查看: 15797|回復: 1
ACS712引腳圖電路圖與pdf數據手冊下載
ID:333922 發表于 2018-5-19 22:04 | 顯示全部樓層 |閱讀模式
ACS712引腳圖:
ACS712管腳功能:
ACS712應用電路圖:
Features and Benefits
▪  Low-noise analog signal path
▪  Device bandwidth is set via the new FILTER pin
▪ 5 μs output rise time in response to step input current
▪  80 kHz bandwidth
▪  Total output error 1.5% at TA
= 25°C
▪  Small footprint, low-profile SOIC8 package
▪ 1.2 mΩ internal conductor resistance
▪ 2.1 kVRMS minimum isolation voltage from pins 1-4 to pins 5-8
▪  5.0 V, single supply operation
▪  66 to 185 mV/A output sensitivity
▪  Output voltage proportional to AC or DC currents
▪  Factory-trimmed for accuracy
▪  Extremely stable output offset voltage
▪  Nearly zero magnetic hysteresis
▪  Ratiometric output from supply voltage
完整的pdf格式文檔51黑下載地址:
ACS712 數據手冊.pdf (680.22 KB, 下載次數: 125)
ID:138533 發表于 2022-12-4 22:47 | 顯示全部樓層
資料下載了,謝謝分享。
