查看: 4905|回復(fù): 0
Proteus中單片機(jī)89C51在LCD12864上畫曲線
Proteus中單片機(jī)89C51在LCD12864上畫曲線仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機(jī)源程序如下:
  1. /********************************** LCD12864曲線顯示*******************************************/
  2. #include<avr/io.h>
  3. #include<reg51.h>
  4. #include<drive_functions.h>
  5. #include<math.h>
  6. //#include<get_keys.h>
  7. #define Graphic_Clear 0x01   //檫除點(diǎn)
  8. #define Graphic_Not 0x02     //反相點(diǎn)
  9. #define Graphic_Draw 0x03         //畫點(diǎn)
  10. uchar j=0,i=0;
  11. uchar r=32;
  12. /***********************在LCD上任意坐標(biāo)畫點(diǎn)********************************/
  13. void DrawPoint(uchar X,uchar Y,uchar Type)
  14. {        //X,Y化點(diǎn)的坐標(biāo)Type畫點(diǎn)的類型:反相點(diǎn),檫除點(diǎn),畫點(diǎn)
  15.
  16.    uchar DX = (Y >> 3);               //計(jì)算出屬于哪個(gè)字節(jié)
  17.    uchar BX = Y - (DX << 3);           //計(jì)算出屬于字節(jié)哪一位
  18.    uchar TempData = 0;
  19.
  20.
  21.    if (X > 63)
  22.    {
  23.     chip_select=2;
  24.       X -= 64;
  25.    }
  26.    else
  27.    {
  28.       chip_select=1;
  29.    }
  30.    SetPage(DX);             //設(shè)行地址
  31.    SetColumn(X);                         //設(shè)列地址
  32.
  33.    TempData = ReadData();   //讀出所畫點(diǎn)所在字節(jié)的內(nèi)容
  34.
  35.    switch (Type)            //對(duì)該字節(jié)進(jìn)行相應(yīng)操作
  36.    {
  37.        case Graphic_Clear:
  38.                                                   TempData &= ~(1<<BX);
  39.                                                  break;
  40.       case Graphic_Not:
  41.                                                  TempData ^= (1 << BX);
  42.                                                   break;
  43.       case Graphic_Draw:
  44.                                                   TempData |= (1 << BX);
  45.                                                         break;
  46.           default:                                break;
  47.    }
  48.
  49.    SetPage(DX);            //設(shè)置行地址
  50.    SetColumn(X);                          //設(shè)置列地址
  51.    WriteData(TempData);         //把修改后的字節(jié)送回LCD,達(dá)到畫點(diǎn)目的
  52. }
  53. /********插值法畫任意兩點(diǎn)之間直線的函數(shù),函數(shù)中只用加減法,程序運(yùn)行效率很高**********/
  54. DrawLine(uchar x1,uchar y1,uchar x2,uchar y2)
  55. {                           //x1,y1起點(diǎn)坐標(biāo);x2,y2終點(diǎn)坐標(biāo);
  56.     uchar x,y;
  57.     uchar d_x,d_y;
  58.     char err=0;
  59.     uchar temp=0;
  60.     if(y2<y1){x=x1;y=y1;x1=x2;y1=y2;x2=x;y2=y;}
  61.     d_y=y2-y1;
  62.     if (d_y==0)
  63.         {
  64.         if (x1>x2) {x=x1;x1=x2;x2=x;}
  65.         for ( x=x1;x<=x2;x++ ) DrawPoint(x,y1,Graphic_Draw);
  66.         }
  67.     else
  68.         {
  69.     if(x2>=x1){temp=1;d_x=x2-x1;}else d_x=x1-x2;
  70.     x=x1;y=y1;DrawPoint(x,y,Graphic_Draw);
  71.     if(temp&&(d_y<=d_x))
  72.         while(x!=x2)
  73.             {if(err<0){x=x+1;err=err+(y2-y);}
  74.             else {x=x+1;y=y+1;err=err+(y2-y)-(x2-x);}
  75.             DrawPoint(x,y,Graphic_Draw);
  76.             }
  77.     else if(temp&&(d_y>d_x))
  78.         while(y!=y2)
  79.             {d_x=x2-x;d_y=y2-y;
