查看: 4502|回復: 2
BMP180氣壓傳感器arduino與51單片機源碼及數據手冊下載
網上找來的,需要的可以看一看
arduino源程序如下:
  1. //Arduino 1.0+ Only
  2. //Arduino 1.0+ Only
  3. /*Based largely on code by  Jim Lindblom
  4. Get pressure, altitude, and temperature from the BMP085.
  5. Serial.print it out at 9600 baud to serial monitor.
  6. */
  7. #include <Wire.h>
  8. #define BMP085_ADDRESS 0x77  // I2C address of BMP085
  9. const unsigned char OSS = 0;  // Oversampling Setting
  10. // Calibration values
  11. int ac1;
  12. int ac2;
  13. int ac3;
  14. unsigned int ac4;
  15. unsigned int ac5;
  16. unsigned int ac6;
  17. int b1;
  18. int b2;
  19. int mb;
  20. int mc;
  21. int md;
  22. // b5 is calculated in bmp085GetTemperature(...), this variable is also used in bmp085GetPressure(...)
  23. // so ...Temperature(...) must be called before ...Pressure(...).
  24. long b5;
  25. void setup(){
  26.   Serial.begin(9600);
  27.   Wire.begin();
  28.   bmp085Calibration();
  29. }
  30. void loop()
  31. {
  32.   float temperature = bmp085GetTemperature(bmp085ReadUT()); //MUST be called first
  33.   float pressure = bmp085GetPressure(bmp085ReadUP());
  34.   float atm = pressure / 101325; // "standard atmosphere"
  35.   float altitude = calcAltitude(pressure); //Uncompensated caculation - in Meters
  36.   Serial.print("Temperature: ");
  37.   Serial.print(temperature, 2); //display 2 decimal places
  38.   Serial.println("deg C");
  39.   Serial.print("Pressure: ");
  40.   Serial.print(pressure, 0); //whole number only.
  41.   Serial.println(" Pa");
  42.   Serial.print("Standard Atmosphere: ");
  43.   Serial.println(atm, 4); //display 4 decimal places
  44.   Serial.print("Altitude: ");
  45.   Serial.print(altitude, 2); //display 2 decimal places
  46.   Serial.println(" M");
  47.   Serial.println();//line break
  48.   delay(1000); //wait a second and get values again.
  49. }
  50. // Stores all of the bmp085's calibration values into global variables
  51. // Calibration values are required to calculate temp and pressure
  52. // This function should be called at the beginning of the program
  53. void bmp085Calibration()
  54. {
  55.   ac1 = bmp085ReadInt(0xAA);
  56.   ac2 = bmp085ReadInt(0xAC);
  57.   ac3 = bmp085ReadInt(0xAE);
  58.   ac4 = bmp085ReadInt(0xB0);
  59.   ac5 = bmp085ReadInt(0xB2);
  60.   ac6 = bmp085ReadInt(0xB4);
  61.   b1 = bmp085ReadInt(0xB6);
  62.   b2 = bmp085ReadInt(0xB8);
  63.   mb = bmp085ReadInt(0xBA);
  64.   mc = bmp085ReadInt(0xBC);
  65.   md = bmp085ReadInt(0xBE);
  66. }
  67. // Calculate temperature in deg C
  68. float bmp085GetTemperature(unsigned int ut){
  69.   long x1, x2;
  70.   x1 = (((long)ut - (long)ac6)*(long)ac5) >> 15;
  71.   x2 = ((long)mc << 11)/(x1 + md);
  72.   b5 = x1 + x2;
  73.   float temp = ((b5 + 8)>>4);
  74.   temp = temp /10;
  75.   return temp;
  76. }
  77. // Calculate pressure given up
  78. // calibration values must be known
  79. // b5 is also required so bmp085GetTemperature(...) must be called first.
  80. // Value returned will be pressure in units of Pa.
