查看: 6177|回復: 3
Arduino Libraries庫函數大全(word文檔下載)
Libraries
目錄
Libraries provide extra functionality for use in sketches, e.g. working with hardware or manipulating data. To use a library in a sketch, select it from Sketch > Import Library.
Standard Libraries
•    EEPROM - reading and writing to "permanent" storage
•    Ethernet - for connecting to the internet using the Arduino Ethernet Shield
•    Firmata - for communicating with applications on the computer using a standard serial protocol.
•    LiquidCrystal - for controlling liquid crystal displays (LCDs)
•    SD - for reading and writing SD cards
•    Servo - for controlling servo motors
•    SPI - for communicating with devices using the Serial Peripheral Interface (SPI) Bus
•    SoftwareSerial - for serial communication on any digital pins. Version 1.0 and later of Arduino incorporate Mikal Hart's NewSoftSerial library as SoftwareSerial.
•    Stepper - for controlling stepper motors
•    WiFi - for connecting to the internet using the Arduino WiFi shield
•    Wire - Two Wire Interface (TWI/I2C) for sending and receiving data over a net of devices or sensors.
The Matrix and Sprite libraries are no longer part of the core distribution.
完整的Word格式文檔51黑下載地址:
Arduino Libraries庫函數大全(官方網站).doc (3 MB, 下載次數: 62)
參與人數 2黑幣 +53 收起 理由
azi197417 + 3
ID:379680 發表于 2018-9-8 22:46 | 只看該作者
感謝樓主分享。
ID:199427 發表于 2018-10-4 19:45 | 只看該作者
官網上沒有找到Arduino Libraries的下載鏈接。謝謝樓主提供的資料!
ID:452731 發表于 2019-1-20 23:37 | 只看該作者
很有意義的資料片貢獻
