單片機實現(xiàn)簡易波形發(fā)生器
2018-7-1 01:35 上傳
- #include<reg51.h>
- #include<absacc.h>
- #define DAC0832 XBYTE[0xfeff]
- #define uchar unsigned char
- uchar num = 0;
- uchar tl = 0xe0;
- uchar th = 0xff;
- uchar interrupt_flagl = 0x00;
- uchar code sin[256] = { 0x7f,0x82,0x85,0x88,0x8b,0x8f,0x92,0x95,0x98,0x9b,0x9e,0xa1,0xa4,0xa7,0xaa,
- 0xad,0xb0,0xb3,0xb6,0xb8,0xbb,0xbe,0xc1,0xc3,0xc6,0xc8,0xcb,0xcd,0xd0,
- 0xd2,0xd5,0xd7,0xd9,0xdb,0xdd,0xe0,0xe2,0xe4,0xe5,0xe7,0xe9,0xeb,0xec,
- 0xee,0xef,0xf1,0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfb,0xfc,0xfd,0xfd,
- 0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfd,0xfd,0xfc,0xfb,0xfb,
- 0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,0xee,0xec,0xeb,0xe9,0xe7,
- 0xe5,0xe4,0xe2,0xe0,0xdd,0xdb,0xd9,0xd7,0xd5,0xd2,0xd0,0xcd,0xcb,0xc8,0xc6,0xc3,
- 0xc1,0xbe,0xbb,0xb8,0xb6,0xb3,0xb0,0xad,0xaa,0xa7,0xa4,0xa1,0x9e,0x9b,0x98,0x95,
- 0x92,0x8f,0x8b,0x88,0x85,0x82,0x7f,0x7c,0x79,0x76,0x73,0x6f,0x6c,0x69,0x66,0x63,
- 0x60,0x5d,0x5a,0x57,0x54,0x51,0x4e,0x4b,0x48,0x46,0x43,0x40,0x3d,0x3b,0x38,0x36,
- 0x33,0x31,0x2e,0x2c,0x29,0x27,0x25,0x23,0x21,0x1e,0x1c,0x1a,0x19,0x17,0x15,0x13,
- 0x12,0x10,0x0f,0x0d,0x0c,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x03,0x02,0x01,0x01,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x05,
- 0x06,0x07,0x08,0x09,0x0a,0x0c,0x0d,0x0f,0x10,0x12,0x13,0x15,0x17,0x19,0x1a,0x1c,
- 0x1e,0x21,0x23,0x25,0x27,0x29,0x2c,0x2e,0x31,0x33,0x36,0x38,0x3b,0x3d,0x40,0x43,0x46,
- 0x48,0x4b,0x4e,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x73,0x76,
- 0x79,0x7c
- void case1(void)
- tl -= 0x05;
- if(tl <= 0xb0)
- tl = 0xe0;
- void case2(void)
- tl += 0x05;
- if(tl >= 0xff)
- tl = 0xe0;
- void case3(void)
- interrupt_flagl= interrupt_flagl + 0x01;
- if(interrupt_flagl > 0x04)
- interrupt_flagl = 0x01;
- int0_key() interrupt 0
- if(P2 == 0xdf)
- case1();
- else if(P2 == 0xbf)
- case2();
- else if(P2 == 0x7f)
- case3();
- timer0_int(void) interrupt 1
- TR0 = 0;
- if(interrupt_flagl == 0x01)
- if(num < 64)
- DAC0832 = 0x00;
- else if((num >= 64) && (num <= 128))
- DAC0832 = 0x85;
- else if((num > 128) &&(num <= 255))
- DAC0832 = 0;
- else if(num >255)
- num =0;
- else if(interrupt_flagl == 0x02)
- if( num <= 85)
- DAC0832 = num;
- else if(num > 85 && num < 170)
- DAC0832 = 85;
- else if((num >= 170) &&(num < 255 ))
- DAC0832 = 255 - num;
- else if(num >= 255)
- num = 0;
- else if(interrupt_flagl == 0x03)
- if( num <= 0x128)
- DAC0832 = num;
- else if((num >= 0x128) && (num < 0x255))
- num = 0;
- else if(interrupt_flagl == 0x04)
- DAC0832 = sin[num];
- if(num > 255)
- num = 0;
- num++;
- TR0 =1;
- TH0 = th;
- TL0 = tl;
- void main()
- TMOD = 0x01;
- TH0 = 0xff;
- TL0 = 0xe0;
- ET0= 1;
- TR0 = 1;
- TF0= 1;
- PX0 =1;
- EX0 =1;
- EA =1;
- while(1)
簡易波形發(fā)生器.rar
(24.19 KB, 下載次數(shù): 32)
2018-6-20 19:16 上傳
下載積分: 黑幣 -5
