XHDZ-30102引腳圖:
2018-6-10 00:50 上傳
管腳功能:
2018-6-10 00:51 上傳
XHDZ-30102芯片介紹:
General Description
The MAX30102 is an integrated pulse oximetry and
heart-rate monitor module. It includes internal LEDs,
photodetectors, optical elements, and low-noise electronics
with ambient light rejection. The MAX30102 provides a
complete system solution to ease the design-in process
for mobile and wearable devices.
The MAX30102 operates on a single 1.8V power supply
and a separate 5.0V power supply for the internal LEDs.
Communication is through a standard I2C-compatible
interface. The module can be shut down through software
with zero standby current, allowing the power rails to
remain powered at all times.
完整的pdf格式文檔51黑下載地址:
MAX30102.pdf
(930.99 KB, 下載次數: 7)
2018-6-9 14:30 上傳
下載積分: 黑幣 -5
