查看: 5040|回復: 3
89C51控制交通燈系統(tǒng)程序
ID:348183 發(fā)表于 2018-6-11 00:12 | 顯示全部樓層 |閱讀模式
#include <reg52.h>          //調(diào)用單片機頭文件
#define uchar unsigned char   //宏定義"uchar"代替"unsigned char"。
#define uint  unsigned int   //宏定義"uint"用來定義無符號整型數(shù)。
uchar a_a;
////數(shù)碼管段選定義  0   1    2    3    4    5  6  7   8    9
uchar smg_du[]={0x6f,0x03,0x3d,0x4b,0x53,0x75,0x7e,0x28,0x7f,0x7b,
//        A B  C   D    E   F 不顯示
             0x77,0x5e,0x4a,0x05,0x0a,0x2a,0xff};  //斷碼
uchar dis_smg[8] = {0};
uchar smg_i = 4;    //顯示數(shù)碼管的個位數(shù)
//數(shù)碼管位選定義
sbit smg_we1 = P2^1; //數(shù)碼管位選定義
sbit smg_we2 = P2^0;
sbit smg_we3 = P3^6;
sbit smg_we4 = P3^7;
uint dx_zong   = 0;
uint nb_zong   = 0;
int dx_s = 0,nb_s = 0; //東西  南北 倒計時變量
sbit dx_red    = P2^7;     //東西紅燈
sbit dx_yellow = P2^6;  //東西黃燈
sbit dx_green  = P2^5;  //東西綠燈
sbit nb_red    = P2^4;  //南北紅燈
sbit nb_yellow = P2^3;  //南北黃燈
sbit nb_green  = P2^2;  //南北綠燈
sbit nb_green_ll  = P1^6;  //南北綠燈
sbit dx_green_ll  = P1^7;  //東西綠燈
sbit dx_h_red = P3^5;        //東西人行橫道紅燈
sbit dx_h_green = P3^4;      //東西人行橫道紅燈
sbit nb_h_red = P3^2;        //南北人行橫道紅燈
sbit nb_h_green = P3^3;      //南北人行橫道紅燈
sbit nb_che = P1^4;         //南北車計流量
sbit dx_che = P1^5;         //東西車計流量
uint nb_che_value;
uint dx_che_value;
uchar  nb[20];
uchar xdata dx[20];
uchar flag_che,miao;   //本看車流量
uchar flag_jtd_mode;  //交通燈的模式 根據(jù)時間
bit flag_1s = 0;
bit flag_500ms;
bit flag_dx_nb = 0;   //東西南北模式
uchar flag_5m_value;
uchar i;
uchar dx_time = 30,nb_time = 20;   //東西、南北的時間
uchar nb_time_ll = 20,dx_time_ll = 20;   //東西、南北左轉(zhuǎn)的時間
uchar yellow_time = 5;
uchar flag_jdgz ;     //交通管制
uchar nb_ll,dx_ll;   //南北 東西加的時間
/***********************數(shù)碼位選函數(shù)*****************************/
void smg_we_switch(uchar i)
switch(i)
  case 0: smg_we1 = 0;  smg_we2 = 1; smg_we3 = 1;  smg_we4 = 1; break;
  case 1: smg_we1 = 1;  smg_we2 = 1; smg_we3 = 0;  smg_we4 = 1; break;
  case 2: smg_we1 = 1;  smg_we2 = 0; smg_we3 = 1;  smg_we4 = 1; break;
  case 3: smg_we1 = 1;  smg_we2 = 1; smg_we3 = 1;  smg_we4 = 0; break;
* 名稱 : delay_1ms()
* 功能 : 延時1ms函數(shù)
* 輸入 : q
* 輸出 : 無
void delay_1ms(uint q)
uint i,j;
for(i=0;i<q;i++)
  for(j=0;j<110;j++);
* 名稱 : display()
* 功能 : 數(shù)碼管顯示
* 輸入 : 無
* 輸出 : 無
void display()
uchar i;
for(i=0;i<smg_i;i++)
  smg_we_switch(i);     //位選
  P0 = dis_smg[i];   //段選
