#include <reg52.h>
uchar n='0',num0=0,num1=0;
char zuo_pwm=35,you_pwm=35 ;
sbit zuo1=P0^0;//in1
sbit zuo2=P0^1;//in2
sbit you1=P0^2;
sbit you2=P0^3;
sbit ENA=P0^4;
sbit ENB=P0^5;
/* 函數功能:設置串口*/
void init() //time0
TMOD=0x21;
SCON=0x50;
TMOD &= 0xF0; //設置定時器模式
TMOD |= 0x01; //設置定時器模式
TL0 = 0x91; //設置定時初值
TH0 = 0xFF; //設置定時初值
TH1=0xfd;
TL1=0xfd;
EA=1; //打開總中斷
ET0=1; //打開定時器0中斷允許
TR1=1; //定時器1開始計時
TR0=1; //定時器0開始計時
ES=1; //打開接收中斷
void qian ()
zuo_pwm=17;
you_pwm=17;
zuo1=1;
zuo2=0;
you1=1;
you2=0;
void jiansu () //智能燈熄滅
zuo_pwm=8;
you_pwm=8;
zuo1=1;
zuo2=0;
you1=1;
you2=0;
// zuo1=0;
// zuo2=0;
// you1=0;
// you2=0;
//zuo_pwm=0;
//you_pwm=0;
void jiasu ()
zuo_pwm=35;
you_pwm=35;
zuo1=1;
zuo2=0;
you1=1;
you2=0;
void hou () //智能燈1/3亮度
zuo_pwm=17;
you_pwm=17;
zuo1=0;
zuo2=1;
you1=0;
you2=1;
void turnleft () //智能燈2/3亮度
zuo_pwm = 13;
you_pwm = 16;
zuo1=1;
zuo2=0;
you1=1;
you2=0;
void turnright ()
zuo_pwm = 16;
you_pwm = 13;
zuo1=1;
zuo2=0;
you1=1;
you2=0;
void stop ()
zuo1=0;
zuo2=0;
you1=0;
you2=0;
void zhuandong ()
zuo_pwm=35;
you_pwm=35;
zuo1=1;
zuo2=0;
you1=0;
you2=1;
void zhuandong_jian ()
zuo_pwm=12;
you_pwm=12;
zuo1=1;
zuo2=0;
you1=0;
you2=1;
void main ()
init (); //初始化
while (1)
switch (n) //藍牙控制
case '2':qian (); break;
case '3':jiansu (); break;
case '4':jiasu (); break;
case '5':hou (); break;
case '6':turnleft (); break;
case '7':turnright (); break;
case '8':zhuandong (); break;
case '9':zhuandong_jian (); break;
case '0':stop (); break;
default:break;
/* 函數功能:設置串口*/
void UART_SER()interrupt 4
if (RI)
RI=0;
n=SBUF;
TI=1;
SBUF=n;
if (TI)
TI=0;
//定時器0中斷函數
void Timer1Interrupt(void) interrupt 1
//PWM調占空比
num0++;
num0++;
num1++;
if(num0<=zuo_pwm)
{ENA=1;}
ENA=0;
if(num0==40)
ENA=~ENA;
num0=0;
if(num1<=you_pwm)
ENB=1;
ENB=0;
if(num1==40)
{ENB=~ENB;num1=0;}
