發現一個用NRF24L01撘的無線測溫系統,剛好跟畢設內容差不多,分享一個給大家接收端代碼是這樣的,想改成用BMP180模塊顯示氣壓和溫度的。
- #include <reg52.h>
- #include <intrins.h>
- typedef unsigned char uchar;
- typedef unsigned char uint;
- //****************************************NRF24L01端口定義***************************************
- sbit MISO =P1^3;
- sbit MOSI =P1^4;
- sbit SCK =P1^2;
- sbit CE =P1^1;
- sbit CSN =P3^2;
- sbit IRQ =P3^3;
- //************************************按鍵***************************************************
- sbit KEY1=P3^6;
- sbit KEY2=P3^7;
- //************************************數碼管位選*********************************************
- sbit led3=P2^0;
- sbit led2=P2^1;
- sbit led1=P2^2;
- sbit led0=P2^3;
- //************************************蜂明器***************************************************
- sbit BELL=P3^4;
- //***********************************數碼管0-9編碼*******************************************
- uchar seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9段碼
- uchar seg1[10]={0x40,0x4F,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10}; //0~~9段碼
- char temp[6];
- uchar RxBuf[20]={0};
- //*********************************************NRF24L01*************************************
- #define TX_ADR_WIDTH 5 // 5 uints TX address width
- #define RX_ADR_WIDTH 5 // 5 uints RX address width
- #define TX_PLOAD_WIDTH 20 // 20 uints TX payload
- #define RX_PLOAD_WIDTH 20 // 20 uints TX payload
- uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //本地地址
- uint const RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //接收地址
- //***************************************NRF24L01寄存器指令*******************************************************
- #define READ_REG 0x00 // 讀寄存器指令
- #define WRITE_REG 0x20 // 寫寄存器指令
- #define RD_RX_PLOAD 0x61 // 讀取接收數據指令
- #define WR_TX_PLOAD 0xA0 // 寫待發數據指令
- #define FLUSH_TX 0xE1 // 沖洗發送 FIFO指令
- #define FLUSH_RX 0xE2 // 沖洗接收 FIFO指令
- #define REUSE_TX_PL 0xE3 // 定義重復裝載數據指令
- #define NOP 0xFF // 保留
- //*************************************SPI(nRF24L01)寄存器地址****************************************************
- #define CONFIG 0x00 // 配置收發狀態,CRC校驗模式以及收發狀態響應方式
- #define EN_AA 0x01 // 自動應答功能設置
- #define EN_RXADDR 0x02 // 可用信道設置
- #define SETUP_AW 0x03 // 收發地址寬度設置
- #define SETUP_RETR 0x04 // 自動重發功能設置
- #define RF_CH 0x05 // 工作頻率設置
- #define RF_SETUP 0x06 // 發射速率、功耗功能設置
- #define STATUS 0x07 // 狀態寄存器
- #define OBSERVE_TX 0x08 // 發送監測功能
- #define CD 0x09 // 地址檢測
- #define RX_ADDR_P0 0x0A // 頻道0接收數據地址
- #define RX_ADDR_P1 0x0B // 頻道1接收數據地址
- #define RX_ADDR_P2 0x0C // 頻道2接收數據地址
- #define RX_ADDR_P3 0x0D // 頻道3接收數據地址
- #define RX_ADDR_P4 0x0E // 頻道4接收數據地址
- #define RX_ADDR_P5 0x0F // 頻道5接收數據地址
- #define TX_ADDR 0x10 // 發送地址寄存器
- #define RX_PW_P0 0x11 // 接收頻道0接收數據長度
- #define RX_PW_P1 0x12 // 接收頻道0接收數據長度
- #define RX_PW_P2 0x13 // 接收頻道0接收數據長度
- #define RX_PW_P3 0x14 // 接收頻道0接收數據長度
- #define RX_PW_P4 0x15 // 接收頻道0接收數據長度
- #define RX_PW_P5 0x16 // 接收頻道0接收數據長度
- #define FIFO_STATUS 0x17 // FIFO棧入棧出狀態寄存器設置
- void Delay(unsigned int s);
- void inerDelay_us(unsigned char n);
- void init_NRF24L01(void);
- uint SPI_RW(uint uchar);
- uchar SPI_Read(uchar reg);
- void SetRX_Mode(void);
- uint SPI_RW_Reg(uchar reg, uchar value);
- uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars);
- uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars);
- unsigned char nRF24L01_RxPacket(unsigned char* rx_buf);
- void nRF24L01_TxPacket(unsigned char * tx_buf);
- //*****************************************長延時*****************************************
- unsigned int i;
- for(i=0; i<s; i++);
- uint bdata sta; //狀態標志
- sbit RX_DR =sta^6;
- sbit TX_DS =sta^5;
- sbit MAX_RT =sta^4;
- /*延時函數
- for(;n>0;n--)
- _nop_();
- /*NRF24L01初始化
- inerDelay_us(100);
- CE=0; // chip enable
- CSN=1; // Spi disable
- SCK=0; // Spi clock line init high
- SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 寫本地地址
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 寫接收端地址
- SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 頻道0自動 ACK應答允許
- SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允許接收地址只有頻道0,如果需要多頻道,可以參考Page21
- SPI_RW_Reg(WRITE_REG + RF_CH, 0); // 設置信道工作為2.4GHZ,收發必須一致
- SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //設置接收數據長度,本次設置為32紙?
- SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //設置發射速率為1MHZ,發射功率為最大值0dB
- /*函數:uint SPI_RW(uint uchar)
- /*功能:NRF24L01的SPI寫時序
- /*詳細請參考Page19
- uint bit_ctr;
- for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit
- MOSI = (uchar & 0x80); // output 'uchar', MSB to MOSI
- uchar = (uchar << 1); // shift next bit into MSB..
- SCK = 1; // Set SCK high..
- uchar |= MISO; // capture current MISO bit
- SCK = 0; // ..then set SCK low again
- return(uchar); // return read uchar
- /*函數:uchar SPI_Read(uchar reg)
- /*功能:NRF24L01的SPI時序
- /*詳細請參考Page19
- uchar reg_val;
- CSN = 0; // CSN low, initialize SPI communication...
- SPI_RW(reg); // Select register to read from..
- reg_val = SPI_RW(0); // ..then read registervalue
- CSN = 1; // CSN high, terminate SPI communication
- return(reg_val); // return register value
- /*功能:NRF24L01讀寫寄存器函數
- uint status;
- CSN = 0; // CSN low, init SPI transaction
- status = SPI_RW(reg); // select register
- SPI_RW(value); // ..and write value to it..
- CSN = 1; // CSN high again
- return(status); // return nRF24L01 status uchar
- /*函數:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars)
- /*功能: 用于讀數據,reg:為寄存器地址,pBuf:為待讀出數據地址,uchars:讀出數據的個數
- uint status,uchar_ctr;
- CSN = 0; // Set CSN low, init SPI tranaction
- status = SPI_RW(reg); // Select register to write to and read status uchar
- for(uchar_ctr=0;uchar_ctr<uchars;uchar_ctr++)
- pBuf[uchar_ctr] = SPI_RW(0); //
- CSN = 1;
- /*函數:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars)
- /*功能: 用于寫數據:為寄存器地址,pBuf:為待寫入數據地址,uchars:寫入數據的個數
- CSN = 0; //SPI使能
- for(uchar_ctr=0; uchar_ctr<uchars; uchar_ctr++) //
- SPI_RW(*pBuf++);
- CSN = 1; //關閉SPI
- /*函數:void SetRX_Mode(void)
- /*功能:數據接收配置
- CE=0;
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收發完成中斷響應,16位CRC ,主接收
- CE = 1;
- inerDelay_us(130);
- /*函數:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf)
- /*功能:數據讀取后放如rx_buf接收緩沖區中
- unsigned char revale=0;
- sta=SPI_Read(STATUS); // 讀取狀態寄存其來判斷數據接收狀況
- if(RX_DR) // 判斷是否接收到數據
- CE = 0;
- SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
- revale =1; //讀取數據完成標志
- SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到數據后RX_DR,TX_DS,MAX_PT都置高為1,通過寫1來其清除中斷標志
- return revale;
- /*函數:void nRF24L01_TxPacket(unsigned char * tx_buf)
- /*功能:發送 tx_buf中數據
- CE=0; //StandBy I模式
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 裝載接收端地址
- SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 裝載數據
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收發完成中斷響應,16位CRC,主發送
- CE=1; //置高CE,激發數據發送
- inerDelay_us(10);
- //***********************************************串口初始化***********************************************
- void StartUART( void )
- SCON = 0x50;
- TMOD = 0x20;
- TH1 = 0xFA;
- TL1 = 0xFA; //波特率4800
- PCON = 0x00;
- TR1 = 1;
- //***********************************************通過串口向PC發送***********************************************
- void R_S_Byte(uchar R_Byte)
- SBUF = R_Byte;
- while( TI == 0 ); //查詢法
- TI = 0;
- //***********************************************數碼動態掃描顯示***********************************************
- void disdignit()
- P0=0xC6; //C
- led0=0;
- Delay(50);
- led0=1;
- P0=seg[temp[1]]; //小數位
- led1=0;
- Delay(50);
- led1=1;
- P0=seg1[temp[5]]; //十位
- led2=0;
- Delay(50);
- led2=1;
- P0=seg[temp[4]]; //個位
- led3=0;
- Delay(50);
- led3=1;
- //************************************主函數************************************************************
- void main(void)
- uchar i=0;
- init_NRF24L01() ; //NRF24L01初始化
- StartUART();
- Delay(6000);
- BELL=1;
- while(1)
- SetRX_Mode();
- if(nRF24L01_RxPacket(RxBuf))
- temp[0]=RxBuf[3]; //符號位
- temp[2]=((RxBuf[2]<<4)|RxBuf[1]); //整數位
- temp[1]=RxBuf[0]; //小數位
- temp[4]=RxBuf[2]; //十位
- temp[5]=RxBuf[1]; //個位
- disdignit(); //數碼管顯示溫度
- R_S_Byte('t'); //串口顯示溫度
- R_S_Byte(0x30+temp[4]); //串口顯示溫度
- R_S_Byte(0x30+temp[5]); //串口顯示溫度
- R_S_Byte('.'); //串口顯示溫度
- R_S_Byte(0x30+temp[1]); //串口顯示溫度
- /* for(i=0;i<3;i++)
- R_S_Byte(temp[2-i]); //串口顯示溫度
- Delay(60);
- if(temp[2]>=0x30) //大于30度時報警,0x30轉換成10進制為48
- BELL=0; //打開蜂明器
- // Delay(1);
- else
- BELL=1; //關閉蜂明器