/*********************定時器0、定時器1初始化******************/
void time0_init()
EA  = 1;     //開總中斷
TMOD = 0X11;   //定時器0、定時器1工作方式1
ET0 = 1;    //開定時器0中斷
TR0 = 1;    //允許定時器0定時
uchar flag_csf=1;
uchar f_value=0;
/*********************交通燈處理函數(shù)*********************************/
void jiaotongdeng_dis()
/***********************南北時間*********************************/
  if(f_value < nb_ll + nb_time) //南北綠燈時間
   if(flag_csf == 1)   //意思是只初始化一次
    flag_csf = 2;
    dx_zong = dx_s = nb_ll + nb_time_ll + yellow_time; //是顯示南北的總時間
    nb_s = nb_ll + nb_time; //給南北倒計時顯示初始化值
   dx_red    = 0;
   dx_green  = 1;//滅
   dx_yellow = 1;//滅
   nb_red    = 1;
   nb_green  = 0;
   nb_yellow = 1;    //滅
   nb_green_ll = 1;
   dx_green_ll = 1;
   flag_5m_value = 0;
  else if(f_value < nb_ll + nb_time + yellow_time)   //當小于5秒時  黃燈要閃了
   if(flag_csf == 2)   //意思是只初始化一次
    flag_csf = 3;
    dx_s = nb_time_ll + 2*yellow_time; //是顯示南北的總時間
    nb_s = yellow_time; //給南北倒計時顯示初始化值
   dx_red    = 0;
   dx_green  = 1;    //滅
   dx_yellow = 1;    //滅
   nb_red    = 1;
   nb_green  = 1;    //滅
   if(flag_500ms == 0)    //黃燈閃爍
    nb_yellow = 0;
    nb_yellow = 1;
   dx_h_green = 1;
   dx_h_red = 0;
   nb_h_green = 0;
   nb_h_red = 1;
  else if(f_value < nb_ll + nb_time + nb_time_ll)   //當左轉(zhuǎn)的綠燈閃
   if(flag_csf == 3)   //意思是只初始化一次
    flag_csf = 4;
    dx_s = nb_time_ll + yellow_time; //是顯示南北的總時間
    nb_s = nb_time_ll; //給南北倒計時顯示初始化值
   dx_red    = 0;
   dx_green  = 1;    //滅
   dx_yellow = 1;    //滅
   nb_green  = 1;    //滅
   nb_yellow = 1;    //滅
   dx_h_green = 1;
   dx_h_red = 0;
   nb_h_green = 1;
  else if(f_value < nb_ll + nb_time +  nb_time_ll)   //當小于5秒時  黃燈要閃了
   if(flag_csf == 4)   //意思是只初始化一次
    flag_csf = 1;
    dx_s = nb_s = yellow_time; //給南北倒計時顯示初始化值
   dx_red    = 0;
   dx_green  = 1;    //滅
   dx_yellow = 1;    //滅
    nb_yellow = 0;
    nb_yellow = 1;    //滅
   dx_h_green = 1;     //滅
   nb_h_green = 1;     //滅
   nb_h_red = 0;
   nb_green_ll = 1;    //滅
   dx_green_ll = 1;    //滅
/***********************東西時間*********************************/
  if(flag_dx_nb == 1)
   if(f_value < dx_ll + dx_time) //東西綠燈時間
     flag_csf = 2;
     nb_zong = nb_s = dx_ll +  dx_time_ll + 2*yellow_time; //是顯示南北的總時間
     dx_s = dx_ll + dx_time; //給南北倒計時顯示初始化值
    dx_red    = 1;    //滅
    dx_green  = 0;
    dx_yellow = 1;    //滅
    nb_red    = 0;
    nb_green  = 1;    //滅
