查看: 4951|回復(fù): 0
單片機(jī)陣列鍵盤原理圖,匯編語言源代碼以及仿真工程
ID:333902 發(fā)表于 2018-5-20 02:14 | 顯示全部樓層 |閱讀模式
陣列鍵盤原理圖,源代碼以及proteus程序
單片機(jī)匯編語言源程序如下:
  1. ORG  0000H
  2. START:          MOV          P3,#00H
  3.                 ACALL DAY1S
  4.                 MOV          P3,#0FFH
  5.                 ACALL DAY1S
  6.                 MOV          P3,#00H
  7.                 ACALL DAY1S
  8.                 MOV          P3,#0FFH
  9.                 ACALL DAY1S
  10. TEST:
  11.                 MOV   P1,#0F0H
  12.                 MOV  A,P1
  13.                 ANL  A,#0FH
  14.                 CJNE  A, #00H,HAVE
  15.
  16.                 SJMP  TEST
  17. HAVE:
  18.                 MOV  A,#01H
  19. NEXT:
  20.                 MOV  B,A
  21.                 MOV  P1,A
  22. READ:
  23.                 MOV  A,P1
  24.                 ANL  A,#0F0H
  25.
  26.                 CJNE  A,#00H,YES
  27.                 MOV  A,B
  28.                 RL  A
  29.                 CJNE  A,#10H,NEXT
  30. YES:
  31.                 ACALL  DAY
  32. AREAD:
  33.                 MOV  A,P1
  34.                 ANL  A,#0F0H
  35.
  36.                 MOV  R2,A
  37.                 MOV  A, B
  38.                 ANL  A,#0FH
  39.                 ORL  A,R2
  40. YES1:
  41.                 MOV  B,A
  42.                 LJMP AJM
  43. AJM:
  44.                 MOV  R1,#00H
  45. AJM1:                MOV         DPTR,#BTNTAB
  46.                 MOV  A, R1
  47.                 MOVC A, @A+DPTR
  48.                 CJNE A,B,NEXTKEY
  49.                 MOV         DPTR,#LEDTAB
  50.                 MOV  A,R1
  51.                 MOVC A,@A+DPTR
  52.                 MOV  P3,A
  53.                 LJMP TEST
  54. NEXTKEY:
  55.                 INC R1
  56.                 CJNE R1,#10H,AJM1
  57.                 LJMP TEST
  58.
  59. DAY:                MOV   R6,#20
  60. DL2:                MOV R7,#7DH
  61. DL1:                NOP;
  62.                 NOP;
  63.                 DJNZ   R7,DL1
  64.                 DJNZ   R6,DL2
  65.                 RET
  66. DAY1S:                MOV  R0,#32H
  67. DAY1S1:
  68.                 ACALL DAY
  69.                 DJNZ  R0,DAY1S1
  70.                 RET
  71. BTNTAB:                DB          11H,21H,41H,81H
  72.                 DB        12H,22H,42H,82H
  73.                 DB        14H,24H,44H,84H
  74.                 DB        18H,28H,48H,88H
  75. LEDTAB:         DB          0C0H,0F9H,0A4H,0B0H,  99H, 92H, 82H,0F8H
  76.                 DB        80H, 90H, 88H, 83H, 0C6H,0A1H, 86H,8EH,0FFH
  77.                 END
陣列鍵盤完成版.zip (47.64 KB, 下載次數(shù): 14)
參與人數(shù) 1黑幣 +50 收起 理由
