stm32f4xxDAC實(shí)驗(yàn)代碼
實(shí)驗(yàn)現(xiàn)象:
本實(shí)驗(yàn)利用按鍵(KEY1/KEY_UP兩個(gè)按鍵,或USMART)控制STM32F4內(nèi)部DAC模塊的通道1來輸出電壓,通過ADC1的
通道5采集DAC的輸出電壓,在LCD模塊上面顯示ADC獲取到的電壓值以及DAC的設(shè)定輸出電壓值等信息。同時(shí)可以通
過usmart調(diào)用Dac1_Set_Vol函數(shù),來直接設(shè)置DAC輸出電壓。
注意事項(xiàng):
1,4.3寸和7寸屏需要比較大電流,USB供電可能不足,請(qǐng)用外部電源適配器(推薦外接12V 1A電源).
2,本例程在LCD_Init函數(shù)里面(在ILI93xx.c),用到了printf,如果不初始化串口1,將導(dǎo)致液晶無法顯示!!
3,ADC和DAC的參考電壓默認(rèn)通過P7連接在VDDA上面(3.3V),所以默認(rèn)參考電壓是3.3V
4,通過跳線帽短接多功能接口(P12)的ADC和DAC,即可實(shí)現(xiàn)自測(cè)試(AD讀取DA值,顯示在LCD上)
單片機(jī)源程序如下:
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "led.h"
- #include "lcd.h"
- #include "adc.h"
- #include "dac.h"
- #include "key.h"
- int main(void)
- u16 adcx;
- float temp;
- u8 t=0;
- u16 dacval=0;
- u8 key;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級(jí)分組2
- delay_init(168); //初始化延時(shí)函數(shù)
- uart_init(115200); //初始化串口波特率為115200
- LED_Init(); //初始化LED
- LCD_Init(); //LCD初始化
- Adc_Init(); //adc初始化
- KEY_Init(); //按鍵初始化
- Dac1_Init(); //DAC通道1初始化
- POINT_COLOR=RED;
- LCD_ShowString(30,50,200,16,16,"Explorer STM32F4");
- LCD_ShowString(30,70,200,16,16,"DAC TEST");
- LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
- LCD_ShowString(30,110,200,16,16,"2014/5/6");
- LCD_ShowString(30,130,200,16,16,"WK_UP:+ KEY1:-");
- POINT_COLOR=BLUE;//設(shè)置字體為藍(lán)色
- LCD_ShowString(30,150,200,16,16,"DAC VAL:");
- LCD_ShowString(30,170,200,16,16,"DAC VOL:0.000V");
- LCD_ShowString(30,190,200,16,16,"ADC VOL:0.000V");
- DAC_SetChannel1Data(DAC_Align_12b_R,dacval);//初始值為0
- while(1)
- t++;
- key=KEY_Scan(0);
- if(key==WKUP_PRES)
- if(dacval<4000)dacval+=200;
- DAC_SetChannel1Data(DAC_Align_12b_R, dacval);//設(shè)置DAC值
- }else if(key==2)
- if(dacval>200)dacval-=200;
- else dacval=0;
- if(t==10||key==KEY1_PRES||key==WKUP_PRES) //WKUP/KEY1按下了,或者定時(shí)時(shí)間到了
- adcx=DAC_GetDataOutputValue(DAC_Channel_1);//讀取前面設(shè)置DAC的值
- LCD_ShowxNum(94,150,adcx,4,16,0); //顯示DAC寄存器值
- temp=(float)adcx*(3.3/4096); //得到DAC電壓值
- adcx=temp;
- LCD_ShowxNum(94,170,temp,1,16,0); //顯示電壓值整數(shù)部分
- temp-=adcx;
- temp*=1000;
- LCD_ShowxNum(110,170,temp,3,16,0X80); //顯示電壓值的小數(shù)部分
- adcx=Get_Adc_Average(ADC_Channel_5,10); //得到ADC轉(zhuǎn)換值
- temp=(float)adcx*(3.3/4096); //得到ADC電壓值
- adcx=temp;
- LCD_ShowxNum(94,190,temp,1,16,0); //顯示電壓值整數(shù)部分
- temp-=adcx;
- temp*=1000;
- LCD_ShowxNum(110,190,temp,3,16,0X80); //顯示電壓值的小數(shù)部分
- LED0=!LED0;
- t=0;
- delay_ms(10);
DAC實(shí)驗(yàn).zip
(545.31 KB, 下載次數(shù): 8)
2018-5-28 21:39 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
