查看: 16559|回復: 31
STC90C52單片機+BMP180+LCD1602溫度氣壓高度計設計
ID:343102 發表于 2018-6-22 10:44 | 顯示全部樓層 |閱讀模式
經過多次努力,用STC90C52+BMP180+LCD1602做的溫度氣壓高度計終于調試成功,效果如圖所示,程序見附件。
制作出來的實物圖:
  1. #include  <REG52.H>
  2. #include  <math.h>    //Keil library
  3. #include  <stdlib.h>  //Keil library
  4. #include  <stdio.h>   //Keil library
  5. #include  <INTRINS.H> //Keil library
  6. #define   uchar unsigned char
  7. #define   uint unsigned int
  8. #define BMP085_SlaveAddress   0xee  //定義器件在IIC總線中的從地址
  9. #define OSS 0// Oversampling Setting (note: code is not set up to use other OSS values)
  10. #define   DataPort P0    //LCD1602數據端口
  11. sbit      LCM_RS=P2^4;   //LCD1602命令端口
  12. sbit      LCM_RW=P2^5;   //LCD1602命令端口
  13. sbit      LCM_EN=P2^6;   //LCD1602命令端口
  14. sbit  SCL=P1^0;      //IIC時鐘引腳定義
  15. sbit   SDA=P1^1;      //IIC數據引腳定義
  16. int  dis_data;                              //變量
  17. typedef unsigned char  BYTE;
  18. typedef unsigned short WORD;
  19. long  temperature;//溫度值
  20. long  pressure;//壓力值
  21. long  height;//相對海拔高度值
  22. short ac1;
  23. short ac2;
  24. short ac3;
  25. unsigned short ac4;
  26. unsigned short ac5;
  27. unsigned short ac6;
  28. short b1;
  29. short b2;
  30. short mb;
  31. short mc;
  32. short md;
  33. void delay(unsigned int k)
  34. {
  35. unsigned int i,j;
  36. for(i=0;i<k;i++)
  37. {
  38. for(j=0;j<121;j++)
  39. {;}}
  40. }
  41. /*******************************/
  42. void WaitForEnable(void)
  43. {
  44. DataPort=0xff;
  45. LCM_RS=0;LCM_RW=1;_nop_();
  46. LCM_EN=1;_nop_();_nop_();
  47. while(DataPort&0x80);
  48. LCM_EN=0;
  49. }
  50. /*******************************/
  51. void WriteCommandLCM(uchar CMD,uchar Attribc)
  52. {
  53. if(Attribc)WaitForEnable();
  54. LCM_RS=0;LCM_RW=0;_nop_();
  55. DataPort=CMD;_nop_();
  56. LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  57. }
  58. /*******************************/
  59. void WriteDataLCM(uchar dataW)
  60. {
  61. WaitForEnable();
  62. LCM_RS=1;LCM_RW=0;_nop_();
  63. DataPort=dataW;_nop_();
  64. LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  65. }
  66. /***********************************/
  67. void InitLcd()
  68. {
  69. WriteCommandLCM(0x38,1);
  70. WriteCommandLCM(0x08,1);
  71. WriteCommandLCM(0x01,1);
  72. WriteCommandLCM(0x06,1);
  73. WriteCommandLCM(0x0c,1);
  74. }
  75. /***********************************/
  76. void DisplayOneChar(uchar X,uchar Y,uchar DData)
  77. {
  78. Y&=1;
  79. X&=15;
  80. if(Y)X|=0x40;
  81. X|=0x80;
  82. WriteCommandLCM(X,0);
  83. WriteDataLCM(DData);
  84. }
  85. ///**************************************
  86. //延時5微秒(STC90C52RC@12M)
  87. //不同的工作環境,需要調整此函數,注意時鐘過快時需要修改
  88. //當改用1T的MCU時,請調整此延時函數
  89. //**************************************/
  90. //void Delay5us();
  91. void Delay5us()
  92. {
  93. _nop_();_nop_();_nop_();_nop_();
  94. _nop_();_nop_();_nop_();_nop_();
  95. _nop_();_nop_();_nop_();_nop_();
  96. _nop_();_nop_();_nop_();_nop_();
  97. }
  98. /**************************************
  99. 延時5毫秒(STC90C52RC@12M)
  100. 不同的工作環境,需要調整此函數
  101. 當改用1T的MCU時,請調整此延時函數
  102. **************************************/
  103. void Delay5ms()
  104. {
  105.     WORD n = 560;
  106.     while (n--);
  107. }
  108. /**************************************
  109. 起始信號
  110. **************************************/
  111. void BMP085_Start()
  112. {
  113.     SDA = 1;                    //拉高數據線