    nb_yellow = 1;    //滅
    dx_h_green = 0;
    dx_h_red = 1;    //滅
    nb_h_green = 1;    //滅
    nb_h_red = 0;
    flag_5m_value = 0;
   else if(f_value < dx_ll + dx_time+ yellow_time)   //當小于5秒時  黃燈要閃了
     flag_csf = 3;
     nb_s = dx_time_ll + 2*yellow_time; //是顯示南北的總時間
     dx_s = yellow_time; //給南北倒計時顯示初始化值
//     while(1);
    dx_red    = 1;    //滅
    dx_green  = 1;    //滅
    nb_red    = 0;
    nb_green  = 1;    //滅
    nb_yellow = 1;    //滅
    if(flag_500ms == 0)
     dx_yellow = 0;
     dx_yellow = 1;    //滅
    dx_h_green = 0;
    dx_h_red = 1;    //滅
    nb_h_green = 1;    //滅
    nb_h_red = 0;
   else if(f_value < dx_ll + dx_time+dx_time_ll+ yellow_time)   //東西左轉(zhuǎn)
     flag_csf = 4;
     nb_s = dx_time_ll + yellow_time; //是顯示南北的總時間
     dx_s = dx_time_ll; //給南北倒計時顯示初始化值
    dx_red    = 1;    //滅
    dx_green  = 1;    //滅
    dx_yellow = 1;    //滅
    nb_red    = 0;
    nb_green  = 1;    //滅
    nb_yellow = 1;    //滅
    dx_h_green = 1;    //滅
    nb_h_green = 1;    //滅
    nb_h_red = 0;
    nb_green_ll = 1;
    dx_green_ll = 0;
   else if(f_value < dx_ll + dx_time+dx_time_ll+ yellow_time*2)   //當小于5秒時  黃燈要閃了
     flag_csf = 1;
     nb_s =  yellow_time; //是顯示南北的總時間
    dx_red    = 1;    //滅
    dx_green  = 1;    //滅
    nb_red    = 0;
    nb_green  = 1;    //滅
    nb_yellow = 1;    //滅
    if(flag_500ms == 0)
     dx_yellow = 0;
     dx_yellow = 1;    //滅
    dx_h_green = 1;    //滅
    dx_h_red = 0;
    nb_h_green = 1;    //滅
    nb_h_red = 0;
if(flag_1s == 1)
  flag_1s = 0;
  miao ++;
  if(miao >= 60)
   miao = 0;
  dx_che_value = 0;
  dx_s --;
  nb_s --;
  f_value ++;
  if(flag_dx_nb == 0)    //南北時間
   if(f_value >= dx_zong)
    f_value = 0;
    flag_dx_nb = 1;   //東西綠燈模式
    if(nb_che_value >= 30)
     nb_ll = 20;
    else if(nb_che_value >= 20)
     nb_ll = 10;
     nb_ll = 0;
  if(flag_dx_nb == 1)    //東西時間
   if(f_value >= nb_zong)
    f_value = 0;
    flag_dx_nb = 0;   //南北綠燈模式
    if(dx_che_value >= 30)
     dx_ll = 20;
    else if(dx_che_value >= 20)
     dx_ll = 10;
     dx_ll = 0;
dis_smg[0] = smg_du[dx_s % 10] ; //顯示
dis_smg[1] = smg_du[dx_s / 10] ;
dis_smg[2] = smg_du[nb_s % 10] ;
dis_smg[3] = smg_du[nb_s / 10] ;
/********************獨立按鍵程序*****************/
uchar key_can;  //按鍵值
void key()  //獨立按鍵程序
static uchar key_new;
key_can = 20;                   //按鍵值還原
P1 |= 0x0f;
