后驅+舵機
- #include "led.h"
- #include "delay.h"
- #include "key.h"
- #include "sys.h"
- #include "usart.h"
- #include "timer.h"
- u8 count;
- u8 jd;
- u8 flag,com;
- u16 t=1000;
- //const u8 TEXT_Buffer[]="OK";
- #define IN5 PCout(1)
- #define IN6 PCout(2)
- void run(void);
- void backrun(void);
- void stoprun(void);
- void leftrun(void);
- void rightrun(void);
- int main(void)
- u16 len;
- u16 t;
- u16 times=0;
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //使能PB,PE端口時鐘
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //LED0-->PB.5 端口配置
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度為50MHz
- GPIO_Init(GPIOC, &GPIO_InitStructure); //根據設定參數初始化GPIOB.5
- GPIO_SetBits(GPIOC,GPIO_Pin_1); //PB.5 輸出高
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //LED1-->PE.5 端口配置, 推挽輸出
- GPIO_Init(GPIOC, &GPIO_InitStructure); //推挽輸出 ,IO口速度為50MHz
- GPIO_SetBits(GPIOC,GPIO_Pin_2);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //LED0-->PB.5 端口配置
- GPIO_SetBits(GPIOC,GPIO_Pin_0);
- jd = 3;
- count = 0;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
- uart_init(9600);
- LED_Init();
- delay_init();
- TIM3_Int_Init(4,7199);
- while(1)
- times++;
- if(times%50==0)LED1=!LED1;
- delay_ms(10);
- if(USART_RX_STA&0x8000)
- LED3 = !LED3;
- com = USART_RX_BUF[0];
- len=USART_RX_STA&0x3fff;
- flag = 1;
- USART_RX_STA=0;
- if(flag == 1)
- switch(com)
- case '1':
- run();
- LED4 = !LED4;
- for(t=0;t<len;t++)
- USART_SendData(USART1, USART_RX_BUF[t]);//向串口1發送數據
- while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待發送結束
- break;
- case '2':
- backrun();
- break;
- case '3':
- stoprun();
- break;
- case '4':
- leftrun();
- break;
- case '5':
- rightrun();
- break;
- default:break;
- flag = 0;
- void run(void)
- IN5 = 1;
- IN6 = 0;
- IN5 = 0;
- IN6 = 1;
- IN5 = 0;
- IN6 = 0;
- jd++;
- count = 0;
- if (jd == 6)
- jd = 5;
- jd--;
- count = 0;
- if (jd == 0)
- jd = 1;
car.rar
(280.33 KB, 下載次數: 25)
2018-5-24 03:55 上傳
下載積分: 黑幣 -5
