程序可參考
py源程序如下:
- import hufcode
- import statistic
- import six
- def decompress():
- print("please input youer filename")
- inputfilename=input()
- f = open(inputfilename,'rb')
- filedata1 = f.read()
- filedata=bytearray(filedata1)
- filesize = f.tell()
- #print(filedata)
- a1 = filedata[0]
- a2 = filedata[1]
- a3 = filedata[2]
- a4 = filedata[3]
- j = 0
- j = j|a1
- j = j<<8
- j = j|a2
- j = j<<8
- j = j|a3
- j = j<<8
- j = j|a4
- leaf_node_size = j
- char_freq = {}
- for i in range(leaf_node_size):
- c = filedata[4+i*5+0]
- a1 = filedata[4+i*5+1]
- a2 = filedata[4+i*5+2]
- a3 = filedata[4+i*5+3]
- a4 = filedata[4+i*5+4]
- j=0
- j = j|a1
- j = j<<8
- j = j|a2
- j = j<<8
- j = j|a3
- j = j<<8
- j = j|a4
- #print (c, j)
- char_freq[c] = j
- j=0
- list1=[]
- list_all=[]
- for x in char_freq.keys():
- list1.append((x,char_freq[x]))
- list1.sort()
- list_all=[item[0]for item in list1]
- #print(list1)
- #print(list_all)
- nodes = hufcode.createNodes([item[1] for item in list1]) #出現次數
- root = hufcode.createHuffmanTree(nodes) #葉子節點
- codes = hufcode.huffmanEncoding(nodes,root) #編碼
- #print(codes)
- code1=''
- for x in range(leaf_node_size*5+4,filesize):
- c = filedata[x]
- for i in range(8):
- if c&128:
- code1 = code1 +'1'
- else:
- code1 = code1 + '0'
- c = c<<1
- #print(code1)
- newcode=dict(zip(codes,list_all))
- print(newcode)
- #print(newcode.get('1000'))
- #print(bytes((int(newcode.get('1000')),)).decode("ascii"))
- i=0
- res=''
- while i < len(code1)-24:
- j = i+1
- while j < len(code1): #獲取某一字符的code
- if code1[i:j] in newcode.keys():
- break
- j += 1
- #print(code1[i:j])
- res =res + bytes((int(newcode.get(str(code1[i:j]))),)).decode('ascii')
- #print(res)
- i = j
- sub_code = code1[-16:-8]
- last_length = 0
- last_length = last_length<<1
- if sub_code[i] == '1':
- last_length = last_length|1
- code1=code1[-24:-16]+code1[-8:-8+last_length]
- i=0
- while i < len(code1):
- j = i+1
- break
- j += 1
- #print(res)
- i = j
- print(res)
- print("\ndo you want save it? 1/yes,2/no")
- ans=input()
- ans=int(ans)
- if ans==1:
- print('please input the filename')
- outfilename=input()
- out = open(outfilename,"w")
- out.write(res)
- out.close
- else:
- pass
霍夫曼.rar
(14.57 KB, 下載次數: 7)
2018-6-24 10:58 上傳
py程序,哈夫曼編碼 下載積分: 黑幣 -5
