2018-6-15 01:48 上傳
PedestrianDetection-master
1.數據集的預處理\
2.分類器的訓練\
3.檢測算法的測試\
4.Kalman跟蹤\
README.md
全部資料51hei下載地址:
PedestrianDetection-master.zip
(76.17 KB, 下載次數: 40)
2018-6-14 21:28 上傳
行人檢測demo 下載積分: 黑幣 -5
源碼預覽如下:
- #include <opencv2/core/core.hpp>
- #include <opencv2/objdetect/objdetect.hpp>
- #include <opencv2/highgui/highgui.hpp>
- #include <opencv2/video/tracking.hpp>
- #include <opencv2/video/video.hpp>
- #include <stdio.h>
- #include <iostream>
- #include <fstream>
- #include <vector>
- #include <algorithm>
- using namespace std;
- using namespace cv;
- //常量定義
- char IMG_PATH_TEXT[]="E:/INRIAPerson/color/img_path.txt"; //圖像路徑
- //char IMG_PATH_TEXT[]="E:/研究生課件/機器視覺/Project/Data/pictures"; //圖像路徑
- //const int START_FRAME=243; //開始跟蹤的幀243 || 413
- //const int END_FRAME=290; //結束跟蹤的幀290 || 480
- const int WINHEIGHT=180; //圖像高度
- const int WINWIDTH=320; //圖像寬度
- const int ROIWIDTH=160; //ROI高度
- const int ROIHEIGHT=160; //ROI寬度
- const Scalar green(0,255,0);
- const Scalar red(0,0,255);
- const Scalar blue(255,0,0);
- const string DETECT_WINNAME="Detect Window";
- const string TRACKER_WINNAME="Track Window";
- Mat img(WINHEIGHT,WINWIDTH,CV_8UC3); //the Mat storage the image
- Mat blackboard(WINHEIGHT,WINWIDTH,CV_8UC3);
- const cv::Rect WHOLEIMG(0,0,WINWIDTH-2,WINHEIGHT-2);
- const int STATE_NUM=4;
- const int MEASURE_NUM=2;
- //使用HOG在img圖像中檢測行人位置
- //返回的矩陣vector為矩陣位置
- //返回檢測時間
- void DetectPedestrian(vector<cv::Rect>& found_filtered,const HOGDescriptor& hog,
- double* time=NULL)
- found_filtered.clear ();
- vector<cv::Rect> found;
- //hog detector get the cv::Rect with pedestrian
- if(time!=NULL)
- *time=(double)getTickCount();
- hog.detectMultiScale(img, found, 0, Size(8,8), Size(32,32), 1.05, 2);
- if(time!=NULL)
- *time=(double)getTickCount()-*time;
- *time /= getTickFrequency();
- //if the cv::Rect overlap
- size_t i, j;
- for( i = 0; i < found.size(); i++ )
- cv::Rect r = found[i];
- for( j = 0; j < found.size(); j++ )
- if( j != i && (r & found[j]) == r)
- break;
- if( j == found.size() )
- found_filtered.push_back(r);
- for( i = 0; i < found_filtered.size(); i++ )
- cv::Rect r = found_filtered[i];
- // the HOG detector returns slightly larger rectangles than the real objects.
- // so we slightly shrink the rectangles to get a nicer output.
- r.x += cvRound(r.width*0.1);
- r.width = cvRound(r.width*0.8);
- r.y += cvRound(r.height*0.07);
- r.height = cvRound(r.height*0.8);
- //found_filtered[i]=r;
- cv::rectangle (img,r,green,3);
- std::cout<<" Time : "<<*time<<std::endl;
- //重載函數,在img的一個子區域中檢測行人位置
- //該子區域由一個矩形確定
- //返回檢測時間
- const cv::Rect& roi,double* time=NULL)
- //CV_Assert(WHOLEIMG.contains(roi.br()) && WHOLEIMG.contains(roi.tl()));
- if(time!=NULL)
- hog.detectMultiScale(img(roi), found, 0, Size(8,8), Size(32,32), 1.05, 2);
- if(time!=NULL)
- Point pt=roi.tl();
- size_t i, j;
- found[i]+=pt;
- break;
- void InitialKalmanFilter(KalmanFilter& kf,double x,double y,
- double delta_x,double delta_y)
- kf.transitionMatrix=(Mat_<float>(STATE_NUM, STATE_NUM) <<
- 1,0,1,0,
- 0,1,0,1,
- 0,0,1,0,
- 0,0,0,1 );
- kf.statePost=(Mat_<float>(STATE_NUM,1)<<
- x,
- y,
- delta_x,
- delta_y );
- kf.statePre=(Mat_<float>(STATE_NUM,1)<<
- x,
- y,
- delta_x,
- delta_y );
- //setIdentity: 縮放的單位對角矩陣;
- // !< measurement matrix (H) 觀測模型
- setIdentity(kf.measurementMatrix);
- // !< process noise covariance matrix (Q)
- // wk 是過程噪聲,并假定其符合均值為零,協方差矩陣為Qk(Q)的多元正態分布;