  81. long bmp085GetPressure(unsigned long up){
  82.   long x1, x2, x3, b3, b6, p;
  83.   unsigned long b4, b7;
  84.   b6 = b5 - 4000;
  85.   // Calculate B3
  86.   x1 = (b2 * (b6 * b6)>>12)>>11;
  87.   x2 = (ac2 * b6)>>11;
  88.   x3 = x1 + x2;
  89.   b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
  90.   // Calculate B4
  91.   x1 = (ac3 * b6)>>13;
  92.   x2 = (b1 * ((b6 * b6)>>12))>>16;
  93.   x3 = ((x1 + x2) + 2)>>2;
  94.   b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
  95.   b7 = ((unsigned long)(up - b3) * (50000>>OSS));
  96.   if (b7 < 0x80000000)
  97.     p = (b7<<1)/b4;
  98.   else
  99.     p = (b7/b4)<<1;
  100.   x1 = (p>>8) * (p>>8);
  101.   x1 = (x1 * 3038)>>16;
  102.   x2 = (-7357 * p)>>16;
  103.   p += (x1 + x2 + 3791)>>4;
  104.   long temp = p;
  105.   return temp;
  106. }
  107. // Read 1 byte from the BMP085 at 'address'
  108. char bmp085Read(unsigned char address)
  109. {
  110.   unsigned char data;
  111.   Wire.beginTransmission(BMP085_ADDRESS);
  112.   Wire.write(address);
  113.   Wire.endTransmission();
  114.   Wire.requestFrom(BMP085_ADDRESS, 1);
  115.   while(!Wire.available())
  116.     ;
  117.   return Wire.read();
  118. }
  119. // Read 2 bytes from the BMP085
  120. // First byte will be from 'address'
  121. // Second byte will be from 'address'+1
  122. int bmp085ReadInt(unsigned char address)
  123. {
  124.   unsigned char msb, lsb;
  125.   Wire.beginTransmission(BMP085_ADDRESS);
  126.   Wire.write(address);
  127.   Wire.endTransmission();
  128.   Wire.requestFrom(BMP085_ADDRESS, 2);
  129.   while(Wire.available()<2)
  130.     ;
  131.   msb = Wire.read();
  132.   lsb = Wire.read();
  133.   return (int) msb<<8 | lsb;
  134. }
  135. // Read the uncompensated temperature value
  136. unsigned int bmp085ReadUT(){
  137.   unsigned int ut;
  138.   // Write 0x2E into Register 0xF4
  139.   // This requests a temperature reading
  140.   Wire.beginTransmission(BMP085_ADDRESS);
  141.   Wire.write(0xF4);
  142.   Wire.write(0x2E);
  143.   Wire.endTransmission();
  144.   // Wait at least 4.5ms
  145.   delay(5);
  146.   // Read two bytes from registers 0xF6 and 0xF7
  147.   ut = bmp085ReadInt(0xF6);
  148.   return ut;
  149. }
  150. // Read the uncompensated pressure value
  151. unsigned long bmp085ReadUP(){
  152.   unsigned char msb, lsb, xlsb;
  153.   unsigned long up = 0;
  154.   // Write 0x34+(OSS<<6) into register 0xF4
  155.   // Request a pressure reading w/ oversampling setting
  156.   Wire.beginTransmission(BMP085_ADDRESS);
  157.   Wire.write(0xF4);
  158.   Wire.write(0x34 + (OSS<<6));
  159.   Wire.endTransmission();
  160.   // Wait for conversion, delay time dependent on OSS
  161.   delay(2 + (3<<OSS));
  162.   // Read register 0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
  163.   msb = bmp085Read(0xF6);
  164.   lsb = bmp085Read(0xF7);
  165.   xlsb = bmp085Read(0xF8);
  166.   up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8-OSS);
  167.   return up;
  168. }
  169. void writeRegister(int deviceAddress, byte address, byte val) {
  170.   Wire.beginTransmission(deviceAddress); // start transmission to device
