查看: 3392|回復: 0
C51單片機溫濕傳感器DHT11顯示屏LCD1602顯示
ID:350078 發(fā)表于 2018-6-21 14:42 | 顯示全部樓層 |閱讀模式
#include"lcd.h"
void Read_Busy()           //忙檢測函數(shù),判斷bit7是0,允許執(zhí)行;1禁止
    unsigned char sta;      //
    LCD1602_DB = 0xff;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;    //使能,用完就拉低,釋放總線
    }while(sta & 0x80);
void Lcd1602_Write_Cmd(unsigned char cmd)     //寫命令
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
    LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat)   //寫數(shù)據(jù)
      Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
      LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y)  //坐標顯示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd1602_Write_Cmd(addr|0x80);
//*************************顯示字符
void DisplayOneChar (uchar X,uchar Y,uchar DData)
if(Y) X|=0X40;   //Y=1顯示第二行,Y=0顯示第一行
X|=0X80;
Lcd1602_Write_Cmd(X); //X用來選擇哪一位
Lcd1602_Write_Data(DData); //DData用來寫數(shù)據(jù)
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str)     //顯示字符串
    LcdSetCursor(x,y);      //當前字符的坐標
    while(*str != '\0')
        Lcd1602_Write_Data(*str++);
void InitLcd1602()              //1602初始化
    Lcd1602_Write_Cmd(0x38);    //打開,5*8,8位數(shù)據(jù)
    Lcd1602_Write_Cmd(0x0c);
    Lcd1602_Write_Cmd(0x06);
    Lcd1602_Write_Cmd(0x01);    //清屏
詳見:http://www.raoushi.com/bbs/dpj-87250-1.html
