查看: 5815|回復(fù): 1
基于proteus8的出租車計價器仿真+PCB+單片機源碼+原理圖
ID:357536 發(fā)表于 2018-6-24 00:49 | 顯示全部樓層 |閱讀模式
這是我們組話費12天做出來的,
出租車計價器仿真原理圖如下(proteus8仿真工程文件可到本帖附件中下載)
Altium Designer畫的出租車計價器原理圖和PCB圖如下:(51hei附件中可下載工程文件)
  1. #include<reg51.h>
  2. #include"lcd1602.h"
  3. #include"ds1302.h"
  4. unsigned char time_add[7];
  5. void LcdDisplay();
  6. void keyscan();
  7. uint n=0,s=0;
  8. uint j=0,k=0;
  9. uint t=0;
  10. uint tx=0,ty=0,tz=0;
  11. uint s18=0,n18=0,t18=0,tx18=0,ty18=0,tz18=0,j18=0,k18=0;
  12. uint l=0;
  13. uint lx=0,ly=0;
  14. uint count;
  15. sbit SW=P2^1;
  16. sbit LED=P2^0;
  17. sbit add_hour=P1^2;
  18. sbit add_min=P1^1;
  19. sbit add_sec=P1^0;
  20. void main()
  21. {
  22.         LcdInit();
  23.         Ds1302Init();
  24.         TMOD = 0x01;
  25.     TL0 = 0X60;
  26.     TH0 = 0XEA;
  27.     ET0 = 1;
  28.     count = 5400;
  29.         INT0 = 1;
  30.     IT0 = 1;
  31.     EX0 = 1;
  32.     EA = 1;
  33.         while(1)
  34.           {
  35.                 Ds1302ReadTime();
  36.                 LcdDisplay();
  37.                 keyscan();
  38.                 if(SW==0)
  39.                 {
  40.                         TR0 = 1;
  41.                         EX0=0;
  42.                         do
  43.                         {
  44.
  45.                                 lx=l/10;
  46.                                 ly=l%10;
  47.                                 Ds1302ReadTime();
  48.                                 LcdWriteCom(0x80+0X40);
  49.                                 LcdWriteData('T');
  50.                                 LcdWriteData(':');
  51.                                 LcdWriteData('0'+TIME[2]/16);
  52.                                 LcdWriteData('0'+(TIME[2]&0x0f));
  53.                                 LcdWriteData('-');
  54.                                 LcdWriteData('0'+TIME[1]/16);
  55.                                 LcdWriteData('0'+(TIME[1]&0x0f));
  56.                                 LcdWriteData('-');
  57.                                 LcdWriteData('0'+TIME[0]/16);
  58.                                 LcdWriteData('0'+(TIME[0]&0x0f));
  59.                                 LcdWriteCom (0x80);
  60.                                  LcdWriteData('D');
  61.                                  LcdWriteData(':');
  62.                                 LcdWriteData('1');
  63.                                  LcdWriteData('.');
  64.                                  LcdWriteData('0');
  65.                                  LcdWriteData(' ');
  66.                                  LcdWriteData('S');
  67.                                 LcdWriteData(':');
  68.                                  LcdWriteData('0'+j);
  69.                                  LcdWriteData('0'+k);
  70.                                 LcdWriteData(' ');
  71.                                 LcdWriteData('T');
  72.                                 LcdWriteData(':');
  73.                                 LcdWriteData(' ');
  74.                                 LcdWriteData('0'+lx);
  75.                                 LcdWriteData('0'+ly);
  76.
  77.
  78.                         }while(SW==0);
  79.
  80.                 }
  81.                 else
  82.                         {TR0=0;
  83.                          EX0=1;
  84.                         }
  85.            }
  86.         }
  87. void keyscan()
  88. {
  89.    Ds1302Write(0x8E,0x00);
  90.    if( add_sec==0)
  91.    {
  92.     time_add[0]=(TIME[0]>>4)*10+(TIME[0]&0x0F);
  93.
  94.     time_add[0]=(time_add[0]+1)%60 ;
  95.     TIME[0]=(time_add[0]/10<<4)|(time_add[0]%10);
  96.
  97.     Ds1302Write(WRITE_RTC_ADDR[0], TIME[0]);
  98.
  99.     }
  100.         if( add_min==0)
  101.   { time_add[1]=(TIME[1]>>4)*10+(TIME[1]&0x0F);
  102.