  114.     SCL = 1;                    //拉高時鐘線
  115.     Delay5us();                 //延時
  116.     SDA = 0;                    //產生下降沿
  117.     Delay5us();                 //延時
  118.     SCL = 0;                    //拉低時鐘線
  119. }
  120. /**************************************
  121. 停止信號
  122. **************************************/
  123. void BMP085_Stop()
  124. {
  125.     SDA = 0;                    //拉低數據線
  126.     SCL = 1;                    //拉高時鐘線
  127.     Delay5us();                 //延時
  128.     SDA = 1;                    //產生上升沿
  129.     Delay5us();                 //延時
  130. }
  131. /**************************************
  132. 發送應答信號
  133. 入口參數:ack (0:ACK 1:NAK)
  134. **************************************/
  135. void BMP085_SendACK(bit ack)
  136. {
  137.     SDA = ack;                  //寫應答信號
  138.     SCL = 1;                    //拉高時鐘線
  139.     Delay5us();                 //延時
  140.     SCL = 0;                    //拉低時鐘線
  141.     Delay5us();                 //延時
  142. }
  143. /**************************************
  144. 接收應答信號
  145. **************************************/
  146. bit BMP085_RecvACK()
  147. {
  148.     SCL = 1;                    //拉高時鐘線
  149.     Delay5us();                 //延時
  150.     CY = SDA;                   //讀應答信號
  151.     SCL = 0;                    //拉低時鐘線
  152.     Delay5us();                 //延時
  153.     return CY;
  154. }
  155. /**************************************
  156. 向IIC總線發送一個字節數據
  157. **************************************/
  158. void BMP085_SendByte(BYTE dat)
  159. {
  160.     BYTE i;
  161.     for (i=0; i<8; i++)         //8位計數器
  162.     {
  163.         dat <<= 1;              //移出數據的最高位
  164.         SDA = CY;               //送數據口
  165.         SCL = 1;                //拉高時鐘線
  166.         Delay5us();             //延時
  167.         SCL = 0;                //拉低時鐘線
  168.         Delay5us();             //延時
  169.     }
  170.     BMP085_RecvACK();
  171. }
  172. /**************************************
  173. 從IIC總線接收一個字節數據
  174. **************************************/
  175. BYTE BMP085_RecvByte()
  176. {
  177.     BYTE i;
  178.     BYTE dat = 0;
  179.     SDA = 1;                    //使能內部上拉,準備讀取數據,
  180.     for (i=0; i<8; i++)         //8位計數器
  181.     {
  182.         dat <<= 1;
  183.         SCL = 1;                //拉高時鐘線
  184.         Delay5us();             //延時
  185.         dat |= SDA;             //讀數據
  186.         SCL = 0;                //拉低時鐘線
  187.         Delay5us();             //延時
  188. }
  189.     return dat;
  190. }
  191. //*********************************************************
  192. //讀出BMP085內部數據,連續兩個
  193. //*********************************************************
  194. short Multiple_read(uchar ST_Address)
  195. {
  196.     uchar msb, lsb;
  197.     short _data;
  198.     BMP085_Start();                          //起始信號
  199.     BMP085_SendByte(BMP085_SlaveAddress);    //發送設備地址+寫信號
  200.     BMP085_SendByte(ST_Address);             //發送存儲單元地址
  201.     BMP085_Start();                          //起始信號
  202.     BMP085_SendByte(BMP085_SlaveAddress+1);         //發送設備地址+讀信號
  203.     msb = BMP085_RecvByte();                 //BUF[0]存儲
  204.     BMP085_SendACK(0);                       //回應ACK
  205.     lsb = BMP085_RecvByte();
  206.     BMP085_SendACK(1);                       //最后一個數據需要回NOACK
