UCOS擴展例程- UCOSIII任務(wù)內(nèi)建消息隊列
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "led.h"
- #include "lcd.h"
- #include "key.h"
- #include "pcf8574.h"
- #include "ltdc.h"
- #include "sdram.h"
- #include "malloc.h"
- #include "includes.h"
- //任務(wù)優(yōu)先級
- #define START_TASK_PRIO 3
- //任務(wù)堆棧大小
- #define START_STK_SIZE 128
- //任務(wù)控制塊
- OS_TCB StartTaskTCB;
- //任務(wù)堆棧
- CPU_STK START_TASK_STK[START_STK_SIZE];
- //任務(wù)函數(shù)
- void start_task(void *p_arg);
- //任務(wù)優(yōu)先級
- #define MAIN_TASK_PRIO 4
- //任務(wù)堆棧大小
- #define MAIN_STK_SIZE 128
- //任務(wù)控制塊
- OS_TCB Main_TaskTCB;
- //任務(wù)堆棧
- CPU_STK MAIN_TASK_STK[MAIN_STK_SIZE];
- void main_task(void *p_arg);
- //任務(wù)優(yōu)先級
- #define MSGDIS_TASK_PRIO 6
- //任務(wù)堆棧
- #define MSGDIS_STK_SIZE 128
- //任務(wù)控制塊
- OS_TCB Msgdis_TaskTCB;
- //任務(wù)堆棧
- CPU_STK MSGDIS_TASK_STK[MSGDIS_STK_SIZE];
- //任務(wù)函數(shù)
- void msgdis_task(void *p_arg);
- //LCD刷屏?xí)r使用的顏色
- int lcd_discolor[14]={ WHITE, BLACK, BLUE, BRED,
- GRED, GBLUE, RED, MAGENTA,
- GREEN, CYAN, YELLOW,BROWN,
- BRRED, GRAY };
- #define TASK_Q_NUM 4 //發(fā)任務(wù)內(nèi)建消息隊列的長度
- ////////////////////////定時器////////////////////////////////
- u8 tmr1sta=0; //標(biāo)記定時器的工作狀態(tài)
- OS_TMR tmr1; //定義一個定時器
- void tmr1_callback(void *p_tmr,void *p_arg); //定時器1回調(diào)函數(shù)
- //加載主界面
- void ucos_load_main_ui(void)
- POINT_COLOR = RED;
- LCD_ShowString(10,10,200,16,16,"Apollo STM32F4/F7");
- LCD_ShowString(10,30,200,16,16,"UCOSIII Examp 11-2");
- LCD_ShowString(10,50,200,16,16,"Task Queue");
- LCD_ShowString(10,70,220,16,16,"KEY_UP:Tmr1");
- LCD_ShowString(10,90,200,16,16,"2016/1/21");
- POINT_COLOR = BLACK;
- LCD_DrawLine(0,107,239,107); //畫線
- LCD_ShowString(30,130,100,16,16,"tmr1 state:");
- LCD_ShowString(30,170,120,16,16,"Task_QMsg Size:");
- LCD_ShowString(30,210,120,16,16,"Task_QMsg rema:");
- LCD_ShowString(30,250,100,16,16,"Task_QMsg:");
- POINT_COLOR = BLUE;
- LCD_ShowString(40,150,100,16,16,"TMR1 STOP! ");
- //查詢DATA_Msg消息隊列中的總隊列數(shù)量和剩余隊列數(shù)量
- void check_msg_queue(u8 *p)
- CPU_SR_ALLOC();
- u8 msgq_remain_size; //消息隊列剩余大小
- OS_CRITICAL_ENTER(); //進(jìn)入臨界段
- msgq_remain_size =Msgdis_TaskTCB.MsgQ.NbrEntriesSize-Msgdis_TaskTCB.MsgQ.NbrEntries;
