只需一步,快速開(kāi)始
查看: 2249|回復(fù): 2
藍(lán)牙小車(chē)程序
ID:343378 發(fā)表于 2018-6-22 20:58 | 顯示全部樓層 |閱讀模式
#include "REGX52.H"
typedef unsigned int u16;
typedef unsigned char u8 ;
sbit IN1=P0^1;
sbit IN2=P0^2;
sbit IN3=P0^3;
sbit IN4=P0^4;
sbit ENA=P0^0;
sbit ENB=P0^5;
sbit LED1=P2^0;
sbit LED2=P2^1;
sbit LED3=P2^2;
sbit LED4=P2^3;
void UsartInit()
SCON=0X50;   //設(shè)置為工作方式1
TMOD=0X20;   //設(shè)置計(jì)數(shù)器工作方式2
PCON=0X80;   //波特率加倍
TH1=0XF9;    //計(jì)數(shù)器初始值設(shè)置,注意波特率是4800的
TL1=0XF9;
ES=1;      //打開(kāi)接收中斷
EA=1;      //打開(kāi)總中斷
TR1=1;     //打開(kāi)計(jì)數(shù)器
/*void delay (u16 i)
     i--;
  while(1);
void tingzhi ()
IN1=0;
IN2=0;
IN3=0;
IN4=0;
void qianjin()
IN1=1;
IN2=0;
IN3=1;
IN4=0;
void zuozhuan ()
IN1=1;
IN2=0;
IN3=0;
IN4=0;
// LED2=0;
void youzhuan()
IN1=0;
IN2=0;
IN3=1;
IN4=0;
// LED2=1;
void houtui()
IN1=0;
IN2=1;
IN3=0;
IN4=1;
//LED1=1;
void delay_nus(unsigned int i)
  i=i/10;
  while(--i);
void delay_nms(unsigned int n)
  n=n+1;
  while(--n)
  delay_nus(900);
void ControlCar(unsigned char ConType)
tingzhi();
switch(ConType)
case 01:
  qianjin();
  LED1=0;
break;
case 02:
ENA=1;
ENB=1;
zuozhuan();
LED2=0;
break;
case 03:
ENA=1;
ENB=1;
youzhuan();
LED3=0;
break;
case 04:
ENA=1;
ENB=1;
houtui();
LED4=0;
break;
case 05:
tingzhi();
break;
ENA=1;
ENB=1;
  delay_nms (10);
     UsartInit();
  delay_nms (10);
  while(1);
void Usart() interrupt 4
u8 receiveData;
u16 a;
   delay_nms(50);
receiveData=SBUF;//出去接收到的
ENA=1;
ENB=1;
// ControlCar(5);
delay_nms(50);
   RI=0;
   a=SBUF;
   a=SBUF%16;
  ControlCar(a);
  delay_nms(50);
SBUF=receiveData;//將接收到的數(shù)據(jù)放入到發(fā)送寄存器
while(!TI);    //等待發(fā)送數(shù)據(jù)完成
TI=0;       //清除發(fā)送完成標(biāo)志位
ID:372705 發(fā)表于 2018-8-1 11:30 | 顯示全部樓層
都弄好了,小車(chē)都不動(dòng)
ID:256009 發(fā)表于 2018-8-9 14:36 | 顯示全部樓層
謝謝分享