if((P1 & 0x0f) != 0x0f)  //按鍵按下
  delay_1ms(1);       //按鍵消抖動
  if(((P1 & 0x0f) != 0x0f) && (key_new == 1))
  {      //確認是按鍵按下
   key_new = 0;
   switch(P1 & 0x0f)
    case 0x0e:  key_can = 4;  break;  //得到按鍵值
    case 0x0d:  key_can = 3;  break;  //得到按鍵值
    case 0x0b:  key_can = 2;  break;  //得到按鍵值
    case 0x07:  key_can = 1;  break;  //得到按鍵值
  key_new = 1;
uchar menu_1,flag_s;
/********************設置函數(shù)*****************/
void key_with()
if(menu_1 == 0)
  if(key_can == 2)
   flag_che = 1;  //查看車流量
  if(key_can == 3)
   flag_che = 0;
if(key_can == 4)   //交通管制按鍵
  flag_jdgz ++;
  if(flag_jdgz > 6)
   flag_jdgz = 0;
  if(flag_jdgz == 1)  //  全部亮紅燈
   dx_green  = 1;    //滅
   dx_yellow = 1;    //滅
   nb_green  = 1;    //滅
   nb_yellow = 1;    //滅
  if(flag_jdgz == 2)  //  南北黃燈  東西黃燈
   dx_red    = 1;    //滅
   dx_green  = 1;    //滅
   dx_yellow = 0;    //亮
   nb_red    = 1;    //滅
   nb_green  = 1;    //滅
   nb_yellow = 0;    //亮
  if(flag_jdgz == 3)  //  東西紅燈  南北綠燈
   dx_red    = 0;    //亮
   dx_green  = 1;    //滅
   dx_yellow = 1;    //滅
   nb_red    = 1;    //滅
   nb_green  = 0;    //亮
   nb_yellow = 1;    //滅
   dx_h_green = 1;    //滅
   dx_h_red = 1;    //亮
   nb_h_green = 0;    //亮
   nb_h_red = 1;    //滅
  if(flag_jdgz == 4)  //  南北紅燈  東西綠燈
   dx_red    = 1;    //滅
   dx_green  = 0;    //亮
   dx_yellow = 1;    //滅
   nb_red    = 0;    //亮
   dx_h_green = 0;    //亮
   dx_h_red = 1;    //滅
   nb_h_green = 1;    //滅
   nb_h_red = 0;    //亮
  if(flag_jdgz == 5)  //    南北左轉(zhuǎn)綠燈
   dx_red    = 0;    //亮
   dx_green  = 1;    //滅
   nb_green  = 1;    //滅
   nb_yellow = 1;    //滅
   dx_h_green = 1;    //滅
   dx_h_red = 0;    //亮
   nb_h_green = 1;    //滅
   nb_h_red = 0;    //亮
  if(flag_jdgz == 6)  //  南北紅燈  東西左轉(zhuǎn)綠燈
   dx_red    = 0;    //亮
   dx_green  = 1;    //滅
   dx_yellow = 1;    //滅
   nb_yellow = 1;    //滅
   dx_h_green = 1;    //滅
   dx_h_red = 0;    //亮
   nb_h_green = 1;    //滅
   nb_h_red = 0;    //亮
   dx_green_ll = 0;
if(key_can == 1)   //設置鍵
  menu_1 ++;
  if(menu_1 > 5)
   menu_1  = 0;
if(menu_1 == 1)    //設置東西的時間
  if(key_can == 2)
   dx_time ++ ;  //加1
   if(dx_time > 99)
    dx_time = 99;
  if(key_can == 3)
   dx_time -- ;  //減1
   if(dx_time <= 5)
    dx_time = 5;
  dis_smg[0] = smg_du[dx_time % 10] ;  //顯示東西設置的時候
  dis_smg[1] = smg_du[dx_time / 10] ;
if(menu_1 == 2)    //設置南北的時間
