查看: 2212|回復(fù): 2
12864 按鍵顯示
ID:345165 發(fā)表于 2018-6-5 08:54 來自觸屏版 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#include "delay.h"
sbit RS = P2^4;
sbit RW = P2^5;
sbit E  = P2^6;
sbit RES = P2^3;
sbit PSB = P2^1;
sbit PAUSE = P3^0;
#define DataPort P0        //單片機(jī) P0<------> 液晶DB0-DB7
sbit KEY_ADD=P3^3;         //定義按鍵輸入端口
sbit KEY_DEC=P3^4;
unsigned char curr,currold;//全局變量,當(dāng)前箭頭位置
unsigned char code user16x16[]={ //箭頭圖片
0x00,0x00,0x20,0x00,0x30,0x00,0x38,0x00,0x3C,0x00,0x3E,0x00,0x3F,0x00,0x3F,0x80,
0x3F,0xC0,0x3F,0x80,0x3F,0x00,0x3E,0x00,0x3C,0x00,0x38,0x00,0x30,0x00,0x20,0x00,
unsigned char code *MainMenu[]=
{"  1.設(shè)置1"},
{"  2.設(shè)置2"},
{"  3.設(shè)置3"},
{"  4.設(shè)置4"},
{"  5.設(shè)置5"},
{"  6.設(shè)置6"},
{"  7.設(shè)置7"},
{"  8.設(shè)置8"},
{"  9.設(shè)置9"},
{"  10. 設(shè)置10"},
                    檢測忙位
void Check_Busy()
    RS=0;
    RW=1;
    E=1;
    DataPort=0xff;
    while((DataPort&0x80)==0x80);//忙則等待
    E=0;
                   寫命令
void Write_Cmd(unsigned char Cmd)
        Check_Busy();
        RS=0;
        RW=0;
        E=1;
        DataPort=Cmd;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                    寫數(shù)據(jù)
void Write_Data(unsigned char Data)
        Check_Busy();
        RS=1;
        RW=0;
        E=1;
        DataPort=Data;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                   液晶屏初始化
void Init_ST7920()
   DelayMs(40);           //大于40MS的延時程序
   PSB=1;                 //設(shè)置為8BIT并口工作模式
   DelayMs(1);            //延時
   RES=0;                 //復(fù)位
   DelayMs(1);            //延時
   RES=1;                 //復(fù)位置高
   DelayMs(10);
   Write_Cmd(0x30);       //選擇基本指令集
   DelayUs2x(50);         //延時大于100us
   Write_Cmd(0x30);       //選擇8bit數(shù)據(jù)流
   DelayUs2x(20);         //延時大于37us
   Write_Cmd(0x0c);       //開顯示(無游標(biāo)、不反白)
   Write_Cmd(0x01);       //清除顯示,并且設(shè)定地址指針為00H
   DelayMs(15);           //延時大于10ms
   Write_Cmd(0x06);       //指定在資料的讀取及寫入時,設(shè)定游標(biāo)的移動方向及指定顯示的移位,光標(biāo)從右向左加1位移動
                   用戶自定義字符
void CGRAM()
     int i;
     Write_Cmd(0x30);
     Write_Cmd(0x40);
     for(i=0;i<16;i++)
            Write_Data(user16x16[i*2]);
        Write_Data(user16x16[i*2+1]);
                   顯示用戶自定義字符
void DisplayCGRAM(unsigned char x,unsigned char y)
switch(y)
          case 1: Write_Cmd(0x80+x);break;
          case 2: Write_Cmd(0x90+x);break;
          case 3: Write_Cmd(0x88+x);break;
          case 4: Write_Cmd(0x98+x);break;
      default:break;
    Write_Data(00);
    Write_Data(00);
                   顯示字符串
x:橫坐標(biāo)值,范圍0~8
y:縱坐標(biāo)值,范圍1~4
void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s)
switch(y)
      default:break;
while(*s>0)
      Write_Data(*s);
      s++;
      DelayUs2x(50);
                      清屏
void ClrScreen()
   Write_Cmd(0x01);
   DelayMs(15);
                   顯示圖片
/*void LCD_PutGraphic(unsigned char code *img)
int i,j;
//顯示上半屏內(nèi)容設(shè)置
   for(i=0;i<32;i++)
      Write_Cmd(0x80 + i); //SET  垂直地址 VERTICAL ADD
      Write_Cmd(0x80);     //SET  水平地址 HORIZONTAL ADD
      for(j=0;j<16;j++)
         Write_Data(*img);
         img++;
//顯示下半屏內(nèi)容設(shè)置
   for(i=0;i<32;i++)
      Write_Cmd(0x88);     //SET 水平地址 HORIZONTAL ADD
      for(j=0;j<16;j++)
         Write_Data(*img);
         img++;
                 設(shè)置到繪圖模式
/*void SetGraphicMode()
   Write_Cmd(0x36);       //選擇8bit數(shù)據(jù)流 圖形模式
   DelayUs2x(20);
                 調(diào)用顯示更新
void DisplayUpdata(void)
    unsigned char num;
        ClrScreen();
        num=sizeof(MainMenu)/sizeof(MainMenu[0]);//判斷數(shù)組中數(shù)值個數(shù)
        if((0+(curr/4)*4)<num)
      LCD_PutString(0,1,MainMenu[0+(curr/4)*4]);
        else //如果超出數(shù)組最大元素,則寫空信息,不判斷此信息可能會出現(xiàn)亂碼
          LCD_PutString(0,1,"");
        if((1+(curr/4)*4)<num)
          LCD_PutString(0,2,MainMenu[1+(curr/4)*4]);
          LCD_PutString(0,2,"");
        if((2+(curr/4)*4)<num)
          LCD_PutString(0,3,MainMenu[2+(curr/4)*4]);
          LCD_PutString(0,3,"");
        if((3+(curr/4)*4)<num)
          LCD_PutString(0,4,MainMenu[3+(curr/4)*4]);
          LCD_PutString(0,4,"");
        DisplayCGRAM(0,curr%4+1);
                 主程序
main()
  Init_ST7920();   //初始化
  CGRAM();     //寫入自定義字符
  DisplayUpdata();
if(curr!=currold) //光標(biāo)位置變化,則更新顯示
    DisplayUpdata();
        currold=curr;
if(!KEY_ADD)  //如果檢測到低電平,說明按鍵按下
         DelayMs(10); //延時去抖,一般10-20ms
     if(!KEY_ADD)     //再次確認(rèn)按鍵是否按下,沒有按下則退出
        while(!KEY_ADD);//如果確認(rèn)按下按鍵等待按鍵釋放,沒有釋放則一直等待
                   if(curr<sizeof(MainMenu)/sizeof(MainMenu[0])-1)//判斷數(shù)組中數(shù)值個數(shù)
                          curr++;
if(!KEY_DEC)  //如果檢測到低電平,說明按鍵按下
     if(!KEY_DEC)     //再次確認(rèn)按鍵是否按下,沒有按下則退出
        while(!KEY_DEC);//如果確認(rèn)按下按鍵等待按鍵釋放,沒有釋放則一直等待
               if(curr>0)
                          curr--;
ID:308985 發(fā)表于 2018-6-29 16:19 來自觸屏版 | 只看該作者
有原理圖嗎?大佬
ID:76201 發(fā)表于 2018-7-31 18:35 | 只看該作者
這個程序我試過了 可以用,但是后面怎么實(shí)現(xiàn)翻頁呢?反白?還是清除顯示?多級菜單真不好做
