下面是樓主的主程序:
- #include <math.h>
- #include <stdio.h>
- #include <INTRINS.H>
- #include "reg52.h"
- #include "lcd.h"
- #include "ds18.h"
- #include "serc.h"
- #include "yl38.h"
- #include "bhmc.h"
- #ifndef uchar
- #define uchar unsigned char
- #endif
- #ifndef uint
- #define uint unsigned int
- #endif
- sbit ssm=P3^3; //測(cè)試數(shù)據(jù)發(fā)送引腳,每隔20s反一次
- sbit en=P3^2; //wifi模塊初始化引腳
- uchar as[2][21];
- uchar dssz[5]; //DS18緩存
- uchar gysz[6]; //GY30緩存
- uchar ylsz[5]; //YL38緩存
- uchar code ssd[8]={0x10,0x06,0x09,0x08,0x08,0x09,0x06,0x00};//℃
- uchar code lux[8]={0x00,0x10,0x10,0x10,0x15,0x12,0x15,0x00};//lux
- uchar timee; //時(shí)間旗子
- static uchar zt; //步進(jìn)電機(jī)旗子
- void Delay1ms(uint c) //誤差 0us
- uchar a,b;
- for (;c>0; c--)
- for (b=199;b>0;b--)
- for(a=1;a>0;a--);
- void Delay5us() //誤差 0ns
- _nop_();_nop_();_nop_();_nop_();
- void main()
- uchar j,k; //檢索
- LcdInit();
- YL38Init();
- GY30Init();
- SercInit(); //初始化串口
- ssm=0;
- DS18done(dssz); //操作DS18,數(shù)據(jù)存在dssz數(shù)組中
- YL38done(ylsz,50,70); //操作YL38,數(shù)據(jù)存在ylsz數(shù)組中,后面第一個(gè)為反饋下限,小于其則啟動(dòng)反饋P2^4,第二個(gè)為反饋上限,大于其則關(guān)閉反饋
- GY30done(gysz,25000); //操作GY30,數(shù)據(jù)存在gysz數(shù)組中,后面跟著反饋限制值,超過(guò)則啟動(dòng)反饋引腳P1^2,同時(shí)輸出‘T’
- en=0;
- DS18done(dssz);
- Delay1ms(500);
- en=1; //重新啟動(dòng)esp
- DS18done(dssz);
- DIYshow(1,ssd,8,1); //攝氏度℃
- DIYshow(2,lux,8,2); //勒克斯lux
- DisplayOneChar(1,1,'T'); //溫度
- DisplayOneChar(2,1,':');
- DisplayOneChar(10,1,'H'); //濕度
- DisplayOneChar(11,1,':');
- DisplayOneChar(16,1,'%'); //%
- DisplayOneChar(1,2,'L'); //光照
- DisplayOneChar(2,2,':');
- DisplayOneChar(10,2,'F'); //反饋
- DisplayOneChar(11,2,':');
- DisplayOneChar(12,2,'G'); //光照反饋前綴
- DisplayOneChar(14,2,'S'); //濕度反饋前置
- DisplayOneChar(3,1,dssz[0]);
- DisplayOneChar(4,1,dssz[1]);
- DisplayOneChar(5,1,dssz[2]);
- DisplayOneChar(6,1,dssz[3]);
- DisplayOneChar(7,1,dssz[4]);
- DisplayOneChar(12,1,ylsz[0]);
- DisplayOneChar(13,1,ylsz[1]);
- DisplayOneChar(14,1,ylsz[2]);
- DisplayOneChar(15,1,ylsz[3]);
- DisplayOneChar(15,2,ylsz[4]); //濕度反饋
- DisplayOneChar(3,2,gysz[0]);
- DisplayOneChar(4,2,gysz[1]);
- DisplayOneChar(5,2,gysz[2]);
- DisplayOneChar(6,2,gysz[3]);
- DisplayOneChar(7,2,gysz[4]);
- DisplayOneChar(13,2,gysz[5]); //光照反饋
- DS18done(dssz);
- GY30done(gysz,50000);
- Delay1ms(10000);
- SendString("AT+CIPMODE=1\r\n");
- Delay1ms(1000) ;
- SendString("AT+CIPSTART=\"TCP\",\"tcp.lewei50.com\",9960\r\n");
- Delay1ms(1000);
- SendString("AT+CIPSEND\r\n");
- Delay1ms(1000);
- while(1)
- DS18done(dssz);
- for(j=0;j<2;j++) //檢測(cè)是否有手動(dòng)澆水命令發(fā)來(lái)單片機(jī)端,有就判斷能否啟動(dòng)YLFB引腳
- for(k=0;k<21;k++)
- if(as[j][k]=='r'&& as[j][k-1]=='e' || as[j][k]=='e'&& as[j][k-1]=='t')
- SendString("{\"method\":\"response\",\"result\":{\"successful\":true,\"message\":\"Done\"}}&^!\r\n");
- if(ylsz[0]=='5' || ylsz[0]=='6') //檢測(cè)當(dāng)前濕度能否開(kāi)啟水泵
- YLFB=1;
- if(zt==0 && gysz[5]=='T' && ylsz[4]=='F')
- FG();
- zt=1;
- if(zt==1 && gysz[5]=='F' && ylsz[4]=='F')
- RG();
- zt=0;
- if(timee==1) //每隔20秒執(zhí)行一次
- SendString("{\"method\": \"update\",\"gatewayNo\": \"01\",\"userkey\": \"f40a5569285c418c9744d8d627a168ed\"}&^!\r\n");
- SendString("{\"method\":\"upload\",\"data\":[{\"Name\":\"t1\",\"Value\":\"");
- SendoString(dssz,5);
- SendString("\"},{\"Name\":\"x1\",\"Value\":\"");
- SendoString(gysz,5);
- SendString("\"},{\"Name\":\"h1\",\"Value\":\"");
- SendoString(ylsz,4);
- SendString("\"}]}&^!\r\n");
- timee=0;
- void timer() interrupt 1
- static uchar time;
- TH0=0X04; //50ms初值
- TL0=0X00;
- time++;
- if(time==250)
- time=0;
- timee=1;
- ssm=~ssm;
- void ser()interrupt 4 //串口中斷
- static uchar io;
- static uchar jj;
- TI=0;
- RI=0;
- as[jj][io]=SBUF;
- io++;
- if(io==21)
- io=0;
- switch(jj)
- case 0:jj=1;break;
- case 1:jj=0;break;
復(fù)制代碼 |
