查看: 12229|回復: 2
51單片機ADC0832模數(shù)轉換與顯示實例
ID:138707 發(fā)表于 2018-6-8 11:50 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
##ADC0832模數(shù)轉換與顯示##
1602液晶顯示的ADC0832模數(shù)轉換的電路原理圖如下:
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #define uint unsigned int
  5. #define delay4us() {_nop_();_nop_();_nop_();_nop_();}
  6. sbit RS = P2^0;
  7. sbit RW = P2^1;
  8. sbit E  = P2^2;
  9. sbit CS  = P1^0;
  10. sbit CLK = P1^1;
  11. sbit DIO = P1^2;
  12. uchar Display_Buffer[] = "0.00V";
  13. uchar code Line1[] = "Current Voltage:";
  14. void DelayMS(uint ms)  {
  15.          uchar i;
  16.         while(ms--)         {
  17.                  for(i=0;i<120;i++);
  18.         }
  19. }
  20. bit LCD_Busy_Check()  {
  21.          bit result;
  22.         RS = 0;
  23.         RW = 1;
  24.         E  = 1;
  25.         delay4us();
  26.         result = (bit)(P0&0x80);
  27.         E  = 0;
  28.         return result;
  29. }
  30. void LCD_Write_Command(uchar cmd)  {
  31.          while(LCD_Busy_Check());
  32.         RS = 0;
  33.         RW = 0;
  34.         E  = 0;
  35.         _nop_();
  36.         _nop_();
  37.         P0 = cmd;
  38.         delay4us();
  39.         E = 1;
  40.         delay4us();
  41.         E = 0;
  42. }
  43. void Set_Disp_Pos(uchar pos)  {
  44.          LCD_Write_Command(pos | 0x80);
  45. }
  46. void LCD_Write_Data(uchar dat)   {
  47.          while(LCD_Busy_Check());
  48.         RS = 1;
  49.         RW = 0;
  50.         E  = 0;
  51.         P0 = dat;
  52.         delay4us();
  53.         E = 1;
  54.         delay4us();
  55.         E = 0;
  56. }
  57. void LCD_Initialise()  {
  58.         LCD_Write_Command(0x38); DelayMS(1);
  59.         LCD_Write_Command(0x0c); DelayMS(1);
  60.         LCD_Write_Command(0x06); DelayMS(1);
  61.         LCD_Write_Command(0x01); DelayMS(1);
  62. }
  63. uchar Get_AD_Result() {
  64.          uchar i,dat1=0,dat2=0;
  65.         CS  = 0;
  66.         CLK = 0;
  67.         DIO = 1; _nop_(); _nop_();
  68.         CLK = 1; _nop_(); _nop_();
  69.         CLK = 0;DIO = 1; _nop_(); _nop_();
  70.         CLK = 1; _nop_(); _nop_();
  71.         CLK = 0;DIO = 1; _nop_(); _nop_();
  72.         CLK = 1;DIO = 1; _nop_(); _nop_();
  73.         CLK = 0;DIO = 1; _nop_(); _nop_();
  74.         for(i=0;i<8;i++)         {
  75.                  CLK = 1; _nop_(); _nop_();
  76.                 CLK = 0; _nop_(); _nop_();
  77.                 dat1 = dat1 << 1 | DIO;
  78.         }
  79.         for(i=0;i<8;i++)         {
  80.                  dat2 = dat2 << ((uchar)(DIO)<<i);
  81.                 CLK = 1; _nop_(); _nop_();
  82.                 CLK = 0; _nop_(); _nop_();
  83.         }
  84.         CS = 1;
  85.         return (dat1 == dat2) ? dat1:0;
  86. }
  87. void main()  {
  88.          uchar i;
  89.         uint d;
  90.         LCD_Initialise();
  91.         DelayMS(10);
  92.         while(1)
  93.         {
  94.                  d = Get_AD_Result()*500.0/255;
  95.                 Display_Buffer[0]=d/100+'0';
  96.                 Display_Buffer[2]=d/10%10+'0';
  97.                 Display_Buffer[3]=d%10+'0';
  98.                 Set_Disp_Pos(0x01);
  99.                 i = 0;
  100.                 while(Line1[ i]!='\0')  {
  101.                          LCD_Write_Data(Line1[i+1]);
  102.                 }
  103.                 Set_Disp_Pos(0x46);
  104.                 i = 0;
  105.                 while(Display_Buffer!='\0')
  106.                 {
  107.                          LCD_Write_Data(Display_Buffer[i+1]);
  108.                 }
  109.         }
  110. }
51單片機ADC0832模數(shù)轉換與顯示實例.docx (49.45 KB, 下載次數(shù): 107)
參與人數(shù) 1黑幣 +50 收起 理由
ID:642435 發(fā)表于 2019-11-25 23:07 | 只看該作者
仿真LM016L怎么全是uuuuuu
ID:549426 發(fā)表于 2020-11-4 20:05 | 只看該作者
要是你打包資料下載就好了