  207.     BMP085_Stop();                           //停止信號
  208.     Delay5ms();
  209.     _data = msb << 8;
  210.     _data |= lsb;
  211.     return _data;
  212. }
  213. //********************************************************************
  214. long bmp085ReadTemp(void)
  215. {
  216.     BMP085_Start();                  //起始信號
  217.     BMP085_SendByte(BMP085_SlaveAddress);   //發送設備地址+寫信號
  218.     BMP085_SendByte(0xF4);          // write register address
  219.     BMP085_SendByte(0x2E);       // write register data for temp
  220.     BMP085_Stop();                   //發送停止信號
  221.     delay(10);// max time is 4.5ms
  222.     return (long) Multiple_read(0xF6);
  223. }
  224. //*************************************************************
  225. long bmp085ReadPressure(void)
  226. {
  227.     long pressure = 0;
  228.     BMP085_Start();                   //起始信號
  229.     BMP085_SendByte(BMP085_SlaveAddress);   //發送設備地址+寫信號
  230.     BMP085_SendByte(0xF4);          // write register address
  231.     BMP085_SendByte(0x34);         // write register data for pressure
  232.     BMP085_Stop();                    //發送停止信號
  233.     delay(10);                      // max time is 4.5ms
  234.     pressure = Multiple_read(0xF6);
  235.     pressure &= 0x0000FFFF;
  236.     return pressure;
  237. }
  238. //**************************************************************
  239. //初始化BMP085,根據需要請參考pdf進行修改**************
  240. void Init_BMP085()
  241. {
  242.     ac1 = Multiple_read(0xAA);
  243.     ac2 = Multiple_read(0xAC);
  244.     ac3 = Multiple_read(0xAE);
  245.     ac4 = Multiple_read(0xB0);
  246.     ac5 = Multiple_read(0xB2);
  247.     ac6 = Multiple_read(0xB4);
  248.     b1 =  Multiple_read(0xB6);
  249.     b2 =  Multiple_read(0xB8);
  250.     mb =  Multiple_read(0xBA);
  251.     mc =  Multiple_read(0xBC);
  252.     md =  Multiple_read(0xBE);
  253. }
  254. //***********************************************************************
  255. void bmp085Convert()//換算
  256. {
  257.   unsigned int ut;
  258.   unsigned long up;
  259.   long x1, x2, b5, b6, x3, b3, p;
  260.   unsigned long b4, b7;
  261.   ut = bmp085ReadTemp();   // 讀取溫度
  262.   up = bmp085ReadPressure();  // 讀取壓強
  263.   x1 = (((long)ut - (long)ac6)*(long)ac5) >> 15;
  264.   x2 = ((long) mc << 11) / (x1 + md);
  265.   b5 = x1 + x2;
  266.   temperature = ((b5 + 8) >> 4);
  267.   b6 = b5 - 4000;
  268.   // Calculate B3
  269.   x1 = (b2 * (b6 * b6)>>12)>>11;
  270.   x2 = (ac2 * b6)>>11;
  271.   x3 = x1 + x2;
  272.   b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
  273.   // Calculate B4
  274.   x1 = (ac3 * b6)>>13;
  275.   x2 = (b1 * ((b6 * b6)>>12))>>16;
  276.   x3 = ((x1 + x2) + 2)>>2;
  277.   b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
  278.   b7 = ((unsigned long)(up - b3) * (50000>>OSS));
  279.   if (b7 < 0x80000000)
  280.     p = (b7<<1)/b4;
  281.   else
  282.     p = (b7/b4)<<1;
  283.   x1 = (p>>8) * (p>>8);
  284.   x1 = (x1 * 3038)>>16;
  285.   x2 = (-7357 * p)>>16;
  286.   pressure = p+((x1 + x2 + 3791)>>4);
  287.   height=(101325-pressure)*843/100;
  288.   DisplayOneChar(0,0,'T');//溫度部分
  289.   DisplayOneChar(1,0,':');
  290.   DisplayOneChar(4,0,'.');
  291. ……………………
  292. …………限于本文篇幅 余下代碼請從51黑下載附件…………
STC90C52+BMP180+LCD1602溫度氣壓高度計單片機程序.rar (42.17 KB, 下載次數: 397)
參與人數 1黑幣 +77 收起 理由
admin + 77 共享資料的黑幣獎勵!
