很簡(jiǎn)單的一個(gè)單片機(jī)程序
仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載):
2018-5-17 02:24 上傳
單片機(jī)源程序如下:
- #include<reg51.h>
- #include<absacc.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define PA XBYTE[0x0000] //8255 A口地址
- #define PB XBYTE[0x0001] //8255 B口地址
- #define PC XBYTE[0x0002] //8255 C口地址
- #define PS XBYTE[0x0003] //8255 控制口地址
- sbit button1=P3^3; //K0 接外部中斷1,緊急車輛通過指示開關(guān)
- sbit button2=P1^0; //K1 支道狀態(tài)開關(guān)
- sbit button3=P1^1; //K2 主道狀態(tài)開關(guān)
- sbit button4=P3^2; //K3 接外部中斷0,調(diào)整紅綠時(shí)長(zhǎng)
- sbit button5=P0^4;
- sbit wei1=P1^4;
- sbit wei2=P1^5;
- sbit wei3=P1^6;
- sbit wei4=P1^7;
- sbit wei5=P1^2;
- sbit wei6=P1^3;
- sbit wei7=P3^0;
- sbit wei8=P3^1;
- uint num0=0,num1=0;
- uint k;
- uchar dp1,dp2,dp3,dp4;
- uchar code table[]= //共陰七段碼
- 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
- void time0_int() //計(jì)時(shí)器初始化
- TMOD =0x11; //設(shè)置定時(shí)器0位方式1
- TH0=0x3C; //定時(shí)50毫秒,初值為15536=3CB0
- TL0=0xB0;
- EA=1; //開全局中斷
- EX1=1; //開外部中斷1
- EX0=1;
- IT0=0;
- IT1=0; //中斷1為低電平觸發(fā)
- ET0=1; //開計(jì)時(shí)器0中斷
- TR0=1; //啟動(dòng)計(jì)時(shí)器0
- void delay(unsigned int z) //延時(shí)程序
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void ini() //兩路燈初始狀態(tài)
- P3=0xff;
- P1=0xff;
- P2=0xff;
- PA=0x21;
- PB=0x0C;
- void display0(uchar unit,uchar decade) //南北方向倒計(jì)時(shí)顯示
- wei1=0; //顯示低位
- P2=table[unit];
- delay(2);
- wei1=1;
- wei2=0; //高位顯示
- P2=table[decade];
- delay(2);
- wei2=1;
- wei5=0;
- P2=table[unit];
- delay(2);
- wei5=1;
- wei6=0;
- P2=table[decade];
- delay(2);
- wei6=1;
- void display1(uchar unit,uchar decade) //東西方向倒計(jì)時(shí)
- wei3=0; //顯示低位
- P2=table[unit];
- delay(10);
- wei3=1;
- wei4=0; //顯示高位
- P2=table[decade];
- delay(10);
- wei4=1;
- wei7=0;
- P2=table[unit];
- delay(10);
- wei7=1;
- wei8=0;
- P2=table[decade];
- delay(10);
- wei8=1;
- void main()
- PS=0x80; //8255控制字寫入,A B C口均為輸出,均為方式0
- time0_int();
- ini();
- while(1)
- while((button1!=0)&&(button2!=0)&&(button3!=0))
- if((button1!=0)&&(button2!=0)&&(button3!=0)) //南北方向
- if(num0>0&&num0<540)
- PA=0x0C; //綠燈亮27秒
- dp1=(27-(num0-0)/20)%10;
- dp2=(27-(num0-0)/20)/10;
- display0(dp1,dp2); //倒計(jì)時(shí)顯示
- if(num0>=540&&num0<600) //黃燈連續(xù)閃爍3秒
- PA=0x12;
- delay(200);
- PA=0x00;
- dp1=(3-(num0-540)/20)%10;
- dp2=(3-(num0-540)/20)/10;
- if(num0>=600&&num0<1200) //紅燈亮30秒
- PA=0x21;
- dp1=(30-(num0-600)/20)%10;
- dp2=(30-(num0-600)/20)/10;
- if(num0>=1200)num0=0;
- if((button1!=0)&&(button2!=0)&&(button3!=0)) //東西方向
- if(num1>0&&num1<600) //紅燈亮30秒
- PB=0x0C;
- dp3=(30-num1/20)%10;
- dp4=(30-num1/20)/10;
- display1(dp3,dp4); //倒計(jì)時(shí)顯示
- if(num1>=600&&num1<1140) //綠燈亮27秒
- PB=0x21;
- dp3=(27-(num1-600)/20)%10;
- dp4=(27-(num1-600)/20)/10;
- if(num1>=1140&&num1<1200) //黃燈連續(xù)閃3秒
- PB=0x12;
- delay(200);
- PB=0x00;
- dp3=3-(num1-1140)/20;
- dp4=0;
- if(num1>1200)num1=0;
- void time0() interrupt 1 //定時(shí)中斷響應(yīng)
- TH0=0x3C; //定時(shí)1ms初值
- TL0=0xB0;
- num0++;
- num1++;
- void thing1() interrupt 0 //某一方向放行
- display0(0,0);
- display1(0,0);
- while((button1!=0)&&(button2!=0)&&(button3==0)) //南北禁行,東西放行
- PA=0x21;
- PB=0x21;
- dp1=8;
- dp2=8;
- display0(8,8);
- display1(8,8);
- while((button1!=0)&&(button2==0)&&(button3!=0)) //南北放行,東西禁行
- PA=0x0C;
- PB=0x0C;
- dp1=8;
- dp2=8;
- display0(8,8);
- display1(8,8);
- void thing2() interrupt 2 //外部中斷器1響應(yīng)_緊急情況_兩道禁止通行
- PA=0x21;
- PB=0x0C;
- display0(8,8);
- display1(8,8);
交通燈.rar
(87.73 KB, 下載次數(shù): 37)
2018-5-16 21:33 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