  80.             if(err<0){x=x+1;y=y+1;err=err+d_y-d_x;}
  81.             else {y=y+1;err=err-d_x;}
  82.             DrawPoint(x,y,Graphic_Draw);
  83.             }
  84.     else if(!temp&&(d_y<=d_x))
  85.         while(x!=x2)
  86.             {d_x=x-x2;d_y=y2-y;
  87.             if(err<0){x=x-1;err=err+d_y;}
  88.             else {x=x-1;y=y+1;err=err+d_y-d_x;}
  89.             DrawPoint(x,y,Graphic_Draw);
  90.             }
  91.     else if(!temp &&(d_y>d_x))
  92.         while(y!=y2)
  93.             {d_x=x-x2;d_y=y2-y;
  94.             if(err<0){x=x-1;y=y+1;err=err+d_y-d_x;}
  95.             else {y=y+1;err=err-d_x;}
  96.             DrawPoint(x,y,Graphic_Draw);
  97.             }
  98.         }
  99. }
  100. /***********************************************************************/
  101. void DrawLevel(void)
  102. {
  103. for(i=0;i<127;i++){DrawPoint(i,32,Graphic_Draw);}//畫水平直線
  104. }
  105. /************************************************************************************/
  106. void DrawSineWave(void)
  107. {
  108.         uchar xn=0;
  109.         uchar yn=32;
  110.         uchar i;
  111.         uchar xi,yi;
  112. for(i=0;i<127;i++)
  113.         {
  114.                 xi=i;
  115.                 yi=(sin(i*0.1)*32)+32;
  116.                 DrawLine(xn,yn,xi,yi);      //在一系列零散的點(diǎn)上,兩點(diǎn)兩點(diǎn)之間連線,從而得到一條曲線
  117.
  118.                 xn=i;
  119.                 yn=yi;
  120.
  121.                 }
  122.                 }
  123. /*************************************************************************************/
  124. void DrawCircle(uchar x0,uchar y0,uchar r)//x0,y0為圓心坐標(biāo),r為圓半徑
  125. {
  126. uchar xn,yn,xi,yi;
  127. unsigned int j;
  128. xn=cos(0)*r+x0;
  129. yn=sin(0)*r+y0;
  130. for(j=0;j<630;j++)
  131.         {
  132.                 xi=(cos(j*0.01)*r)+x0;
  133.                 yi=(sin(j*0.01)*r)+y0;
  134.                 DrawLine(xn,yn,xi,yi);      //在一系列零散的點(diǎn)上,兩點(diǎn)兩點(diǎn)之間連線,從而得到一條曲線
  135.
  136.                 xn=xi;
  137.                 yn=yi;
  138. }
  139. }
  140. /**************************************************************************************************/
  141. void DrawRetic(uchar x0,uchar y0,uchar x1,uchar y1)//畫正方形,x0,y0為左上角坐標(biāo),x1,y1為右下角坐標(biāo)
  142. {
  143.         uchar i;
  144.         for(i=0;i<=x1-x0;i++){  DrawPoint(x0+i,y0,Graphic_Draw);  DrawPoint(x0+i,y1,Graphic_Draw);  }
  145.         for(i=0;i<=y1-y0;i++){  DrawPoint(x0,y0+i,Graphic_Draw);  DrawPoint(x1,y0+i,Graphic_Draw);  }
  146.         }
  147. /**************************************************************************************************/
  148. void DrawTrigle(uchar x1,uchar y1,uchar x2,uchar y2,uchar x3,uchar y3)//畫三角形,三個(gè)坐標(biāo)為三角形頂點(diǎn)
  149. {
  150.         DrawLine(x1,y1,x2,y2);
  151.         DrawLine(x2,y2,x3,y3);
  152.         DrawLine(x1,y1,x3,y3);
  153.
  154. }
  155. /******************************** main **********************************************************/
  156. void main(void)
  157. ……………………
  158. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
Proteus中單片機(jī)89C51在LCD12864上畫曲線.rar (62.69 KB, 下載次數(shù): 44)
