查看: 5585|回復: 1
用單片機顯示日期和時間的程序
ID:350621 發表于 2018-6-12 22:42 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
sbit A=P2^2;
sbit D=P2^3;
sbit C=P2^4;
sbit A1=P2^5;
sbit D1=P2^6;
sbit C1=P2^7;
uchar code c[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; int
shi1=2,shi2=3,fen1=5,fen2=9,miao1=4,miao2=0,nian1=1,nian2=8,yue1=0,yue2=6,ri1=0,ri2=6;
int t=0;
void delay(uint z)
uint x;
uchar y;
for(x=z;x>0;x--)
for(y=20;y>0;y--);
void disp1() //年月日
A=0;
D=0;
C=0;
P1=c[nian1]; //顯示該位數字
delay(10); //延時
P1=0x00; //消去陰影
A=1;
D=0;
C=0;
P1=c[nian2];
delay(10);
P1=0x00;
A=0;
D=1;
C=0;
P1=0x40;
delay(10);
P1=0x00;
A=1;
D=1;
C=0;
P1=c[yue1];
delay(10);
P1=0x00;
A=0;
D=0;
C=1;
P1=c[yue2];
delay(10);
P1=0x00;
A=1;
D=0;
C=1;
P1=0x40;
delay(10);
P1=0x00;
A=0;
D=1;
C=1;
P1=c[ri1];
delay(10);
P1=0x00;
A=1;
D=1;
C=1;
P1=c[ri2];
delay(10);
P1=0x00;
void disp2() //時分秒
A1=0;
D1=0;
C1=0;
P0=c[shi1];
delay(10);
P0=0x00;
A1=1;
D1=0;
C1=0;
P0=c[shi2];
delay(10);
P0=0x00;
A1=0;
D1=1;
C1=0;
P0=0x40;
delay(10);
P0=0x00;
A1=1;
D1=1;
C1=0;
P0=c[fen1];
delay(10);
P0=0x00;
A1=0;
D1=0;
C1=1;
P0=c[fen2];
delay(10);
P0=0x00;
A1=1;
D1=0;
C1=1;
P0=0x40;
delay(10);
P0=0x00;
A1=0;
D1=1;
C1=1;
P0=c[miao1];
delay(10);
P0=0x00;
A1=1;
D1=1;
C1=1;
P0=c[miao2];
delay(10);
P0=0x00;
void jishi()
miao2++;
if(miao2==10)
miao2=0;
miao1++;
if(miao1==6)
miao1=0;
fen2++;
if(fen2==10)
fen2=0;
fen1++;
if(fen1==6)
fen1=0;
shi2++;
if(shi1==2)
if(shi2==4)
shi2=0;
shi1=0;
ri2++;
if(ri2==10)
ri2=0;
ri1++;
if(ri1==4)
ri1=0;
yue2++;
if(yue1==1)
if(yue2==3)
yue2=0;
yue1=0;
nian2++;
if(nian2==10)
nian2=0;
nian1++;
if(nian1==10)
nian1=0;
if(yue2==10)
yue2=0;
yue1++;
if(shi2==10)
shi2=0;
shi1++;
disp1();
disp2();
jishi();
ID:359102 發表于 2018-6-29 10:22 | 顯示全部樓層
有電路圖嗎