  171.   Wire.write(address);       // send register address
  172.   Wire.write(val);         // send value to write
  173.   Wire.endTransmission();     // end transmission
  174. }
  175. int readRegister(int deviceAddress, byte address){
  176.   int v;
  177.   Wire.beginTransmission(deviceAddress);
  178.   Wire.write(address); // register to read
  179.   Wire.endTransmission();
  180.   Wire.requestFrom(deviceAddress, 1); // read a byte
  181.   while(!Wire.available()) {
  182.     // waiting
  183.   }
  184.   v = Wire.read();
  185.   return v;
  186. }
  187. float calcAltitude(float pressure){
  188.   float A = pressure/101325;
  189.   float B = 1/5.25588;
  190.   float C = pow(A,B);
  191.   C = 1 - C;
  192.   C = C /0.0000225577;
  193.   return C;
  194. }
51單片機源碼
  1. //***************************************
  2. // BMP085 IIC測試程序
  3. // 使用單片機STC89C51
  4. // 晶振:11.0592M
  5. // 顯示:LCD1602
  6. // 編譯環境 Keil uVision2
  7. // 參考宏晶網站24c04通信程序
  8. //****************************************
  9. #include  <REG51.H>
  10. #include  <math.h>    //Keil library
  11. #include  <stdlib.h>  //Keil library
  12. #include  <stdio.h>   //Keil library
  13. #include  <INTRINS.H> //Keil library
  14. #define   uchar unsigned char
  15. #define   uint unsigned int
  16. #define   DataPort P0    //LCD1602數據端口
  17. sbit          SCL=P1^0;      //IIC時鐘引腳定義
  18. sbit           SDA=P1^1;      //IIC數據引腳定義
  19. sbit      LCM_RS=P2^0;   //LCD1602命令端口
  20. sbit      LCM_RW=P2^1;   //LCD1602命令端口
  21. sbit      LCM_EN=P2^2;   //LCD1602命令端口
  22. #define        BMP085_SlaveAddress   0xee          //定義器件在IIC總線中的從地址
  23. #define OSS 0        // Oversampling Setting (note: code is not set up to use other OSS values)
  24.
  25. typedef unsigned char  BYTE;
  26. typedef unsigned short WORD;
  27.
  28. uchar ge,shi,bai,qian,wan,shiwan;           //顯示變量
  29. int  dis_data;                              //變量
  30. short ac1;
  31. short ac2;
  32. short ac3;
  33. unsigned short ac4;
  34. unsigned short ac5;
  35. unsigned short ac6;
  36. short b1;
  37. short b2;
  38. short mb;
  39. short mc;
  40. short md;
  41. void delay(unsigned int k);
  42. void InitLcd();                            //初始化lcd1602
  43. void WriteDataLCM(uchar dataW);
  44. void WriteCommandLCM(uchar CMD,uchar Attribc);
  45. void DisplayOneChar(uchar X,uchar Y,uchar DData);
  46. void conversion(long temp_data);
  47. void  Single_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data);   //單個寫入數據
  48. uchar Single_Read(uchar REG_Address);                                      //單個讀取內部寄存器數據
  49. void  Multiple_Read(uchar,uchar);                                          //連續的讀取內部寄存器數據
  50. //------------------------------------
  51. void Delay5us();
  52. void Delay5ms();
  53. void BMP085_Start();
  54. void BMP085_Stop();
  55. void BMP085_SendACK(bit ack);
  56. bit  BMP085_RecvACK();
  57. void BMP085_SendByte(BYTE dat);
  58. BYTE BMP085_RecvByte();
  59. void BMP085_ReadPage();
  60. void BMP085_WritePage();
  61. //-----------------------------------
  62. //*********************************************************
  63. void conversion(long temp_data)
  64. {
  65.