  if(key_can == 2)
   nb_time ++ ;  //加1
   if(nb_time > 99)
    nb_time = 99;
  if(key_can == 3)
   nb_time -- ;  //減1
   if(nb_time <= 5)
    nb_time = 5;
  dis_smg[2] = smg_du[nb_time % 10] ;  //顯示東西設置的時候
  dis_smg[3] = smg_du[nb_time / 10] ;
if(menu_1 == 3)    //設置黃燈的時間
  if(key_can == 2)
   yellow_time ++ ;  //加1
   if(yellow_time > 99)
    yellow_time = 99;
  if(key_can == 3)
   yellow_time -- ;  //減1
   if(yellow_time <= 1)
    yellow_time = 1;
  dis_smg[0] = smg_du[yellow_time % 10] ;  //顯示黃燈時間
  dis_smg[1] = smg_du[yellow_time / 10] ;
  dis_smg[2] = smg_du[yellow_time % 10] ;  //顯示黃燈時間
  dis_smg[3] = smg_du[yellow_time / 10] ;
if(menu_1 == 4)    //設置東西左邊的時間
  if(key_can == 2)
   dx_time_ll ++ ;  //加1
   if(dx_time_ll > 99)
    dx_time_ll = 99;
  if(key_can == 3)
   dx_time_ll -- ;  //減1
   if(dx_time_ll <= 5)
    dx_time_ll = 5;
  dis_smg[0] = smg_du[dx_time_ll % 10] ;  //顯示東西設置的時候
  dis_smg[1] = smg_du[dx_time_ll / 10] ;
  dis_smg[2] = 0xcc ; //不顯示
  dis_smg[3] = 0x00 ; //L
if(menu_1 == 5)    //設置南北左轉(zhuǎn)的時間
  if(key_can == 2)
   nb_time_ll ++ ;  //加1
   if(nb_time_ll > 99)
    nb_time_ll = 99;
  if(key_can == 3)
   nb_time_ll -- ;  //減1
   if(nb_time_ll <= 5)
    nb_time_ll = 5;
  dis_smg[0] = 0x00 ; //不顯示
  dis_smg[1] = 0xcc ; //L
  dis_smg[2] = smg_du[nb_time_ll % 10] ;  //顯示東西設置的時候
  dis_smg[3] = smg_du[nb_time_ll / 10] ;
/********************車計流量程序*****************/
void che_liuliang()  //車計流量程序
static uchar value1,value2;
if(nb_che == 0)  //計南北車的流量
  if((nb_che == 0) && (value1 == 1))
  {      //確認是按鍵按下
   value1 = 0;
   nb[miao] += 1;
  value1 = 1;
if(dx_che == 0)  //計東西車的流量
  if((dx_che == 0) && (value2 == 1))
  {      //確認是按鍵按下
   value2 = 0;
   dx[miao] += 1;
  value2 = 1;
* 名稱 : main()
* 功能 : 實現(xiàn)燈的閃爍
* 輸入 : 無
* 輸出 : 無
time0_init();
  key();
  if(key_can < 20)
   key_with();
  che_liuliang();  //車計流量程序
  jiaotongdeng_dis();
  display();
/*********************定時器0中斷服務程序************************/
void time0_int() interrupt 1
static uchar value;    //定時10ms中斷一次
TH0 = 0x3c;
TL0 = 0xb0;     //50ms
value ++;
flag_5m_value++;
if(flag_5m_value % 10 == 0)
  flag_500ms = ~flag_500ms;
if(value >= 20)
  value = 0;
  flag_1s = 1;
無效樓層,該帖已經(jīng)被刪除
ID:464230 發(fā)表于 2019-3-14 13:47 | 顯示全部樓層
這程序仿真時就出錯,不對
ID:493144 發(fā)表于 2019-3-28 12:52 | 顯示全部樓層
九幽幻辰 發(fā)表于 2019-3-14 13:47
這程序仿真時就出錯,不對
請問您改出來了嗎?
