下載后可顯示仿真圖片,網上觀看可能不支持圖片
- #include"at89X52.h"
- sbit LCD_RS =P2^0;
- sbit LCD_RW =P2^1;
- sbit LCD_E =P2^2;
- sbit ADC_CS =P2^3;
- sbit ADC_WR =P3^6;
- sbit ADC_RD =P3^7;
- #define LCD_DATA P0
- unsigned char LcdBuf1[10]="";
- unsigned char code Bmp001[][8]=
- {0x06,0x09,0x09,0x06,0x00,0x00,0x00,0x00},
- {0x06,0x09,0x10,0x10,0x10,0x09,0x06,0x00}
- void dellay(unsigned int h)
- while(h--); //0.01MS
- void WriteDataLcd(unsigned char wdata)
- LCD_DATA=wdata;
- LCD_RS=1;
- LCD_RW=0;
- LCD_E=0;
- dellay(1000);
- LCD_E=1;
- void WriteCommandLcd(unsigned char wdata)
- LCD_DATA=wdata;
- LCD_RS=0;
- LCD_RW=0;
- LCD_E=0;
- dellay(1000);
- LCD_E=1;
- void lcd_init(void)
- LCD_DATA=0;
- WriteCommandLcd(0x38);
- dellay(1000);
- dellay(1000);
- WriteCommandLcd(0x01);
- WriteCommandLcd(0x0c);
- void display_xy(unsigned char x,unsigned char y)
- if(y==1)
- x+=0x40;
- x+=0x80;
- WriteCommandLcd(x);
- void display_string(unsigned char x,unsigned char y,unsigned char *s)
- display_xy(x,y);
- while(*s)
- WriteDataLcd(*s);
- s++;
- void Write_CGRAM(unsigned char add,unsigned char *char_num)
- unsigned i;
- add=add<<3;
- WriteCommandLcd(0x40|add+8);
- for(i=0;i<8;i++)
- WriteDataLcd(*char_num++);
- void delayms()
- int i;
- for(i=110;i>0;i--);
- void delay1s()
- int i,j;
- for(i=1000;i>0;i--);
- for(j=110;j>0;j--);
- void convert()
- unsigned long value;
- char i;
- unsigned long res;
- int temp,temp2;
- int w;
- P1=0xff;
- ADC_RD=0;
- for(i=0;i<10;i++);
- value=P1;
- res=(float)(2550000+110000*value/30)/(2550-11*value/30);
- temp=(float)(res*10000-10000000)/3851-545;
- temp2 = temp;
- if(temp >= 0)
- for(i=6;temp>0;i--)
- LcdBuf1[i]=temp%10+48;
- temp/=10;
- if(temp < 0 )
- w= -temp;
- for(i=6;w>0;i--)
- LcdBuf1[i]=w%10+48;
- w/=10;
- if(i>=0&&temp<0)
- if(temp > -10)
- LcdBuf1[i] = '0';
- i--;
- LcdBuf1[i] = '-';
- i--;
- /* if(i==5)
- LcdBuf1[5] = '0';
- i --;
- LcdBuf1[4] = '-';
- i--; */
- for(;i>=0;i--)
- LcdBuf1[i]=' ';
- for(i=0;i<5;i++)
- LcdBuf1[i]=LcdBuf1[i+1];
- if(LcdBuf1[4]==' ')LcdBuf1[4]='0';
- LcdBuf1[5]='.';
- LcdBuf1[7]=1;
- LcdBuf1[8]='C';
- WriteCommandLcd(0x84);
- display_string(3,0,LcdBuf1);
- ADC_RD=1;
- ADC_WR=0;
- for(i=0;i<10;i++)
- ADC_WR=1;
- delayms();
- main()
- unsigned char i;
- lcd_init();
- for(i=0;i<2;i++)
- Write_CGRAM(i,Bmp001[i]);
- ADC_CS=0;
- ADC_WR=0;
- ADC_WR=1;
- while(1)
- convert();
- delay1s();
pt100測溫程序.zip
2018-6-24 11:28 上傳
下載積分: 黑幣 -5
44.9 KB, 下載次數: 53, 下載積分: 黑幣 -5