  66.     shiwan=temp_data/100000+0x30 ;
  67.     temp_data=temp_data%100000;   //取余運算
  68.     wan=temp_data/10000+0x30 ;
  69.     temp_data=temp_data%10000;   //取余運算
  70.         qian=temp_data/1000+0x30 ;
  71.     temp_data=temp_data%1000;    //取余運算
  72.     bai=temp_data/100+0x30   ;
  73.     temp_data=temp_data%100;     //取余運算
  74.     shi=temp_data/10+0x30    ;
  75.     temp_data=temp_data%10;      //取余運算
  76.     ge=temp_data+0x30;
  77. }
  78. /*******************************/
  79. void delay(unsigned int k)
  80. {
  81. unsigned int i,j;
  82. for(i=0;i<k;i++)
  83. {
  84. for(j=0;j<121;j++)
  85. {;}}
  86. }
  87. /*******************************/
  88. void WaitForEnable(void)
  89. {
  90. DataPort=0xff;
  91. LCM_RS=0;LCM_RW=1;_nop_();
  92. LCM_EN=1;_nop_();_nop_();
  93. while(DataPort&0x80);
  94. LCM_EN=0;
  95. }
  96. /*******************************/
  97. void WriteCommandLCM(uchar CMD,uchar Attribc)
  98. {
  99. if(Attribc)WaitForEnable();
  100. LCM_RS=0;LCM_RW=0;_nop_();
  101. DataPort=CMD;_nop_();
  102. LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  103. }
  104. /*******************************/
  105. void WriteDataLCM(uchar dataW)
  106. {
  107. WaitForEnable();
  108. LCM_RS=1;LCM_RW=0;_nop_();
  109. DataPort=dataW;_nop_();
  110. LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  111. }
  112. /***********************************/
  113. void InitLcd()
  114. {
  115. WriteCommandLCM(0x38,1);
  116. WriteCommandLCM(0x08,1);
  117. WriteCommandLCM(0x01,1);
  118. WriteCommandLCM(0x06,1);
  119. WriteCommandLCM(0x0c,1);
  120. }
  121. /***********************************/
  122. void DisplayOneChar(uchar X,uchar Y,uchar DData)
  123. {
  124. Y&=1;
  125. X&=15;
  126. if(Y)X|=0x40;
  127. X|=0x80;
  128. WriteCommandLCM(X,0);
  129. WriteDataLCM(DData);
  130. }
  131. /**************************************
  132. 延時5微秒(STC90C52RC@12M)
  133. 不同的工作環境,需要調整此函數,注意時鐘過快時需要修改
  134. 當改用1T的MCU時,請調整此延時函數
  135. **************************************/
  136. void Delay5us()
  137. {
  138.     _nop_();_nop_();_nop_();_nop_();
  139.     _nop_();_nop_();_nop_();_nop_();
  140.         _nop_();_nop_();_nop_();_nop_();
  141.         _nop_();_nop_();_nop_();_nop_();
  142. }
  143. /**************************************
  144. 延時5毫秒(STC90C52RC@12M)
  145. 不同的工作環境,需要調整此函數
  146. 當改用1T的MCU時,請調整此延時函數
  147. **************************************/
  148. void Delay5ms()
  149. {
  150.     WORD n = 560;
  151.     while (n--);
  152. }
  153. /**************************************
  154. 起始信號
  155. **************************************/
  156. void BMP085_Start()
  157. {
  158.     SDA = 1;                    //拉高數據線
  159.     SCL = 1;                    //拉高時鐘線
  160.     Delay5us();                 //延時
  161.     SDA = 0;                    //產生下降沿
  162.     Delay5us();                 //延時
  163.     SCL = 0;                    //拉低時鐘線
  164. }
  165. /**************************************
  166. 停止信號
  167. **************************************/
  168. void BMP085_Stop()
  169. {
  170.     SDA = 0;                    //拉低數據線
  171.     SCL = 1;                    //拉高時鐘線
  172.     Delay5us();                 //延時
  173.     SDA = 1;                    //產生上升沿
  174.     Delay5us();                 //延時
  175. }
  176. /**************************************
  177. 發送應答信號
  178. 入口參數:ack (0:ACK 1:NAK)
  179. **************************************/
  180. void BMP085_SendACK(bit ack)
  181. {
  182.     SDA = ack;                  //寫應答信號
  183.     SCL = 1;                    //拉高時鐘線
  184.     Delay5us();                 //延時
  185.     SCL = 0;                    //拉低時鐘線
  186.     Delay5us();                 //延時
  187. }
  188. /**************************************
  189. 接收應答信號
  190. **************************************/
  191. bit BMP085_RecvACK()
  192. {
  193.     SCL = 1;                    //拉高時鐘線
  194.     Delay5us();                 //延時
