單片機(jī)源程序如下:
- //程序頭函數(shù)
- #include <reg52.h>
- //顯示函數(shù)
- #include "intrins.h"
- //宏定義
- #define uint unsigned int
- #define uchar unsigned char
- //宏定義
- //管腳聲明
- sbit LED_wendu = P2^5; //溫度上限值操作端口,報(bào)警燈吸合繼電器;
- sbit LED_wendu_L = P2^4; //溫度下限報(bào)警燈
- sbit LED_humi = P2^2; //濕度上限報(bào)警燈
- sbit LED_humi_L = P2^0; //濕度下限報(bào)警燈
- sbit baojing = P3^2; //蜂鳴器接口
- //按鍵
- sbit Key1=P1^1; //設(shè)置鍵
- sbit Key2=P1^5; //加按鍵
- sbit Key3=P1^6; //減按鍵
- sbit DHT11=P1^0; //DHT11
- signed char w; //溫度值全局變量
- uint c; //溫度值全局變量
- uchar temp; //用于讀取ADC數(shù)據(jù)
- uchar yushe_wendu=60; //溫度預(yù)設(shè)值
- uchar yushe_humi=80; //濕度預(yù)設(shè)值
- uchar yushe_wendu_L=05; //溫度預(yù)設(shè)值
- uchar yushe_humi_L=10; //濕度預(yù)設(shè)值
- //按鈕模式|
- uchar Mode=0;
- uchar U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
- uchar U8FLAG,U8comdata;
- uchar U8count,U8temp;
- uchar U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
- //軟件延時(shí)函數(shù)
- void delay(uint z) //延時(shí)函數(shù)大約延時(shí)z ms
- uint i,j;
- for(i=0;i<z;i++)
- for(j=0;j<121;j++);
- void Delay_Ms(uint ms)
- uint i,j;
- for(i=ms;i>0;i--)
- for(j=112;j>0;j--);
- LCD1602相關(guān)命令
- //LCD管腳聲明 (RW引腳實(shí)物直接接地,因?yàn)楸驹O(shè)計(jì)只用到液晶的寫(xiě)操作,RW引腳一直是低電平)
- sbit LCDRS = P2^7;
- sbit LCDEN = P2^6;
- //初始畫(huà)時(shí)顯示的內(nèi)容
- uchar code Init1[]="TA= L H ";
- uchar code Init2[]="RH= % L % H %";
- //LCD延時(shí)
- void LCDdelay(uint z) //該延時(shí)大約100us(不精確,液晶操作的延時(shí)不要求很精確)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=10;y>0;y--);
- //寫(xiě)命令
- void write_com(uchar com)
- LCDRS=0;
- P0=com;
- LCDdelay(5);
- LCDEN=1;
- LCDdelay(5);
- LCDEN=0;
- //寫(xiě)數(shù)據(jù)
- void write_data(uchar date)
- LCDRS=1;
- P0=date;
- LCDdelay(5);
- LCDEN=1;
- LCDdelay(5);
- LCDEN=0;
- //1602初始化
- void Init1602()
- uchar i=0;
- write_com(0x38);//屏幕初始化
- write_com(0x0c);//打開(kāi)顯示 無(wú)光標(biāo) 無(wú)光標(biāo)閃爍
- write_com(0x06);//當(dāng)讀或?qū)懸粋(gè)字符是指針后一一位
- write_com(0x01);//清屏
- write_com(0x80);//設(shè)置位置
- for(i=0;i<16;i++)
- write_data(Init1[i]); //顯示數(shù)組1的數(shù)據(jù)
- write_com(0x80+5);
- write_data(0xdf);//°
- write_com(0x80+10);
- write_com(0x80+15);
- write_com(0x80+0x40);//設(shè)置位置
- for(i=0;i<16;i++)
- write_data(Init2[i]); //顯示數(shù)組2的數(shù)據(jù)
- void Display_1602(yushe_wendu,yushe_yanwu,yushe_wendu_L,yushe_yanwu_L,c,temp)
- //設(shè)置最高溫度值
- write_com(0x80+13);
- write_data(0x30+yushe_wendu/10);
- write_data(0x30+yushe_wendu%10);
- //設(shè)置最低溫度值
- write_com(0x80+8);
- write_data(0x30+yushe_wendu_L/10);
- write_data(0x30+yushe_wendu_L%10);
- //設(shè)置最高濕度值
- write_com(0x80+0x40+13);
- write_data(0x30+yushe_yanwu%100/10);
- write_data(0x30+yushe_yanwu%10);
- //設(shè)置最低濕度值
- write_com(0x80+0x40+8);
- write_data(0x30+yushe_yanwu_L%100/10);
- write_data(0x30+yushe_yanwu_L%10);
- //時(shí)時(shí)溫度
- write_com(0x80+3);
- write_data(0x30+c%100/10);
- write_data(0x30+c%10);
- //時(shí)時(shí)濕度
- write_com(0x80+0x40+3);
- write_data(0x30+temp%100/10);
- write_data(0x30+temp%10);
- //按鍵處理函數(shù)
- void Key()
- //模式選擇
- if(Key1==0) //設(shè)置按鍵
- while(Key1==0);
- if(Mode>=5) Mode=0;
- else
- Mode++; //模式加一
- switch(Mode) //判斷模式的值
- case 1://調(diào)溫度上限值模式
- write_com(0x80+12);//為1時(shí) 溫度閥值的位置閃爍
