HT7350引腳圖:
2018-5-23 04:39 上傳
HT7350功能框圖:
2018-5-23 04:39 上傳
HT7350典型應用電路圖:
2018-5-23 04:39 上傳
HT7350封裝:
2018-5-23 04:39 上傳
2018-5-23 04:39 上傳
HT7350資料手冊:
HT7350(7350-A).pdf
(119.8 KB, 下載次數: 51)
2018-5-20 20:20 上傳
下載積分: 黑幣 -5
The HT73XX series is a set of three-terminal, low power,
high voltage regulators implemented in CMOS technol-
ogy. The series features extremely low quiescent cur-
rent which is typically 3.5A . They allow input voltages
as high as 12V. The device provides large current with a
significantly small dropout voltage.
The HT73XX consists of a high-precision voltage refer-
ence, an error correction circuit, and a current limited
output driver. They are available with several fixed out-
put voltages ranging from 1.8V to 5.0V. CMOS technol-
ogy ensures low dropout voltage and low current
consumption. Although designed primarily as fixed volt-
age regulators, these devices can be used with external
components to generate variable voltages and currents.
Ultra low quiescent current: 3.5A (typ.)
High input voltage (up to 12V)
Output voltage:
1.8V, 2.5V, 2.7V, 3.0V, 3.3V, 3.5V, 5.0V
Output voltage accuracy: tolerance 3%
Battery-powered equipment
Voltage regulator for microprocessor
Voltage regulator for LAN cards