ID:343102 發表于 2018-6-22 22:08 | 顯示全部樓層
制作感想:
  初衷是想給愛車空氣濾加個氣壓開關,防止空氣濾堵了還不知道,造成發動機進氣不良燃燒不全產生積碳。
  在某寶上一搜,一個氣壓開關居然要40元。而一個BMP180氣壓傳感器不到4元,一個STC90C51芯片也不到4元,一個最小系統板甚至不到2元。又看了LCD1602液晶顯示模塊,價格不到5元,也不貴。USB轉串口下載模塊,我已經有了啊。于是心動,敗了約20元,開始玩起了單片機。
  以前從未接觸過單片機,不過沒關系,自己有電路基礎,再上網找些資料學習學習就行了。網上一搜,找到了51黑論壇,發現是學習單片機的好地方。經過多天的學習、摸索,終于制作成功。
  這個單片機氣壓計不僅能顯示氣壓,還能顯示溫度和相對海拔高度,而且是數字顯示,非常直觀。不僅可以監測空氣濾內的氣壓,還可以帶著去釣魚、爬山。
  第一次DIY單片機就獲得了成功,成就感真是滿滿的。
  第一次DIY單片機就能獲得成功,其實也是與時代發展、科技進步分不開的。現在的單片機技術真是比N多年前強太多了。單片機各部分都已實現模塊化、標準化,組裝一個單片機就像搭積木一樣簡單。軟件技術也比以前進步很多,程序輸入也非常簡單,一個給機頂盒升級用的USB轉串口模塊就能搞定。現在的傳感器也比以前豐富多了,這使單片機的應用領域也更加廣泛了。現在學習單片機,既簡單,又實用。而且配件很容易買到,還幾乎都是白菜價,真是今非昔比。
ID:380510 發表于 2018-7-29 17:39 | 顯示全部樓層
牛逼啊 大兄弟
ID:371423 發表于 2018-8-20 10:46 | 顯示全部樓層
非常感謝,真是幫了大忙了!
ID:387208 發表于 2018-8-21 21:14 | 顯示全部樓層
電路圖呢。。。。。
ID:119159 發表于 2018-8-22 11:09 | 顯示全部樓層
贊一個,有電路圖嗎?
ID:119159 發表于 2019-1-1 21:08 | 顯示全部樓層
弱弱的問一句        pressure &= 0x0000FFFF;什么作用,讀溫度的時候為什么沒有??感激不盡!!
ID:459590 發表于 2019-1-1 21:49 | 顯示全部樓層
謝謝分享!
ID:343102 發表于 2019-2-24 13:08 | 顯示全部樓層
氣壓計電路圖
ID:461137 發表于 2019-3-14 17:58 | 顯示全部樓層
BMP180的VCC不能直接接單片機的VCC嗎?要接限流電阻嗎?幾歐的
ID:461137 發表于 2019-3-17 00:17 | 顯示全部樓層
溫度和氣壓正常顯示,可高度顯示為亂碼
ID:496214 發表于 2019-3-28 10:09 | 顯示全部樓層
謝謝樓主的分享 感激不盡!!!