- setIdentity(kf.processNoiseCov,Scalar::all(25));
- // !< measurement noise covariance matrix (R)
- //vk 是觀測噪聲,其均值為零,協方差矩陣為Rk,且服從正態分布;
- setIdentity(kf.measurementNoiseCov,Scalar::all(25));
- // !< priori error estimate covariance matrix (P'(k)): P'(k)=A*P(k-1)*At + Q)
- // A代表F: transitionMatrix
- //預測估計協方差矩陣;
- setIdentity(kf.errorCovPost,Scalar::all(25));
- //獲得矩形的質心坐標
- Point2f GetCentroid(const cv::Rect& r)
- Point tl=r.tl();
- Point br=r.br();
- return Point2f((float)((tl.x+br.x)/2.0),(float)((tl.y+br.y)/2.0));
- string DescripRect(const cv::Rect r)
- char buf[128];
- sprintf(buf,"This rectangle width: %d , height %d , tl: (%d,%d) ,br: (%d,%d)",
- r.width,r.height,r.tl ().x,r.tl ().y,r.br ().x,r.br ().y);
- return string(buf);
- cv::Rect GetROI(const Point2f& centroid)
- Point tl((int)(centroid.x-ROIWIDTH/2),(int)(centroid.y-ROIHEIGHT/2));
- return (cv::Rect(tl.x,tl.y,ROIWIDTH,ROIHEIGHT) & WHOLEIMG);
- int main()
- double time;
- ofstream fout("data_recorder.txt");
- int count=0; //frame count
- string img_path; // img path
- ifstream fin(IMG_PATH_TEXT); //the text storage the image path
- vector<cv::Rect> pedestrian_location;
- HOGDescriptor hog; //HoG detector
- hog.setSVMDetector(HOGDescriptor::getDefaultPeopleDetector());
- cv::Rect preFrame;
- cv::Rect curFrame;
- int count_tmp=-1;
- bool start_track=false; //是否開始跟蹤?
- int loss_frame=0;
- KalmanFilter kf(STATE_NUM,MEASURE_NUM);
- vector<Point2f> pedestrian_centroid; //存儲質心變化
- vector<Point2f> pedestrian_centroid_pre; //預測的質心變化
- vector<Point2f> state_post;
- //while(getline (fin,img_path) && count<=END_FRAME)
- const string video_name = "E:/研究生課件/機器視覺/Project/Data/VID_20141228_151213.mp4";
- VideoCapture video(video_name);
- Mat frame;
- VideoWriter videowriter;
- videowriter.open("Test_LX.avi",CV_FOURCC('M','J','P','G'),
- 10,Size(WINWIDTH,WINHEIGHT),true);
- VideoWriter boardwriter;
- boardwriter.open("Test_LX_board.avi",CV_FOURCC('M','J','P','G'),
- while(1)
- //BEGIN !
- //Read the image from disk
- //img=imread (img_path,1);
- video >> frame;
- if(frame.empty ())
- break;
- cv::resize (frame, img, Size(WINWIDTH,WINHEIGHT));
- blackboard.setTo (0);
- //繪制行人質心
- for (size_t k=0;k<pedestrian_centroid.size ();k++)
- cv::circle(blackboard ,pedestrian_centroid[k],3,green);
- if(k!=0)
- cv::line(blackboard ,pedestrian_centroid[k],pedestrian_centroid[k-1],
- green,2);
- for (size_t k=0;k<pedestrian_centroid_pre.size ();k++)
- cv::circle(blackboard ,pedestrian_centroid_pre[k],3,red);
- if(k!=0)
- cv::line(blackboard ,pedestrian_centroid_pre[k],
- pedestrian_centroid_pre[k-1],red,2);
- for (size_t k=0;k<state_post.size ();k++)
- cv::circle(blackboard ,state_post[k],4,blue,-1);
- if(k!=0)
- cv::line(blackboard ,state_post[k],state_post[k-1],blue,2);
- char buf[128];
- sprintf(buf,"frame: %3d",count);
- putText (blackboard ,string(buf),cv::Point(10,20),
- FONT_HERSHEY_SIMPLEX,0.2,Scalar::all(255));
- putText (blackboard ,"Red Rectangle: ROI from Kalman",cv::Point(10,40),
- putText(blackboard , "Red Circle: Centroid from Kalman",cv::Point(10,60),
- putText(blackboard , "Green Rectangle: Pedestrian Rect from HOG",
- cv::Point(10,80),
- putText(blackboard , "Green Circle: Centroid from HoG",cv::Point(10,100),
- putText(blackboard , "Blue Circle: posteriori state estimate",cv::Point(10,120),
- if (!start_track && (count_tmp==-1)) //沒有開始跟蹤
- // HoG detection
- //這里時候存在行人呢??
