Altium Designer畫的交通燈模擬系統(tǒng)原理圖如下:(51hei附件中可下載工程文件)
- #include<reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit LED0=P1^0;//南北R
- sbit LED1=P1^1;//南北G
- sbit LED2=P1^2;//東西R
- sbit LED3=P1^3;//東西G
- sbit d1=P0^0;//數(shù)碼管位選
- sbit d2=P0^1;
- sbit d3=P0^2;
- sbit d4=P0^3;
- sbit Btton=P3^2;
- char timedao1;
- char timedao2;
- code unsigned char table[]=
- {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};//共陰數(shù)碼管 0-9
- void delayms(xms)
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- void Display()
- char h,l;
- h=timedao1/10;
- l=timedao1%10;
- d1=1;
- d2=0;
- d3=1;
- d4=1;
- P2=table[h];
- P2=table[l];
- delayms(10);
- d2=1;
- d1=0;
- h=timedao2/10;
- l=timedao2%10;
- P2=table[h];
- delayms(2);
- d3=1;
- d4=1;
- P2=table[h];
- delayms(2);
- d4=1;
- void timer0(void)interrupt 1 using 1
- static uchar count;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- count++;
- if(count==20)
- if(timedao1>=0)
- timedao1--;
- if(timedao2>=0)
- timedao2--;
- count=0;
- void main()
- int c;
- TMOD=0x01;
- EA=1; //CPU終端總控制位
- ET0=1;//定時器,計數(shù)器
- EX0=1;//外部中斷允許控制位
- IT0=1;
- TR0=1;
- while(1)
- timedao1=9;
- timedao2=4;
- while(timedao1>=0)
- LED3=0;
- LED0=0;//南北綠燈亮東西紅燈亮
- Display();
- for(c=0;c<11;c++)
- LED3=~LED3;
- LED0=~LED0;
- delayms(1000);
- timedao1=9;
- timedao2=4;
- LED2=0;
- LED1=0;
- Display();
- for(c=0;c<11;c++)
2018.06.04交通燈模擬.7z
(93.91 KB, 下載次數(shù): 41)
2021-6-10 21:17 上傳