  195.     CY = SDA;                   //讀應答信號
  196.     SCL = 0;                    //拉低時鐘線
  197.     Delay5us();                 //延時
  198.     return CY;
  199. }
  200. /**************************************
  201. 向IIC總線發送一個字節數據
  202. **************************************/
  203. void BMP085_SendByte(BYTE dat)
  204. {
  205.     BYTE i;
  206.     for (i=0; i<8; i++)         //8位計數器
  207.     {
  208.         dat <<= 1;              //移出數據的最高位
  209.         SDA = CY;               //送數據口
  210.         SCL = 1;                //拉高時鐘線
  211.         Delay5us();             //延時
  212.         SCL = 0;                //拉低時鐘線
  213.         Delay5us();             //延時
  214.     }
  215.     BMP085_RecvACK();
  216. }
  217. /**************************************
  218. 從IIC總線接收一個字節數據
  219. **************************************/
  220. BYTE BMP085_RecvByte()
  221. {
  222.     BYTE i;
  223.     BYTE dat = 0;
  224.     SDA = 1;                    //使能內部上拉,準備讀取數據,
  225.     for (i=0; i<8; i++)         //8位計數器
  226.     {
  227.         dat <<= 1;
  228.         SCL = 1;                //拉高時鐘線
  229.         Delay5us();             //延時
  230.         dat |= SDA;             //讀數據
  231.         SCL = 0;                //拉低時鐘線
  232.         Delay5us();             //延時
  233.     }
  234.     return dat;
  235. }
  236. /*
  237. //單字節寫入BMP085內部數據*******************************
  238. void Single_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data)
  239. {
  240.     BMP085_Start();                  //起始信號
  241.     BMP085_SendByte(SlaveAddress);   //發送設備地址+寫信號
  242.     BMP085_SendByte(REG_Address);    //內部寄存器地址
  243.     BMP085_SendByte(REG_data);       //內部寄存器數據
  244.     BMP085_Stop();                   //發送停止信號
  245. }
  246. */
  247. /*
  248. //單字節讀取BMP085內部數據********************************
  249. uchar Single_Read(uchar REG_Address)
  250. {  uchar REG_data;
  251.     BMP085_Start();                          //起始信號
  252.     BMP085_SendByte(BMP085_SlaveAddress);           //發送設備地址+寫信號
  253.     BMP085_SendByte(REG_Address);            //發送存儲單元地址
  254.     BMP085_Start();                          //起始信號
  255.     BMP085_SendByte(BMP085_SlaveAddress+1);         //發送設備地址+讀信號
  256.     REG_data=BMP085_RecvByte();              //讀出寄存器數據
  257.         BMP085_SendACK(1);
  258.         BMP085_Stop();                           //停止信號
  259.     return REG_data;
  260. }
  261. */
  262. //*********************************************************
  263. //讀出BMP085內部數據,連續兩個
  264. //*********************************************************
  265. short Multiple_read(uchar ST_Address)
  266. {
  267.         uchar msb, lsb;
  268.         short _data;
  269.     BMP085_Start();                          //起始信號
  270.     BMP085_SendByte(BMP085_SlaveAddress);    //發送設備地址+寫信號
  271.     BMP085_SendByte(ST_Address);             //發送存儲單元地址
  272.     BMP085_Start();                          //起始信號
  273.     BMP085_SendByte(BMP085_SlaveAddress+1);         //發送設備地址+讀信號
  274.     msb = BMP085_RecvByte();                 //BUF[0]存儲
  275.     BMP085_SendACK(0);                       //回應ACK
  276.     lsb = BMP085_RecvByte();
  277.         BMP085_SendACK(1);                       //最后一個數據需要回NOACK
  278.     BMP085_Stop();                           //停止信號
  279.     Delay5ms();
  280.     _data = msb << 8;
  281.         _data |= lsb;
  282.         return _data;
  283. }
  284. //********************************************************************
  285. long bmp085ReadTemp(void)
  286. {
  287.     BMP085_Start();                  //起始信號
  288.     BMP085_SendByte(BMP085_SlaveAddress);   //發送設備地址+寫信號
  289.     BMP085_SendByte(0xF4);                  // write register address
  290.     BMP085_SendByte(0x2E);               // write register data for temp
  291.     BMP085_Stop();                   //發送停止信號
  292.         delay(10);        // max time is 4.5ms
  293.
