查看: 1423|回復: 0
lCD1602程序
ID:343940 發表于 2018-6-3 13:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
sbit RS = P2^0;
sbit RW = P2^1;
sbit EN = P2^2;
void Delayms(uint ms)
        uchar i;
        while(ms--)
                 for(i=0;i<120;i++);
uchar Busy_Check()
        uchar LCD_Status;
        RS = 0;
        RW = 1;
        EN = 1;
        Delayms(1);
           LCD_Status = P0;
        EN = 0;
        return LCD_Status;
void Write_LCD_Command(uchar cmd)
        while((Busy_Check()&0x80)==0x80);
        RS = 0;
        RW = 0;
        EN = 0;
        P0 = cmd;
        EN = 1;
        Delayms(1);
        EN = 0;
void Write_LCD_Data(uchar dat)
        RS = 1;
        RW = 0;
        EN = 0;
        P0 = dat;
        EN = 1;
        Delayms(1);
        EN = 0;
void Initialize_LCD()
        Write_LCD_Command(0x38);
        Delayms(1);
        Write_LCD_Command(0x01);
        Delayms(1);
        Write_LCD_Command(0x06);
        Delayms(1);
        Write_LCD_Command(0x0c);
        Delayms(1);
void ShowString(uchar x,uchar y,uchar *str)
        uchar i = 0;
        if(y == 0)
                Write_LCD_Command(0x80 | x);
        if(y == 1)
                Write_LCD_Command(0xc0 | x);
        for(i=0;i<16;i++)
                 Write_LCD_Data(str[i]);
