查看: 4451|回復(fù): 1
OFDM不同信噪比下的誤碼率matlab源碼
ID:346524 發(fā)表于 2018-6-6 22:18 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
clear;
clc;
s = rng(211);            % 設(shè)置RNG狀態(tài)的可重復(fù)性
numFFT = 1024;           % FFT點(diǎn)的數(shù)量
numRBs = 50;             % 資源塊的數(shù)量
rbSize = 12;             % 每個(gè)資源塊的副載波數(shù)量
cpLen = 72;              % 樣本中的循環(huán)前綴長度
bitsPerSubCarrier = 6;   % 2: QPSK, 4: 16QAM, 6: 64QAM, 8: 256QAM
snrdB =30;              % 以dB為單位的SNR
toneOffset = 2.5;        % 音調(diào)偏移或超額帶寬(在副載波中)
L = 513;                 % 濾波器長度(=濾波器次序+ 1),奇數(shù)
numDataCarriers = numRBs*rbSize;    % 子帶中數(shù)據(jù)子載波的數(shù)量
halfFilt = floor(L/2);
n = -halfFilt:halfFilt;
% Sinc函數(shù)原型濾波器
pb = sinc((numDataCarriers+2*toneOffset).*n./numFFT);
% Sinc截?cái)啻翱?br /> w = (0.5*(1+cos(2*pi.*n/(L-1)))).^0.6;
% 歸一化的低通濾波器系數(shù)
fnum = (pb.*w)/sum(pb.*w);
% 過濾脈沖響應(yīng)
h = fvtool(fnum, 'Analysis', 'impulse', ...
    'NormalizedFrequency', 'off', 'Fs', 15.36e6);
h.CurrentAxes.XLabel.String = 'Time (\mus)';
h.FigureToolbar = 'off';
% 使用dsp過濾器對象進(jìn)行過濾
filtTx = dsp.FIRFilter('Structure', 'Direct form symmetric', ...
    'Numerator', fnum);
filtRx = clone(filtTx); % Rx的匹配過濾器
% QAM符號映射器
qamMapper = comm.RectangularQAMModulator( ...
    'ModulationOrder', 2^bitsPerSubCarrier, 'BitInput', true, ...
    'NormalizationMethod', 'Average power');
% 為譜圖設(shè)置一個(gè)數(shù)字
hFig = figure('Position', figposition([46 50 30 30]), 'MenuBar', 'none');
axis([-0.5 0.5 -200 -20]);
hold on;
grid on
xlabel('Normalized frequency');
ylabel('PSD (dBW/Hz)')
title(['F-OFDM, ' num2str(numRBs) ' Resource blocks, '  ...
    num2str(rbSize) ' Subcarriers each'])
% 生成數(shù)據(jù)符號
bitsIn = randi([0 1], bitsPerSubCarrier*numDataCarriers, 1);
symbolsIn = qamMapper(bitsIn);
% 將數(shù)據(jù)打包成OFDM符號
offset = (numFFT-numDataCarriers)/2; % 為通帶中心
symbolsInOFDM = [zeros(offset,1); symbolsIn; ...
                 zeros(numFFT-offset-numDataCarriers,1)];
ifftOut = ifft(ifftshift(symbolsInOFDM));
%預(yù)先加上循環(huán)前綴
txSigOFDM = [ifftOut(end-cpLen+1:end); ifftOut];
% 使用零填充過濾器來刷新尾部。 獲取發(fā)射信號
txSigFOFDM = filtTx([txSigOFDM; zeros(L-1,1)]);
%繪制功率譜密度(PSD)
[psd,f] = periodogram(txSigFOFDM, rectwin(length(txSigFOFDM)), ...
                      numFFT*2, 1, 'centered');
plot(f,10*log10(psd));
% 計(jì)算峰均功率比(PAPR)
PAPR = comm.CCDF('PAPROutputPort', true, 'PowerUnits', 'dBW');
[~,~,paprFOFDM] = PAPR(txSigFOFDM);
disp(['Peak-to-Average-Power-Ratio for F-OFDM = ' num2str(paprFOFDM) ' dB']);
% 繪制OFDM信號的功率譜密度(PSD)
[psd,f] = periodogram(txSigOFDM, rectwin(length(txSigOFDM)), numFFT*2, ...
                      1, 'centered');
hFig1 = figure('Position', figposition([46 15 30 30]));
grid on
title(['OFDM, ' num2str(numRBs*rbSize) ' Subcarriers'])
%計(jì)算峰均功率比(PAPR)
PAPR2 = comm.CCDF('PAPROutputPort', true, 'PowerUnits', 'dBW');
[~,~,paprOFDM] = PAPR2(txSigOFDM);
disp(['Peak-to-Average-Power-Ratio for OFDM = ' num2str(paprOFDM) ' dB']);
%添加AWGN和Rayleigh
chan = rayleighchan(0.00001,100);
rxSig = filter(chan,txSigFOFDM);
rxtSig = awgn(rxSig, snrdB, 'measured');
% 接收匹配的過濾器,
rxSigFilt = filtRx(rxtSig);
% 考慮過濾器延遲
rxSigFiltSync = rxSigFilt(L:end);
% 刪除循環(huán)前綴
rxSymbol = rxSigFiltSync(cpLen+1:end);
%執(zhí)行FFT
RxSymbols = fftshift(fft(rxSymbol));
%選擇數(shù)據(jù)副載波
dataRxSymbols = RxSymbols(offset+(1:numDataCarriers));
% 繪制接收符號星座圖
switch bitsPerSubCarrier
    case 2  % QPSK
        refConst = qammod((0:3).', 4, 'UnitAveragePower', true);
    case 4  % 16QAM
        refConst = qammod((0:15).', 16,'UnitAveragePower', true);
    case 6  % 64QAM
        refConst = qammod((0:63).', 64,'UnitAveragePower', true);
    case 8  % 256QAM
        refConst = qammod((0:255).', 256,'UnitAveragePower', true);
end
constDiagRx = comm.ConstellationDiagram( ...
    'ShowReferenceConstellation', true, ...
    'ReferenceConstellation', refConst, ...
    'Position', figposition([20 15 30 40]), ...
    'MeasurementInterval', length(dataRxSymbols), ...
    'Title', 'F-OFDM Demodulated Symbols', ...
    'Name', 'F-OFDM Reception', ...
    'XLimits', [-1.5 1.5], 'YLimits', [-1.5 1.5]);
constDiagRx(dataRxSymbols);
% 由于沒有通道建模,因此通道均衡不是必要的
%解映射和BER計(jì)算
qamDemod = comm.RectangularQAMDemodulator('ModulationOrder', ...
    2^bitsPerSubCarrier, 'BitOutput', true, ...
BER = comm.ErrorRate;
% 執(zhí)行艱難的決策并測量錯(cuò)誤
rxBits = qamDemod(dataRxSymbols);
ber = BER(bitsIn, rxBits);
disp(['F-OFDM Reception, BER = ' num2str(ber(1)) ' at SNR = ' ...
    num2str(snrdB) ' dB']);
%恢復(fù)RNG狀態(tài)
rng(s);
ID:395916 發(fā)表于 2018-9-10 10:40 | 只看該作者
這段代碼,我正在看,不知你有什么理解,可以溝通一下。
