查看: 1346|回復: 0
單片機練習矩陣鍵盤
ID:339504 發表于 2018-5-28 08:57 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#define        uint  unsigned int
sbit DU = P2^6;
sbit WE = P2^7;
uchar num;
uchar code table[] = {
    0x3f,0x06,0x5b,0x4f,
    0x66,0x6d,0x7d,0x07,
    0x7f,0x6f,0x77,0x7c,
    0x39,0x5e,0x79,0x71        };
void delay(uint x)    //延時 x ms
    uint i,j;
    for(i = x;i > 0;i--)
        for(j = 110;j > 0;j--);
void display(uchar temp)
        DU = 1;
        P0 = table[temp];
        DU = 0;
        P0 = 0xff;
        WE = 1;
        P0 = 0x00;
        WE = 0;
        delay(500);
        WE = 1;                                //打開U2鎖存器
        P0 = 0xc0;                        //送入位選信號
        WE = 0;
                display(num);
                num++;
                if(num == 16)
                        num = 0;
                delay(500);