- p = mymalloc(SRAMIN,20); //申請內(nèi)存
- sprintf((char*)p,"Total Size:%d",Msgdis_TaskTCB.MsgQ.NbrEntriesSize); //顯示DATA_Msg消息隊列總的大小
- LCD_ShowString(40,190,100,16,16,p);
- sprintf((char*)p,"Remain Size:%d",msgq_remain_size); //顯示DATA_Msg剩余大小
- LCD_ShowString(40,230,100,16,16,p);
- myfree(SRAMIN,p); //釋放內(nèi)存
- OS_CRITICAL_EXIT(); //退出臨界段
- int main(void)
- OS_ERR err;
- CPU_SR_ALLOC();
- Stm32_Clock_Init(360,25,2,8); //設(shè)置時鐘,180Mhz
- HAL_Init(); //初始化HAL庫
- delay_init(180); //初始化延時函數(shù)
- uart_init(115200); //初始化USART
- LED_Init(); //初始化LED
- KEY_Init(); //初始化按鍵
- PCF8574_Init(); //初始化PCF8974
- SDRAM_Init(); //初始化SDRAM
- LCD_Init(); //初始化LCD
- my_mem_init(SRAMIN); //初始化內(nèi)部內(nèi)存池
- ucos_load_main_ui(); //加載主UI
- OSInit(&err); //初始化UCOSIII
- OS_CRITICAL_ENTER(); //進(jìn)入臨界區(qū)
- //創(chuàng)建開始任務(wù)
- OSTaskCreate((OS_TCB * )&StartTaskTCB, //任務(wù)控制塊
- (CPU_CHAR * )"start task", //任務(wù)名字
- (OS_TASK_PTR )start_task, //任務(wù)函數(shù)
- (void * )0, //傳遞給任務(wù)函數(shù)的參數(shù)
- (OS_PRIO )START_TASK_PRIO, //任務(wù)優(yōu)先級
- (CPU_STK * )&START_TASK_STK[0], //任務(wù)堆棧基地址
- (CPU_STK_SIZE)START_STK_SIZE/10, //任務(wù)堆棧深度限位
- (CPU_STK_SIZE)START_STK_SIZE, //任務(wù)堆棧大小
- (OS_MSG_QTY )0, //任務(wù)內(nèi)部消息隊列能夠接收的最大消息數(shù)目,為0時禁止接收消息
- (OS_TICK )0, //當(dāng)使能時間片輪轉(zhuǎn)時的時間片長度,為0時為默認(rèn)長度,
- (void * )0, //用戶補充的存儲區(qū)
- (OS_OPT )OS_OPT_TASK_STK_CHK|OS_OPT_TASK_STK_CLR|OS_OPT_TASK_SAVE_FP, //任務(wù)選項,為了保險起見,所有任務(wù)都保存浮點寄存器的值
- (OS_ERR * )&err); //存放該函數(shù)錯誤時的返回值
- OS_CRITICAL_EXIT(); //退出臨界區(qū)
- OSStart(&err); //開啟UCOSIII
- while(1)
- //開始任務(wù)函數(shù)
- OS_ERR err;
- CPU_SR_ALLOC();
- p_arg = p_arg;
- CPU_Init();
- #if OS_CFG_STAT_TASK_EN > 0u
- OSStatTaskCPUUsageInit(&err); //統(tǒng)計任務(wù)
- #endif
- #ifdef CPU_CFG_INT_DIS_MEAS_EN //如果使能了測量中斷關(guān)閉時間
- CPU_IntDisMeasMaxCurReset();
- #endif
- #if OS_CFG_SCHED_ROUND_ROBIN_EN //當(dāng)使用時間片輪轉(zhuǎn)的時候
- //使能時間片輪轉(zhuǎn)調(diào)度功能,設(shè)置默認(rèn)的時間片長度
- OSSchedRoundRobinCfg(DEF_ENABLED,1,&err);
- #endif
- //創(chuàng)建定時器1
- OSTmrCreate((OS_TMR *)&tmr1, //定時器1
- (CPU_CHAR *)"tmr1", //定時器名字
- (OS_TICK )0, //0ms
- (OS_TICK )50, //50*10=500ms
