);  //第3頁第16列(右屏第1個字位置)
  158.         Display(Num+0,0x03,32);    //第3頁第32列(右屏第2個字位置)
  159.         while(1);
  160. }
LCD12864.zip (758.39 KB, 下載次數: 86)
ID:451217 發表于 2018-12-22 13:42 | 只看該作者
不錯不錯,學習了
ID:451441 發表于 2018-12-24 12:49 | 只看該作者
for(i=0;i<16;i++)
           s++;
你好,我在自學,我看到很多這種寫數組指針的用法,可我有個疑問,在哪里有將Num數組和*S指針聯系起來的語句呢?不然怎么知道*S是指向Num數組的呢?我見到很多這樣用法,但不理解,萬望解答,謝謝
ID:451718 發表于 2018-12-24 14:00 | 只看該作者
回復2樓。 請溫習 C語言關于 函數部分: 形參與實參的內容。
ID:451441 發表于 2018-12-24 15:09 | 只看該作者
本帖最后由 ttaniscy 于 2018-12-24 17:24 編輯
robinsonlin 發表于 2018-12-24 14:00
謝謝指點,我回去再看看那部分內容
ID:451441 發表于 2018-12-24 17:12 | 只看該作者
我還有抑或,指針什么時候指針變量S指向數組Num的呢?謝謝解答下
ID:451441 發表于 2018-12-24 17:25 | 只看該作者
謝謝指點迷津,我找書再看下,
