查看: 4025|回復: 0
單片機電子表顯示(Protues仿真+匯編源碼)
ID:356590 發(fā)表于 2018-6-22 11:42 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
電子表動態(tài)顯示仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. HOUR DATA 30H
  2. MIN  DATA 31H
  3. SEC  DATA 32H
  4. cont data 33h
  5. CNTH equ  high(15536)
  6. CNTL equ  low(15536)
  7. NUM  equ  20
  8.         ORG 0
  9.         LJMP START
  10.         org 000bh
  11.         ljmp t0int
  12. START:         MOV HOUR,#23H
  13.         MOV MIN,#58H
  14.         MOV SEC,#56H
  15.         mov tmod,#01
  16.         mov ie,#82h
  17.         mov th0,#CNTH
  18.         mov tl0,#CNTL
  19.         mov cont,#num
  20.         setb tr0
  21. MAIN0:        LCALL DISP
  22.         SJMP MAIN0
  23. t0int:        push acc
  24.         clr tr0
  25.         mov a,#CNTL
  26.         add a,#7
  27.         mov tl0,a
  28.         mov a,#CNTH
  29.         addc a,#0
  30.         mov th0,a
  31.         setb tr0
  32.         djnz cont,quit
  33.         mov cont,#num
  34.         mov a,sec
  35.         add a,#1
  36.         da a
  37.         mov sec,a
  38.         cjne a,#60h,quit
  39.         mov sec,#0
  40.         mov a,min
  41.         add a,#1
  42.         da a
  43.         mov min,a
  44.         cjne a,#60h,quit
  45.         mov min,#0
  46.         mov a,hour
  47.         add a,#1
  48.         da a
  49.         mov hour,a
  50.         cjne a,#24h,quit
  51.         mov hour,#0
  52. quit:        pop acc
  53.         reti
  54. DISP:        MOV DPTR,#TAB
  55.         MOV R7,#3
  56.         MOV R1,#HOUR
  57.         MOV R4,#1H
  58.
  59. LOP0:        MOV A,@R1
  60.         ANL A,#0F0H
  61.         SWAP A
  62.         MOVC A,@A+DPTR
  63.         CPL A
  64.         MOV P1,A
  65.         MOV A,R4
  66.         MOV P3,A
  67.         LCALL DELAY
  68.         MOV P1,#0FFH
  69.         RL A
  70.         MOV P3,A
  71.         RL A
  72.         MOV R4,A
  73.         MOV A,@R1
  74.         ANL A,#0FH
  75.         MOVC A,@A+DPTR
  76.         orl a,#80h
  77.         CPL A
  78.         MOV P1,A
  79.         LCALL DELAY
  80.         MOV P1,#0FFH
  81.         INC R1
  82.         DJNZ R7,LOP0
  83.         RET
  84. DELAY:        MOV R5,#10H
  85.         MOV R6,#0
  86. DEL0:        DJNZ R6,$
  87.         DJNZ R5,DEL0
  88.         RET
  89. TAB:        DB 3FH,6,5BH,4FH,66H,6DH,7DH,7,7FH,6FH
  90. ;          0 1  2   3   4   5   6  7  8   9
  91.         END
2-電子表顯示.zip (40.5 KB, 下載次數(shù): 17)
