查看: 5090|回復: 0
單片機led矩陣字符顯示實驗 顯示學號姓名
#include<reg51.h>#define uchar unsigned char
#define uint unsigned int#define out0 P0    #define out2 P2
#define out3 P3   sbit button0=P3^0;void delay(uint j){          uchar i=100;
for(;j>0;j--){while(i--) ;i=100;}}
uchar code sun_L1[]=
        {0x83,0xAB,0xAB,0x83,0x1,0xED,0xDD,0xBD,
     0xEF,0x81,0x83,0x81,0x83,0x83,0x9B,0x43,};     //姓名
uchar code sun_L2[]={                                                   //學號
        0xff,0xe1,0xed,0xed,0xf7,0xfb,0x81,0xff,     //2
        0xff,0x81,0x7d,0x7d,0x7d,0x7d,0x81,0xff,     //0
        0xff, 0xf7,0xf7,0xf7,0xf7,        0xf7, 0xe3,0xff,  //1
        0xff,0x83,0xfb,0xc3,0xdf,0xdf,0xc3,0xff,     //5
    0xff,0x81,0x7d,0x7d,0x81,0x7d,0x7d,0x81,           //8  };
uchar code sun_H[]=        { 0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
{ uchar i,j,n,k;   while(1)
        { while(out3==0xff)
      {             for(k=0;k<2;k++)  {for(n=0;n<40;n++)                //k為名字的數字,幾個字
        {if(out3==0xfe) break;
        for(i=0,j=0;i<8,j<8;i++,j++)
        out2=sun_H[j];
        out0=sun_L1[i+8*k];
        delay(4);          out0=0xff;out2=0xff;}}    delay(20);}}
while(button0==0x00)        { for(k=0;k<10;k++)
{   for(n=0;n<40;n++)
   {if(out3==0xff) break;
  out2=sun_H[j];
  out0=sun_L2[i+8*k]; delay(2); out0=0xff;out2=0xff;        }}
  delay(20);}}}
實驗2.zip
31.17 KB, 下載次數: 7, 下載積分: 黑幣 -5
