查看: 4085|回復: 1
Arduino智能車入門程序
ID:336773 發表于 2018-5-23 19:47 | 顯示全部樓層 |閱讀模式
//引腳定義
const int left_Forward_PWM_Pin  = 3; //左電機正轉控制引腳
const int left_Backward_PWM_pin = 5; //左電機反轉控制引腳
const int right_Forward_PWM_Pin  = 6; //右電機正轉控制引腳
const int right_Backward_PWM_pin = 9; //右電機正轉控制引腳
const int AD_Left_Pin  = A0; //左電磁傳感器AD引腳
const int AD_Right_Pin = A1; //右電磁傳感器AD引腳
int pos; //傳感器位置變量
int speed_Forward,left_speed_Forward,right_speed_Forward; //中心速度占空比、左、右電機占空比
void setup()
  Serial.begin(9600);  //串口設置,用于輸出,波特率9600
  pinMode(left_Forward_PWM_Pin, OUTPUT);  //配置各電機控制引腳為輸出
  pinMode(left_Backward_PWM_pin, OUTPUT);
  pinMode(right_Forward_PWM_Pin, OUTPUT);
  pinMode(right_Backward_PWM_pin, OUTPUT);
  analogWrite(left_Forward_PWM_Pin, 0);   //初始化各電機正轉占空比, 0為停止
  analogWrite(left_Backward_PWM_pin, 0);
  analogWrite(right_Forward_PWM_Pin, 0);
  analogWrite(right_Backward_PWM_pin, 0);
void loop()
  DirectionControl(); //方向檢測
  //根據方向量pos控制左右輪差速,當pos=0時小車直走,pos<0時左拐,pos>0時右拐
  left_speed_Forward  = speed_Forward + pos ;     //左輪
  right_speed_Forward = speed_Forward - pos + 10; //右輪, +10 為左右輪固有速度差補償
  //限制電機PWM控制輸出的極值(0<PWM<255)
  if(left_speed_Forward<20){left_speed_Forward=20;}
  if(left_speed_Forward>220){left_speed_Forward=220;}
  if(right_speed_Forward<20){right_speed_Forward=20;}
  if(right_speed_Forward>220){right_speed_Forward=220;}
  //設置電機正轉占空比
  analogWrite(left_Forward_PWM_Pin, left_speed_Forward);    //左電機
  analogWrite(right_Forward_PWM_Pin, right_speed_Forward);  //左電機
  delay(33); //延時33ms
void DirectionControl() //方向檢測函數
  static int AD_Left, AD_Right = 0; //左右電磁傳感器AD值
  static float posTemp; //位置臨時變量,為了提高精度,采用浮點型
  static float error,last_error=0.0;
  AD_Left  = analogRead(AD_Left_Pin);   //讀左電磁傳感器AD值
  AD_Right = analogRead(AD_Right_Pin);  //讀右電磁傳感器AD值H
  Serial.print(AD_Left); //串口輸出,調試用
  Serial.print(",");
  Serial.println(AD_Right);
  if(AD_Left+AD_Right>50) //當左右電磁傳感器AD值之和較大時
  //說明:如果左右電磁傳感器AD值之和比較小,則說明傳感器偏離太遠,保持之前的舵機角度
    error=AD_Left-AD_Right;
    if(last_error==0)
    last_error=error;
    posTemp=(last_error+error)/2;
    last_error=error;
    posTemp /=(AD_Left+AD_Right); //除以和值,為相對位置
    posTemp = 0 - posTemp*145; //轉換成電磁線位置控制占空比(浮點),這里 *100 為比例值,值越大轉向越靈敏
    pos = int(posTemp); //位置值取整
    speed_Forward = 265; //正常前進速度
  else if(AD_Left+AD_Right<10) //如果當左右電磁傳感器AD值之和特別小,則說明已經沖出賽道較遠,改為蝸牛速
    speed_Forward = 0;  //蝸牛速
ID:1 發表于 2018-5-24 06:01 | 顯示全部樓層
原理圖能分享一下嗎?
