#include <reg52.h>
#include "1602.h"
#include "dht.h"
//定義標(biāo)識(shí)
volatile bit FlagStartRH = 0; //開始溫濕度轉(zhuǎn)換標(biāo)志
//定義溫濕度傳感器用外部變量
extern U8 U8FLAG,k;
extern U8 U8count,U8temp;
extern U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
extern U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
extern U8 U8comdata;
extern U8 count, count_r;
U16 temp;
S16 temperature, humidity;
//定義變量
U16 RHCounter;
//定時(shí)器0初始化
void Timer0_Init()
ET0 = 1; //允許定時(shí)器0中斷
TMOD = 1; //定時(shí)器工作方式選擇
TL0 = 0x06;
TH0 = 0xf8; //定時(shí)器賦予初值
TR0 = 1; //啟動(dòng)定時(shí)器
//定時(shí)器0中斷
void Timer0_ISR (void) interrupt 1 using 0
TL0 = 0x06;
//每2秒鐘啟動(dòng)一次溫濕度轉(zhuǎn)換
RHCounter ++;
if (RHCounter >= 1000)
FlagStartRH = 1;
RHCounter = 0;
* 名稱 : Main()
* 功能 : 主函數(shù)
U16 i, j, testnum;
EA = 0;
Timer0_Init(); //定時(shí)器0初始化
EA = 1;
L1602_init();
L1602_string(1,1," Welcome to T&H ");
L1602_string(2,1,"Detection System! ");
//延時(shí)
for (i=0;i<1000;i++)
for (j=0;j<1000;j++)
//清屏
L1602_string(1,1," ");
L1602_string(2,1," ");
L1602_string(1,1,"Temperature: C");
L1602_string(2,1,"Humidity: %");
//溫濕度轉(zhuǎn)換標(biāo)志檢查
if (FlagStartRH == 1)
TR0 = 0;
testnum = RH();
FlagStartRH = 0;
TR0 = 1;
//讀出溫濕度,只取整數(shù)部分
humidity = U8RH_data_H;
temperature = U8T_data_H;
//顯示溫濕度
L1602_int(1,12,temperature);
L1602_int(2,12,humidity);
#ifndef _DHT_H_
#define _DHT_H_
#include <reg52.h>
typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 無符號(hào)8位整型變量 */
typedef signed char S8; /* defined for signed 8-bits integer variable 有符號(hào)8位整型變量 */
typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 無符號(hào)16位整型變量 */
typedef signed int S16; /* defined for signed 16-bits integer variable 有符號(hào)16位整型變量 */
typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 無符號(hào)32位整型變量 */
typedef signed long S32; /* defined for signed 32-bits integer variable 有符號(hào)32位整型變量 */
typedef float F32; /* single precision floating point variable (32bits) 單精度浮點(diǎn)數(shù)(32位長度) */
typedef double F64; /* double precision floating point variable (64bits) 雙精度浮點(diǎn)數(shù)(64位長度) */
sbit DATA = P1^7;
void Delay1(U16 );
void Delay_10us(void);
void COM(void);
U8 RH(void);
#endif
