查看: 11375|回復: 0
7N65-F引腳圖與pdf資料手冊下載
ID:333640 發(fā)表于 2018-5-19 14:06 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
7N65-F引腳圖:
  DESCRIPTION
The UTC  7N65-F is a high voltage power MOSFET and is
designed to have better characteristics, such as fast switching time,
low gate charge, low on-state  resistance and have a high rugged
avalanche characteristics. This  power MOSFET is usually used at
high speed switching applications in switching power supplies and
adaptors.
  FEATURES
* RDS(ON) = 1.2Ω @ VGS = 10V, ID = 3.7A
* Fast switching capability
* Avalanche energy tested
* Improved dv/dt capability, high ruggedness
完整的pdf格式文檔51黑下載地址:
7N65-F.pdf (347.84 KB, 下載次數(shù): 9)