- write_data('-');
- write_com(0x80+0x40+12);//為2時(shí) 濕度閥值的位置閃爍
- write_data('H');
- write_com(0x80+7);//為1時(shí) 溫度閥值的位置閃爍
- write_data('L');
- write_com(0x80+0x40+7);//為2時(shí) 濕度閥值的位置閃爍
- write_data('L');
- break; //執(zhí)行后跳出switch
- case 2://調(diào)濕度上限值模式
- write_data('-');
- write_data('H');
- write_data('L');
- write_data('L');
- break;
- case 3://調(diào)溫度下限值模式
- write_data('-');
- write_data('H');
- write_data('H');
- write_data('L');
- case 4://調(diào)濕度下限值模式
- write_data('-');
- write_data('H');
- write_data('H');
- write_data('L');
- break;
- case 5: //當(dāng)模式加到3時(shí)
- write_data('H');
- write_data('H');
- write_data('L');
- write_data('L');
- Mode=0; //模式清零
- break;
- if(Key2==0&&Mode!=0) //加按鍵只有在模式不等于0時(shí)有效
- while(Key2==0);
- switch(Mode) //加按鍵按下時(shí) 判斷當(dāng)前模式
- case 1: //模式為1時(shí)
- yushe_wendu++; //預(yù)設(shè)溫度上限值(閥值)加1
- if(yushe_wendu>=99) //加到大于等于99時(shí)
- yushe_wendu=99; //固定為99
- write_com(0x80+13); //選1602上顯示的位置
- write_data(0x30+yushe_wendu/10); //將溫度上限值數(shù)據(jù)分解開(kāi)送入液晶顯示
- break;
- case 2:
- yushe_humi++; //濕度上限值,同溫度上限值設(shè)置
- if(yushe_humi>=100)
- yushe_humi=100;
- write_data(0x30+yushe_humi%100/10);
- write_data(0x30+yushe_humi%10);
- break;
- case 3: //模式為3時(shí)
- yushe_wendu_L++; //溫度下限值,同溫度上限值設(shè)置
- if(yushe_wendu_L>=95)
- yushe_wendu_L=95;
- break;
- case 4:
- yushe_humi_L++; //濕度下限值,同溫度上限值設(shè)置
- if(yushe_humi_L>=90)
- yushe_humi_L=90;
- write_data(0x30+yushe_humi_L%100/10);
- write_data(0x30+yushe_humi_L%10);
- break;
- if(Key3==0&&Mode!=0)
- while(Key3==0);
- switch(Mode)
- case 1:
- if(yushe_wendu<=1) //當(dāng)溫度上限值減小到1時(shí)
- yushe_wendu=1; //固定為1
- yushe_wendu--; //預(yù)設(shè)溫度值減一
- break;
- case 2:
- if(yushe_humi<=1) //濕度上限值,同溫度上限值設(shè)置
- yushe_humi=1;
- yushe_humi--;
- break;
- if(yushe_wendu_L<=1) //溫度下限值,同溫度上限值設(shè)置
- yushe_wendu_L=1;
- yushe_wendu_L--;
- break;
- case 4:
- if(yushe_humi_L<=1) //濕度下限值,同溫度上限值設(shè)置
- yushe_humi_L=1;
- yushe_humi_L--;
- break;
- delay(10); //延時(shí)去抖動(dòng)
- DHT11相關(guān)命令
- void Delay1(uint j)
- uchar i;
- for(;j>0;j--)
- for(i=0;i<27;i++);
- void Delay_10us(void)
- uchar i;
- i--;
- i--;
- i--;
- i--;
- i--;
- i--;
- void COM(void)
- uchar i;
- for(i=0;i<8;i++)
- U8FLAG=2;
- while((!DHT11)&&U8FLAG++);
- Delay_10us();
- Delay_10us();
- Delay_10us();
- U8temp=0;
- if(DHT11)U8temp=1;
- U8FLAG=2;
- while((DHT11)&&U8FLAG++);
- //超時(shí)則跳出for循環(huán)
- if(U8FLAG==1)break;
- //判斷數(shù)據(jù)位是0還是1
- // 如果高電平高過(guò)預(yù)定0高電平值則數(shù)據(jù)位為 1
- U8comdata<<=1;
- U8comdata|=U8temp; //
- //-----濕度讀取子程序 ------------
- //----以下變量均為全局變量--------
- //----溫度高8位== U8T_data_H------
- //----溫度低8位== U8T_data_L------
- //----濕度高8位== U8RH_data_H-----
- //----濕度低8位== U8RH_data_L-----
- //----校驗(yàn) 8位 == U8checkdata-----
- //----調(diào)用相關(guān)子程序如下----------
- //---- Delay();, Delay_10us();,COM();
- void RH(void)
- //主機(jī)拉低18ms
- DHT11=0;
- Delay1(180);
- ET0 = 0;//關(guān)閉定時(shí)器0中斷
- DHT11=1;
- //總線由上拉電阻拉高 主機(jī)延時(shí)20us
- Delay_10us();
- Delay_10us();
- Delay_10us();
- Delay_10us();
- //主機(jī)設(shè)為輸入 判斷從機(jī)響應(yīng)信號(hào)
- DHT11=1;
- //判斷從機(jī)是否有低電平響應(yīng)信號(hào) 如不響應(yīng)則跳出,響應(yīng)則向下運(yùn)行
- if(!DHT11) //T !