- (OS_OPT )OS_OPT_TMR_PERIODIC, //周期模式
- (OS_TMR_CALLBACK_PTR)tmr1_callback,//定時器1回調(diào)函數(shù)
- (void *)0, //參數(shù)為0
- (OS_ERR *)&err); //返回的錯誤碼
- //創(chuàng)建主任務(wù)
- OSTaskCreate((OS_TCB * )&Main_TaskTCB,
- (CPU_CHAR * )"Main task",
- (OS_TASK_PTR )main_task,
- (void * )0,
- (OS_PRIO )MAIN_TASK_PRIO,
- (CPU_STK * )&MAIN_TASK_STK[0],
- (CPU_STK_SIZE)MAIN_STK_SIZE/10,
- (CPU_STK_SIZE)MAIN_STK_SIZE,
- (OS_MSG_QTY )0,
- (OS_TICK )0,
- (void * )0,
- (OS_ERR * )&err);
- //創(chuàng)建MSGDIS任務(wù)
- OSTaskCreate((OS_TCB * )&Msgdis_TaskTCB,
- (CPU_CHAR * )"Msgdis task",
- (OS_TASK_PTR )msgdis_task,
- (void * )0,
- (OS_PRIO )MSGDIS_TASK_PRIO,
- (CPU_STK * )&MSGDIS_TASK_STK[0],
- (CPU_STK_SIZE)MSGDIS_STK_SIZE/10,
- (CPU_STK_SIZE)MSGDIS_STK_SIZE,
- (OS_MSG_QTY )TASK_Q_NUM, //任務(wù)Msgdis_task需要使用內(nèi)建消息隊列,消息隊列長度為4
- (OS_TICK )0,
- (void * )0,
- (OS_ERR * )&err);
- OSTaskDel((OS_TCB*)0,&err); //刪除start_task任務(wù)自身
- //定時器1的回調(diào)函數(shù)
- u8 *pbuf;
- static u8 msg_num;
- OS_ERR err;
- pbuf = mymalloc(SRAMIN,10); //申請10個字節(jié)
- if(pbuf) //申請內(nèi)存成功
- msg_num++;
- sprintf((char*)pbuf,"ALIENTEK %d",msg_num);
- //發(fā)送消息
- OSTaskQPost((OS_TCB* )&Msgdis_TaskTCB, //向任務(wù)Msgdis發(fā)送消息
- (void* )pbuf,
- (OS_MSG_SIZE)10,
- (OS_OPT )OS_OPT_POST_FIFO,
- (OS_ERR* )&err);
- if(err != OS_ERR_NONE)
- myfree(SRAMIN,pbuf); //釋放內(nèi)存
- OSTmrStop(&tmr1,OS_OPT_TMR_NONE,0,&err); //停止定時器1
- tmr1sta = !tmr1sta;
- //主任務(wù)的任務(wù)函數(shù)
- u8 key,num;
- OS_ERR err;
- u8 *p;
- while(1)
- key = KEY_Scan(0); //掃描按鍵
- if(key==WKUP_PRES)
- if(tmr1sta)
- OSTmrStart(&tmr1,&err);
- LCD_ShowString(40,150,100,16,16,"TMR1 START!");
- else
- num++;
- if(num%10==0) check_msg_queue(p);//檢查DATA_Msg消息隊列的容量
- if(num==50)
- num=0;
- LED0=!LED0;
- OSTimeDlyHMSM(0,0,0,10,OS_OPT_TIME_PERIODIC,&err); //延時10ms
- //顯示消息隊列中的消息
- u8 *p;
- OS_MSG_SIZE size;
- OS_ERR err;
- while(1)
- //請求消息
- p=OSTaskQPend((OS_TICK )0,
- (OS_OPT )OS_OPT_PEND_BLOCKING,
- (OS_MSG_SIZE* )&size,
- (CPU_TS* )0,
- (OS_ERR* )&err );
- LCD_ShowString(40,270,100,16,16,p);
- OSTimeDlyHMSM(0,0,1,0,OS_OPT_TIME_PERIODIC,&err); //延時1s
UCOS擴展例程- UCOSIII任務(wù)內(nèi)建消息隊列.rar
(1.29 MB, 下載次數(shù): 32)
2018-5-29 22:16 上傳
下載積分: 黑幣 -5