ID:490818 發表于 2019-3-29 15:40 | 顯示全部樓層
感謝分享
ID:507691 發表于 2019-4-26 16:24 | 顯示全部樓層
我的壓強,高度在一直變化,有什么辦法解決嗎
ID:526706 發表于 2019-5-3 22:55 | 顯示全部樓層
多謝L樓主
ID:264360 發表于 2019-5-10 10:46 | 顯示全部樓層
風158 發表于 2018-6-22 22:08
制作感想:
  初衷是想給愛車空氣濾加個氣壓開關,防止空氣濾堵了還不知道,造成發動機進氣不良燃燒不全 ...
好用心的網友  受教了  向你學習
ID:650310 發表于 2019-11-26 21:10 | 顯示全部樓層
感謝分享,謝謝
ID:647448 發表于 2019-11-27 08:43 來自觸屏版 | 顯示全部樓層
厲害了我的哥
ID:658240 發表于 2019-12-11 16:59 | 顯示全部樓層
lml0508 發表于 2019-3-14 17:58
要接限流電阻嗎,我接5V的顯示小方塊是為什么原因呢,求解答
ID:343102 發表于 2019-12-16 18:11 | 顯示全部樓層
SoleMemoery 發表于 2019-12-11 16:59
BMP180的供電電壓一般為1.8-3.6V,不能接5V。可用1K電阻和蘭發光LED組成一個穩壓電路為BMP180供電。
ID:408809 發表于 2020-1-8 18:22 | 顯示全部樓層
不知道這個的定位精度和GPS的哪個好點?
ID:688258 發表于 2020-1-27 22:07 | 顯示全部樓層
為什么proteus仿真不了
ID:343102 發表于 2020-2-15 11:50 | 顯示全部樓層
proteus仿真是需要有庫函數的
ID:732057 發表于 2020-4-19 14:55 | 顯示全部樓層
用52芯片可以仿真嗎
ID:541277 發表于 2020-11-8 17:02 | 顯示全部樓層
樓主,按照你畫的圖焊的板子,供上電之后1602就亮一排小格子。
ID:382145 發表于 2021-4-1 19:32 | 顯示全部樓層
  題主,為啥氣壓海拔轉換公式是這個呀height=(101325-pressure)*843/100;文檔里都是一個挺復雜的式子,要開根號,我編譯老是錯誤
ID:343102 發表于 2022-4-26 07:22 | 顯示全部樓層
hjcc 發表于 2020-11-8 17:02
這是個簡化調光電路,不能適應較大溫差。可按1602手冊用電位器調光。
ID:343102 發表于 2022-4-26 07:26 | 顯示全部樓層
境s。 發表于 2021-4-1 19:32
題主,為啥氣壓海拔轉換公式是這個呀height=(101325-pressure)*843/100;文檔里都是一個挺復雜的式子,要 ...
這是常見高度(1萬米以下)的模擬函數,避免了浮點運算。單片機不支持浮點運算,容易出錯。
ID:134227 發表于 2022-6-29 09:50 | 顯示全部樓層
還不是很明白啊。。。
ID:85508 發表于 2022-12-8 19:28 | 顯示全部樓層
感謝分享!電路、程序都有。
ID:71233 發表于 2023-12-12 07:58 | 顯示全部樓層
樓主的BMP180可以用嗎?我從某一個寶上買的幾個都不好用。
ID:343102 發表于 2023-12-15 21:08 | 顯示全部樓層
lmn2005 發表于 2023-12-12 07:58
買了幾次,除了一致性有些微小差別,都能用。
注意電壓,BMP180的供電電壓為1.8-3.6V,不能接5V。
