- #include<stm32f10x.h>
- void TIM3_PWM_Init(u16 arr,u16 psc);
- //1ms延時函數(shù)(72MHz)
- void delay_nms(u16 time)
- u16 i=0;
- while(time--)
- i=12000;
- while(i--);
- int main(void)
- u16 TIMpulse=0;
- u8 dir=1;
- //TIM3_PWM_Init(899,0);//不分頻,PWM頻率=72000/900=80khz
- TIM3_PWM_Init(999,61999);//1HZ,
- delay_nms(100);//觀察初始化的pwm
- // TIM_SetCompare2(TIM3,200);//占空比200/999+1=20%
- while(1)
- if(dir)TIMpulse++;
- else TIMpulse--;
- if(TIMpulse>999)dir=0;
- if(TIMpulse==0)dir=1;
- TIM_SetCompare2(TIM3,TIMpulse);//程序中修改占空比TIMpulse/arr
- //arr:自動裝載值 psc:預(yù)分頻數(shù)
- //TIM3 PWM部分初始化
- GPIO_InitTypeDef GPIO_InitStructure;
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO,ENABLE);//開啟重映射時鐘
- GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3,ENABLE);//重映射TIM3_CH2到PB5輸出
- //GPIO設(shè)置為復(fù)用輸出,輸出TIM3的CH2的PWM脈沖波形GPIOB5
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_5;
- GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_Init(GPIOB,&GPIO_InitStructure);
- //初始化TIM3
- TIM_TimeBaseStructure.TIM_Period=arr; //設(shè)置自動重裝載周期值(決定PWM的頻率)
- TIM_TimeBaseStructure.TIM_Prescaler=psc; //預(yù)分頻值
- TIM_TimeBaseStructure.TIM_ClockDivision=0; //設(shè)置時鐘分割:TDTS=Tck_tim
- TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;//向上計(jì)數(shù)
- TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);
- //初始化TIM3 Channel2 PWM模式
- TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2; //選擇PWM模式2,計(jì)數(shù)值大于比較值有效
- TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable; //比較輸出使能
- TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High; //輸出極性 高為有效值
- //配置占空比 500/arr重載計(jì)數(shù)器=500/999+1,,和函數(shù)TIM_SetCompare2(TIM3,TIMpulse);功能一樣
- TIM_OCInitStructure.TIM_Pulse=500;
- TIM_OC2Init(TIM3,&TIM_OCInitStructure); //初始化外設(shè)TIM3 OC2通道
- TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable); //使能預(yù)裝載器即TIM3_CCR2的預(yù)裝載值在更新事件到來時才能被傳送至當(dāng)前寄存器中
- TIM_Cmd(TIM3,ENABLE); //使能TIM3