- //如果沒有行人,就接著讀下一幀吧,直到找到
- //如果有行人,就目標建立卡爾曼濾波器
- DetectPedestrian(pedestrian_location,hog,&time);
- if (pedestrian_location.size ()==0) //在該幀沒有找到行人
- cv::imshow (DETECT_WINNAME,img);
- waitKey(2);
- printf("Frame %d cannot find pedestrian! \n",count);
- count++;
- continue;
- else //在這幀找到了行人
- preFrame=pedestrian_location[0];
- //如果有多個矩形框的話,先進行取交集運算
- for (size_t j=1;j<pedestrian_location.size ();j++)
- if (preFrame.area ()<pedestrian_location[j].area ())
- preFrame=pedestrian_location[j];
- //preFrame |= pedestrian_location[j];
- count_tmp = count; ///tmp 賦值
- printf("Frame %d find pedestrian! \n",count);
- else //開始了跟蹤
- if (count==(count_tmp+1)) //利用相鄰兩幀數據建立卡爾曼濾波器
- cv::Rect roi(WINWIDTH/2,WINHEIGHT/2,WINWIDTH/2,WINHEIGHT/2);
- roi=(roi&WHOLEIMG);
- std::cout<<roi.tl ().x<<" "<<roi.tl ().y<<endl;
- std::cout<<roi.br ().x<<" "<<roi.br ().y<<endl;
- DetectPedestrian(pedestrian_location,hog,WHOLEIMG,&time);
- if(pedestrian_location.size ()==0) //沒有找到
- start_track = 0;
- count_tmp = -1;
- continue;
- curFrame = pedestrian_location[0]; //獲得了t+1幀的位置信息
- Point2f pt1=GetCentroid (preFrame);
- Point2f pt2=GetCentroid (curFrame);
- // 1. 初始化
- InitialKalmanFilter (kf,pt2.x,pt2.y,pt2.x-pt1.x,pt2.y-pt1.y);
- state_post.push_back (pt2);
- pedestrian_centroid.push_back (pt2);
- pedestrian_centroid_pre.push_back (pt2);
- cout<<"Start!"<<endl;
- fout<<"Kalman Initial Complete!"<<endl;
- else
- // 2.預測
- Mat predict=kf.predict ();
- Point2f predictPt(predict.at<float>(0),predict.at<float>(1));
- fout<<"This is the "<<count<<" frame, and the predict point is ( "<<
- predictPt.x<<" , "<<predictPt.y<<" )"<<endl;
- pedestrian_centroid_pre.push_back (predictPt);
- //cv::circle(blackboard,predictPt,5,red);
- cv::rectangle (blackboard,GetROI (predictPt),red,3);
- cv::circle (img,predictPt,5,red,5);
- // 3.更新Update
- // 1) 使用HoG檢測
- cv::Rect curroi=GetROI (predictPt);
- //cv::Rect curroi=WHOLEIMG;
- //fout<<"This is the "<<count<<" frame, and "<<DescripRect(curroi);
- DetectPedestrian (pedestrian_location,hog,curroi,&time);
- // 2)根據位置更新
- if (pedestrian_location.size ()!=0)
- loss_frame=0;
- int len=pedestrian_location.size ();
- double *dis=new double[len];
- int _min=0;
- for (int j=0;j<len;j++)
- Rect r=pedestrian_location[j];
- Point cen=GetCentroid (r);
- double distan=(cen.x-predictPt.x)*(cen.x-predictPt.x)+
- (cen.y-predictPt.y)*(cen.y-predictPt.y);
- dis[j]=distan;
- if (distan<dis[_min])
- _min=j;
- delete[] dis; //釋放內存
- cv::Rect detected=pedestrian_location[_min];
- #if 0
- if (detected.area ()<pedestrian_location[j].area ())
- detected=pedestrian_location[j];
- //detected |= pedestrian_location[j];
- #endif
- Point2f curCentroid=GetCentroid (detected);
- pedestrian_centroid.push_back (curCentroid);
- cv::circle (blackboard,curCentroid,5,green);
- cv::rectangle (blackboard ,detected,green,3);
- cv::circle (img,curCentroid,5,green,5);
- fout<<"This is the "<<count<<" frame, and the true point is ( "<<
- curCentroid.x<<" , "<<curCentroid.y<<" )"<<endl;
- Mat measure=*(Mat_<float>(2,1)<<curCentroid.x,curCentroid.y);
- kf.correct (measure);
- Mat state=kf.statePost;
- Point2f stateP=Point2f(state.at<float>(0),state.at<float>(1));
- //circle (blackboard ,sta
- state_post.push_back (stateP);
- else
- loss_frame++;
- if (loss_frame>=3)
- printf("Lose the obj in frame %d\n.",count);
- // mark
- start_track = 0;
- count_tmp = -1;
- continue;
- cv::imshow (TRACKER_WINNAME,blackboard );
- count++;
- boardwriter << blackboard;
- videowriter << img;
- int c=waitKey();
- while (c!=27)
- c=waitKey ();
- std::cout<<"-----------------------------"<<endl;
- std::cout<<"Complete!"<<endl;
- fout.close ();
- cv::waitKey();
- return 0;