  103.     time_add[1]=(time_add[1]+1)%60 ;
  104.     TIME[1]=(time_add[1]/10<<4)|(time_add[1]%10);
  105.
  106.     Ds1302Write(WRITE_RTC_ADDR[1], TIME[1]);
  107.
  108.    }
  109. if( add_hour==0)
  110.   {
  111.     time_add[2]=(TIME[2]>>4)*10+(TIME[2]&0x0F);
  112.
  113.     time_add[2]=(time_add[2]+1)%24 ;
  114.     TIME[2]=(time_add[2]/10<<4)|(time_add[2]%10);
  115.
  116.     Ds1302Write(WRITE_RTC_ADDR[2], TIME[2]);
  117.
  118.    }
  119. }
  120. void LcdDisplay()
  121. {
  122.         LcdWriteCom(0x80+0X40);
  123.         LcdWriteData('T');
  124.         LcdWriteData(':');
  125.         LcdWriteData('0'+TIME[2]/16);
  126.         LcdWriteData('0'+(TIME[2]&0x0f));
  127.         LcdWriteData('-');
  128.         LcdWriteData('0'+TIME[1]/16);
  129.         LcdWriteData('0'+(TIME[1]&0x0f));
  130.         LcdWriteData('-');
  131.         LcdWriteData('0'+TIME[0]/16);
  132.         LcdWriteData('0'+(TIME[0]&0x0f));
  133.         LcdWriteData('W');
  134.         LcdWriteData(':');
  135.         LcdWriteData('0'+tz18);
  136.         LcdWriteData('0'+tx18);
  137.         LcdWriteData('.');
  138.         LcdWriteData('0'+ty18);
  139.
  140.     if(time_add[2]>=18&&time_add[2]<=24)
  141.         {
  142.                          t18=1.8*s18*10;
  143.                           tx18=t18/10;
  144.                          ty18=t18%10;
  145.                          tz18=t18/100;
  146.                          if(tx18>=10)
  147.                          {
  148.                                 tx18=t18%100/10;
  149.                          }
  150.                         LcdWriteCom(0x80);
  151.                         LcdWriteData('D');
  152.                         LcdWriteData(':');
  153.                         LcdWriteData('1');
  154.                         LcdWriteData('.');
  155.                         LcdWriteData('8');
  156.                         LcdWriteData(' ');
  157.                         LcdWriteData('S');
  158.                         LcdWriteData(':');
  159.                         LcdWriteData('0'+j18);
  160.                         LcdWriteData('0'+k18);
  161.                         LcdWriteData('T');
  162.                          LcdWriteData(':');
  163.                          LcdWriteData('0'+tz);
  164.                         LcdWriteData('0'+tx);
  165.                          LcdWriteData('.');
  166.                         LcdWriteData('0'+ty);
  167.
  168.         }
  169.         else
  170.         {
  171.
  172.                  t=1.2*s*10;
  173.                  tx=t/10;
  174.                  ty=t%10;
  175.                  tz=t/100;
  176.                  if(tx>=10)
  177.                  {
  178.                         tx=t%100/10;
  179.                  }
  180.
  181.                  LcdWriteCom(0x80);
  182.                  LcdWriteData('D');
  183.                  LcdWriteData(':');
  184.                  LcdWriteData('1');
  185.                  LcdWriteData('.');
  186.                  LcdWriteData('2');
  187.                  LcdWriteData(' ');
  188.                  LcdWriteData('S');
  189.                  LcdWriteData(':');
  190.                  LcdWriteData('0'+j);
  191.                  LcdWriteData('0'+k);
  192.                  LcdWriteData('T');
  193.                  LcdWriteData(':');
  194.                  LcdWriteData('0'+tz);
  195.                  LcdWriteData('0'+tx);
  196.                  LcdWriteData('.');
  197.                  LcdWriteData('0'+ty);
  198.
  199.         }
  200. }
  201. void INT0_ISR() interrupt 0
  202. {
  203. ……………………
  204. …………限于本文篇幅 余下代碼請從51黑下載附件…………
出租車計價器仿真.zip (2.63 MB, 下載次數(shù): 166)
ID:487766 發(fā)表于 2019-3-30 17:49 | 顯示全部樓層
謝謝樓主分享 感覺挺有用的