  294.         return (long) Multiple_read(0xF6);
  295. }
  296. //*************************************************************
  297. long bmp085ReadPressure(void)
  298. {
  299.         long pressure = 0;
  300.     BMP085_Start();                   //起始信號
  301.     BMP085_SendByte(BMP085_SlaveAddress);   //發送設備地址+寫信號
  302.     BMP085_SendByte(0xF4);                  // write register address
  303.     BMP085_SendByte(0x34);                 // write register data for pressure
  304.     BMP085_Stop();                    //發送停止信號
  305.         delay(10);                              // max time is 4.5ms
  306.
  307.         pressure = Multiple_read(0xF6);
  308.         pressure &= 0x0000FFFF;
  309.
  310.         return pressure;
  311.         //return (long) bmp085ReadShort(0xF6);
  312. }
  313. //**************************************************************
  314. //初始化BMP085,根據需要請參考pdf進行修改**************
  315. void Init_BMP085()
  316. {
  317.         ac1 = Multiple_read(0xAA);
  318.         ac2 = Multiple_read(0xAC);
  319.         ac3 = Multiple_read(0xAE);
  320.         ac4 = Multiple_read(0xB0);
  321.         ac5 = Multiple_read(0xB2);
  322.         ac6 = Multiple_read(0xB4);
  323.         b1 =  Multiple_read(0xB6);
  324.         b2 =  Multiple_read(0xB8);
  325.         mb =  Multiple_read(0xBA);
  326.         mc =  Multiple_read(0xBC);
  327.         md =  Multiple_read(0xBE);
  328. }
  329. //***********************************************************************
  330. void bmp085Convert()
  331. {
  332.         long ut;
  333.         long up;
  334.         long x1, x2, b5, b6, x3, b3, p;
  335.         unsigned long b4, b7;
  336.         long  temperature;
  337.         long  pressure;
  338.
  339.         ut = bmp085ReadTemp();
  340.         ut = bmp085ReadTemp();           // 讀取溫度
  341.         up = bmp085ReadPressure();
  342.         up = bmp085ReadPressure();  // 讀取壓強
  343.
  344.         x1 = ((long)ut - ac6) * ac5 >> 15;
  345.         x2 = ((long) mc << 11) / (x1 + md);
  346.         b5 = x1 + x2;
  347.          temperature = (b5 + 8) >> 4;
  348.          //*************
  349.          conversion(temperature);
  350.          DisplayOneChar(4,0,'T');       //溫度顯示
  351.      DisplayOneChar(5,0,':');
  352.      DisplayOneChar(7,0,bai);
  353.      DisplayOneChar(8,0,shi);
  354.      DisplayOneChar(9,0,'.');
  355.          DisplayOneChar(10,0,ge);
  356.          DisplayOneChar(11,0,0XDF);     //溫度單位
  357.          DisplayOneChar(12,0,'C');
  358.
  359.      //*************
  360.
  361.         b6 = b5 - 4000;
  362. ……………………
  363. …………限于本文篇幅 余下代碼請從51黑下載附件…………
【批量下載】GY-68 BMP180 新款 BOSCH溫度 代替BMP085 氣壓傳感器模塊1等.zip (2.21 MB, 下載次數: 58)
ID:380510 發表于 2018-7-31 09:56 | 只看該作者
牛批啊大兄弟
ID:205015 發表于 2019-5-12 08:38 | 只看該作者
感謝分享。
