lpc1700 can通訊例程
2018-5-16 18:20 上傳
- /****************************************Copyright (c)****************************************************
- **--------------File Info---------------------------------------------------------------------------------
- ** File name: main.c
- ** Last modified Date: 2009-05-12
- ** Last Version: V1.01
- ** Descriptions: The main() function example template
- ** Created by: Chengmingji
- ** Created date: 2009-07-24
- ** Version: V1.00
- ** Descriptions: 添加用戶應用程序
- ** Modified by: Liangbaoqiong
- ** Modified date: 2009-07-27
- ** Version: V1.01
- ** Descriptions: 編寫CAN例程
- ** Rechecked by: Zhang bin1
- #include "LPC17xx.h" /* LPC17xx外設寄存器 */
- #include "LPC1700CAN.h"
- ** Function name: SysDelay
- ** Descriptions: 較為準確的軟件延時函數
- ** Input parameters: ulCount: 輸入延時值,如該值為主頻值,則延時時間為3秒
- ** output parameters: 無
- ** Returned value: 無
- __asm void SysDelay (uint32_t ulCount)
- subs r0, #1;
- bne SysDelay;
- bx lr;
- extern uint32_t SystemFrequency;
- ** Function name: main
- ** Descriptions: 測試時短接JP15,邏輯分析儀分別與COM8中CANH和CANL相接,然后打開ZLGCANTest調試軟件
- ** 設置波特率為1000kbps,啟動觀察接收情況
- ** input parameters: 無
- int main (void)
- unsigned char ucData11[]={0x11,0x22,0x33,0x44,0x55,0x66,0x77,0x88};
- SystemInit(); /* 系統初始化 */
- CAN_Init(0,BPS_10K); /* 初始化CAN1 通道 1M波特率 */
- * 寫報文信息(報文數據長度、是否標準幀、ID、發送數據所在的數組)
- while(!writedetail(8,1, 0x08888888,ucData11));
- while (1) {
- CANSend(0, 2);
- SysDelay(SystemFrequency / 6); /* 延時3/6 s = 500ms */
- End Of File
CAN.zip
(789.53 KB, 下載次數: 26)
2018-5-16 17:14 上傳
下載積分: 黑幣 -5