- U8FLAG=2;
- //判斷從機(jī)是否發(fā)出 80us 的低電平響應(yīng)信號(hào)是否結(jié)束
- U8FLAG=2;
- //判斷從機(jī)是否發(fā)出 80us 的高電平,如發(fā)出則進(jìn)入數(shù)據(jù)接收狀態(tài)
- //數(shù)據(jù)接收狀態(tài)
- COM();
- U8RH_data_H_temp=U8comdata;
- COM();
- U8RH_data_L_temp=U8comdata;
- COM();
- U8T_data_H_temp=U8comdata;
- COM();
- U8T_data_L_temp=U8comdata;
- COM();
- U8checkdata_temp=U8comdata;
- DHT11=1;
- ET0 = 1;//開(kāi)啟定時(shí)器0中斷
- //數(shù)據(jù)校驗(yàn)
- U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
- if(U8temp==U8checkdata_temp)
- U8RH_data_H=U8RH_data_H_temp;
- U8RH_data_L=U8RH_data_L_temp;
- U8T_data_H=U8T_data_H_temp;
- U8T_data_L=U8T_data_L_temp;
- U8checkdata=U8checkdata_temp;
- /*****主函數(shù)*****/
- void main()
- uint i=0;
- Delay_Ms(100);//上電延時(shí)100ms,等待DHT11啟動(dòng)
- Init1602(); //調(diào)用初始化顯示函數(shù)
- U8T_data_H=30;
- U8RH_data_H=60;
- while(1) //進(jìn)入循環(huán)
- Key(); //調(diào)用按鍵函數(shù) 掃描按鍵
- if(Mode==0) //只有當(dāng)模式為0時(shí)才會(huì)執(zhí)行以下的閥值判斷部分
- if(i<1)
- i=10;
- RH();//溫濕度檢測(cè)
- i--;
- Display_1602(yushe_wendu,yushe_humi,yushe_wendu_L,yushe_humi_L,U8T_data_H,U8RH_data_H);
- //顯示預(yù)設(shè)溫度上限值,預(yù)設(shè)濕度上限值,預(yù)設(shè)溫度下限值,預(yù)設(shè)濕度下限值,當(dāng)前溫度值,當(dāng)前濕度值
- if(U8RH_data_H>=yushe_humi) //濕度值大于等于預(yù)設(shè)上限值時(shí)
- LED_humi=0; //濕度上限繼電器
- baojing=0; //蜂鳴器報(bào)警
- else if(U8RH_data_H<=yushe_humi_L) //濕度值小于等于預(yù)設(shè)值下限值時(shí)
- LED_humi_L=0; //濕度下限繼電器
- else //濕度值處于上限界限之間時(shí)
- LED_humi=1; //關(guān)掉濕度上限繼電器
- LED_humi_L=1; //關(guān)掉濕度下限繼電器
- if(U8T_data_H>=(yushe_wendu)) //溫度值大于等于預(yù)設(shè)上限值時(shí)
- baojing=0; //打開(kāi)蜂鳴器報(bào)警
- LED_wendu=0; //打開(kāi)溫度上限繼電器
- else if(U8T_data_H<=yushe_wendu_L) //溫度值小于等于預(yù)設(shè)值下限值時(shí)
- LED_wendu_L=0; //溫度下限繼電器
- else //溫度值處于上限界限之間時(shí)
- LED_wendu=1; //關(guān)閉溫度上限繼電器
- LED_wendu_L=1; //關(guān)閉溫度下限繼電器
- if(yushe_humi_L<U8RH_data_H&&U8RH_data_H<yushe_humi&&yushe_wendu_L<U8T_data_H&&U8T_data_H<yushe_wendu)
- //當(dāng)濕度和溫度都處于正常值時(shí) (&&:邏輯與,左右兩邊的表達(dá)式都成立(都為真,也就是1)時(shí),該if語(yǔ)句才成立)
- baojing=1; //停止報(bào)警
- else
