查看: 5538|回復(fù): 0
51單片機(jī) 4X4矩陣鍵盤(查表法)
ID:318620 發(fā)表于 2018-6-3 20:04 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
/*行線接P1.0-P1.3,列線接P1.4-P1.7。
根據(jù)掃描鍵盤返回的鍵值編碼查鍵值編碼表,從而得到鍵值并送數(shù)碼管顯示。
開機(jī)時(shí),數(shù)碼管顯示“-”。
當(dāng)鍵按下時(shí),數(shù)碼管顯示按下鍵的鍵值,蜂鳴器響一聲。*/
#include <reg52.h>
#include <intrins.h>
#define uint  unsigned int
sbit BEEP = P3^6;                  //蜂鳴器驅(qū)動(dòng)線
uchar  key;
unsigned char code disp_code[]={
              0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
              0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xbf};
unsigned char code key_code[]={
              0xee,0xde,0xbe,0x7e,0xed,0xdd,0xbd,0x7d,
              0xeb,0xdb,0xbb,0x7b,0xe7,0xd7,0xb7,0x77 };
  延時(shí)子函數(shù)
void delayms(uint ms)
   uchar t;
   while(ms--)
     for(t = 0; t < 120; t++);
  x*0.14MS 延時(shí)子函數(shù)
void delay0(uchar x)
   uchar i;
   while(x--)
     for (i = 0; i<13; i++) {;}
  蜂鳴器驅(qū)動(dòng)子函數(shù)
void beep()
  uchar i;
  for (i=0;i<180;i++)
    delay0(5);
    BEEP=!BEEP;       //BEEP取反
   BEEP=1;            //關(guān)閉蜂鳴器
   delayms(250);      //延時(shí)
鍵盤掃描子函數(shù)
uchar  keyscan()
   uchar  scan1,scan2,keycode,j;
   P1=0xf0;
   scan1=P1;
   if((scan1&0xf0)!=0xf0)           //判鍵是否按下
     delayms(30);                   //延時(shí)30ms
     scan1=P1;
     if((scan1&0xf0)!=0xf0)         //二次判鍵是否按下
        P1=0x0f;
        scan2=P1;
        keycode=scan1|scan2;         //組合成鍵編碼
        for(j=0;j<=15;j++)
           if(keycode== key_code[j])  //查表得鍵值
              key=j;
              return(key);
   else  P1=0xff;
   return (16);
  判鍵是否按下子函數(shù)
void  keydown()
   P1=0xf0;
   if((P1&0xf0)!=0xf0)
     keyscan();
     P0=disp_code[key];
     beep();
主函數(shù)
main()
   P0 = 0xbf;
   P2 = 0x7f;            //數(shù)碼管顯示"-"
    P1 = 0xff;
     keydown();
4X4矩陣鍵盤(查表法).rar
12.15 KB, 下載次數(shù): 23, 下載積分: 黑幣 -5
