查看: 1933|回復: 0
基于stm32的呼吸燈源碼
ID:357771 發表于 2018-6-24 14:37 | 顯示全部樓層 |閱讀模式
基于32的呼吸燈源碼,包括一氧化碳檢測模塊等
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "key.h"
  4. #include "sys.h"
  5. #include "usart.h"
  6. #include "dht11.h"
  7. #include "timer.h"
  8. #include "lcd1602.h"
  9. #define Buf2_Max 200                                           //串口2緩存長度
  10. /*************        本地常量聲明        **************/
  11. /*************  本地變量聲明        **************/
  12. //char Uart1_Buf[Buf1_Max];
  13. char Uart2_Buf[Buf2_Max];
  14. u8 Times=0,First_Int = 0,shijian=0;
  15. vu8 Timer0_start;        //定時器0延時啟動計數器
  16. vu8 Uart2_Start;        //串口2開始接收數據
  17. vu8 Uart2_End;          //串口2接收數據結束
  18. u8 temperature = 0;
  19. u8 humidity = 0;
  20. u8 cowarn = 0;
  21. char string[100];
  22. /*************        本地函數聲明        **************/
  23.
  24. /*************  外部函數和變量聲明*****************/
  25. void main(void)
  26. {
  27.         u8 t=0;
  28.         u8 dir=1;
  29.   u16 led0pwmval=0;
  30.         delay_init();                     //延時函數初始化
  31.         NVIC_Configuration();          //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
  32.         LED_Init();                             //LED端口初始化
  33.         KEY_Init();
  34.         GPIO_Configuration();
  35.         LCD1602_Init();
  36. //         LCD1602_Show_Str(2, 1, "I love STM32");
  37.         LCD1602_ClearScreen();
  38.         while(DHT11_Init());        //DHT11初始化
  39.
  40.         TIM4_PWM_Init(100-1,720-1);         //不分頻。PWM頻率=72000000/900=80Khz
  41.
  42.
  43.         while(1)
  44.         {
  45.
  46.                         DHT11_Read_Data(&temperature,&humidity);                //讀取溫濕度值
  47.                         if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_1)==0)
  48.                         {
  49.                                 GPIO_ResetBits(GPIOB,GPIO_Pin_5);                                                 //PB.5 輸出高
  50.                                 TIM_SetCompare3(TIM4,99);
  51.                         }
  52.                         else
  53.       {
  54.                                 GPIO_SetBits(GPIOB,GPIO_Pin_5);                                                 //PB.5 輸出高
  55.                                 TIM_SetCompare3(TIM4,0);
  56.                         }
  57.                         //LCD1602_ClearScreen();
  58.
  59.                         memset(string, 0, sizeof(string));
  60.                         sprintf(string,"Temperature %d",temperature);
  61.                         LCD1602_Show_Str(0, 0,string);
  62.
  63.                         memset(string, 0, sizeof(string));
  64.                         sprintf(string,"Humidity    %d ",humidity);
  65.                         LCD1602_Show_Str(0, 1,string);
  66.
  67.
  68.                         if(dir)led0pwmval+=10;
  69.                         else led0pwmval-=10;
  70.                         if(led0pwmval>=99)
  71.                         {
  72.                                 dir=0;
  73.                                 TIM_SetCompare4(TIM4,99);
  74.                         }
  75.                         if(led0pwmval<=0)
  76.                         {
  77.                                 dir=1;
  78.                                 TIM_SetCompare4(TIM4,0);
  79.                         }
  80. //                        TIM_SetCompare1(TIM4,led0pwmval);
  81. //                        TIM_SetCompare2(TIM4,99-led0pwmval);
  82.                                 TIM_SetCompare1(TIM4,led0pwmval);
  83.                                 TIM_SetCompare2(TIM4,humidity);
  84.
  85.
  86.
  87.
  88.                         delay_ms(5);
  89.         }
  90. }
基于STM32F107的呼吸燈.rar (326.71 KB, 下載次數: 9)
