查看: 4137|回復: 0
單片機中斷矩陣式按鍵仿真原理圖和匯編語言源碼
按下按鍵會有數字顯示和報警聲,按鍵松開報警聲取消,數字仍然顯示
模仿以前的手機按鍵
運用匯編語言
  1. ORG 0000H
  2.     AJMP  START
  3. ORG 0003H
  4.     AJMP PINT0
  5. ORG 0030H
  6. START:
  7. MOV SP,#5FH
  8. MOV 30H,#00H
  9. SETB IT0
  10. MOV IP,#01H
  11. SETB EA
  12. SETB EX0
  13. MAIN:MOV P2,#0FH
  14. LCALL SHOW
  15. SJMP MAIN
  16. ORG 0100H
  17. PINT0:PUSH ACC
  18. PUSH PSW
  19. SETB P1.7
  20. LCALL DELAY0
  21. CLR P1.7
  22. LCALL RDKEY
  23. POP PSW
  24. POP ACC
  25. RETI
  26. RDKEY:MOV P2,#0FH
  27. MOV A,P2
  28. ANL A,#0FH
  29. CJNE A,#0FH,XIAODOU
  30. AJMP RDEND
  31. XIAODOU:LCALL DELAY10MS
  32. MOV P2,#0FH
  33. MOV A,P2
  34. ANL A,#0FH
  35. CJNE A,#0FH,SCAN
  36. AJMP RDEND
  37. SCAN:MOV R4,#00H
  38. LINE0: MOV P2,#0EFH
  39. MOV A,P2
  40. ANL A,#0FH
  41. CJNE A,#0FH,GKEY
  42. INC R4
  43. LINE1:MOV P2,#0DFH
  44. MOV A,P2
  45. ANL A,#0FH
  46. CJNE A,#0FH,GKEY
  47. INC R4
  48. LINE2:MOV P2,#0BFH
  49. MOV A,P2
  50. ANL A,#0FH
  51. CJNE A,#0FH,GKEY
  52. INC R4
  53. LINE3:MOV P2,#7FH
  54. MOV A,P2
  55. ANL A,#0FH
  56. CJNE A,#0FH,GKEY
  57. INC R4
  58. GKEY:JNB ACC.0,NEXT
  59. INC R4
  60. INC R4
  61. INC R4
  62. INC R4
  63. RR A
  64. AJMP GKEY
  65. NEXT:MOV 30H,R4
  66. RDEND:RET
  67. SHOW:MOV A,30H
  68. MOV DPTR,#TAB
  69. MOVC A,@A+DPTR
  70. MOV P0,A
  71. LCALL DELAY10ms
  72. RET
  73. DELAY10ms:MOV R7,#25
  74. DELAY0:MOV TMOD,#01H
  75. MOV TL0,#0B0H
  76. MOV TH0,#3CH
  77. SETB TR0
  78. DELAY1:MOV R6,#200
  79. DJNZ R6,$
  80. DJNZ R7,DELAY1
  81. RET
  82. TAB:DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H
  83.     DB 80H,90H,88H,83H,0C6H,0A1H,86H,8EH
  84. END
中斷矩陣式按鍵.zip (53.8 KB, 下載次數: 15)
