查看: 1551|回復: 0
51單片機
ID:330583 發表于 2018-5-15 16:56 | 顯示全部樓層 |閱讀模式
#include <Intrins.h>
#define   DATA  P1      //1602驅動端口
//ROM操作命令
#define   READ_ROM  0x33   //讀ROM
#define  SKIP_ROM   0xCC   //跳過ROM
#define  MATCH_ROM   0x55  //匹配ROM
#define SEARCH_ROM 0xF0   //搜索ROM
#define   ALARM_SEARCH 0xEC  //告警搜索
//存儲器操作命令
#define  ANEW_MOVE 0xB8//重新調出E^2數據
#define   READ_POWER   0xB4  //讀電源
#define  TEMP_SWITCH 0x44 //啟動溫度變換
#define READ_MEMORY  0xBE //讀暫存存儲器
#define COPY_MEMORY 0x48  //復制暫存存儲器
#define WRITE_MEMORY 0x4E //寫暫存存儲器
//數據存儲結構
typedef struct tagTempData
  unsigned char  btThird; //百位數據
unsigned char  btSecond;  //十位數據
unsigned char btFirst;  //個位數據
unsigned char   btDecimal;  //小數點后一位數據
unsigned char  btNegative; //是否為負數
}TEMPDATA;
TEMPDATA m_TempData;
//引腳定義
sbit   DQ = P2^7;  //數據線端口
sbit   RS=  P2^0;
sbit  RW=  P2^1;
sbit E= P2^2;
//DS18B20序列號,通過調用GetROMSequence()函數在P1口讀出(讀8次)
const unsigned char code ROMData1[8] = {0x28, 0x33, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xD7};        //U1
const unsigned char code ROMData2[8] = {0x28, 0x30, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x8E};        //U2
const unsigned char code ROMData3[8] = {0x28, 0x31, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xB9};        //U3
const unsigned char code ROMData4[8] = {0x28, 0x32, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xE0};        //U4
const unsigned char code ROMData5[8] = {0x28, 0x34, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x52};        //U5
const unsigned char code ROMData6[8] = {0x28, 0x35, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x65};        //U6
const unsigned char code ROMData7[8] = {0x28, 0x36, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x3C};        //U7
const unsigned char code ROMData8[8] = {0x28, 0x37, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x0B};        //U8
//判斷忙指令
void Busy()
            DATA = 0xff;
            RS = 0;
            RW = 1;
               while(DATA & 0x80)
   E = 0;
                          E = 1;
                  E = 0;
//寫指令程序
void WriteCommand(unsigned char btCommand)
     Busy();
     RS = 0;
     RW = 0;
     E = 1;
     DATA = btCommand;
     E = 0;
//寫數據程序
void WriteData(unsigned char btData)
     Busy();
     RS = 1;
     RW = 0;
     E = 1;
     DATA = btData;
     E = 0;
//清屏顯示
void Clear()
WriteCommand(1);
//初始化
void Init()
WriteCommand(0x0c);//開顯示,無光標顯示
WriteCommand(0x06);//文字不動,光標自動右移
WriteCommand(0x38);//設置顯示模式:8位2行5x7點陣
//顯示單個字符
void DisplayOne(bit bRow, unsigned char btColumn, unsigned char btData, bit bIsNumber)
         if (bRow)
             WriteCommand(0xc0 + btColumn);
             WriteCommand(0x80 + btColumn);
         if (bIsNumber)
             WriteData(btData + 0x30);
             WriteData(btData);
//顯示字符串函數
void DisplayString(bit bRow, unsigned char btColumn, unsigned char *pData)
        while (*pData != '\0')
                   if (bRow) WriteCommand(0xc0 + btColumn);        //顯示在第1行
                   else            WriteCommand(0x80 + btColumn);        //顯示在第0行
                WriteData(*(pData++));                                                //要顯示的數據
                btColumn++;        //列數加一
//延時16us子函數
void Delay16us()
        unsigned char a;
        for (a = 0; a < 4; a++);
//延時60us子函數
void Delay60us()
        unsigned char a;
        for (a = 0; a < 18; a++);
//延時480us子函數
void Delay480us()
        unsigned char a;
        for (a = 0; a < 158; a++);
//延時240us子函數
void Delay240us()
        unsigned char a;
        for (a = 0; a < 78; a++);
//延時500ms子函數
void Delay500ms()
        unsigned char a, b, c;
        for (a = 0; a < 250; a++)
        for (b = 0; b < 3; b++)
        for (c = 0; c < 220; c++);
//芯片初始化
void Initialization()
                DQ = 0;
                Delay480us();
                         //延時480us
                DQ = 1;
                Delay60us();
                        //延時60us
                if(!DQ)
                                  //收到ds18b20的應答信號
                        DQ = 1;
                        Delay240us();
                //延時240us
                        break;
//寫一個字節(從低位開始寫)
void WriteByte(unsigned char btData)
        unsigned char i, btBuffer;
        for (i = 0; i < 8; i++)
                btBuffer = btData >> i;
                if (btBuffer & 1)
                        DQ = 0;
                        _nop_();
                        _nop_();
                        DQ = 1;
                        Delay60us();
                        DQ = 0;
                        Delay60us();
                        DQ = 1;
//讀一個字節(從低位開始讀)
unsigned char ReadByte()
        unsigned char i, btDest;
                btDest >>= 1;
                DQ = 0;
                _nop_();
                _nop_();
                DQ = 1;
                Delay16us();
                if (DQ) btDest |= 0x80;
                Delay60us();
        return btDest;
//序列號匹配
void MatchROM(const unsigned char *pMatchData)
        unsigned char i;
        Initialization();
        WriteByte(MATCH_ROM);
WriteByte(*(pMatchData + i));
//得到64位ROM序列(在P1口顯示,必須與Proteus聯調且在單步調試下才能得到)
/*void GetROMSequence()
        unsigned char i;
        Initialization();
        WriteByte(READ_ROM);
        P1 = ReadByte();
//讀取溫度值
TEMPDATA ReadTemperature()
        TEMPDATA TempData;
        unsigned int iTempDataH;
        unsigned char btDot, iTempDataL;
        static unsigned char i = 0;
        TempData.btNegative = 0;
                                                //為0溫度為正
        i++;
        if (i == 9) i = 1;
        Initialization();
        WriteByte(SKIP_ROM);                                                        //跳過ROM匹配
        WriteByte(TEMP_SWITCH);                                                        //啟動轉換
        Delay500ms();
        //調用一次就行
        Delay500ms();
        Initialization();
        //多個芯片的時候用MatchROM(ROMData)換掉WriteByte(SKIP_ROM)
        switch (i)
                case 1 : MatchROM(ROMData1); break;
                        //匹配1
                case 2 : MatchROM(ROMData2); break;
                        //匹配2
                case 3 : MatchROM(ROMData3); break;
                        //匹配3
                case 4 : MatchROM(ROMData4); break;
                        //匹配4
                case 5 : MatchROM(ROMData5); break;
                        //匹配5
                case 6 : MatchROM(ROMData6); break;
                        //匹配6
                case 7 : MatchROM(ROMData7); break;
                        //匹配7
                case 8 : MatchROM(ROMData8); break;
                        //匹配8
        //WriteByte(SKIP_ROM);
                                                        //跳過ROM匹配
(單個芯片時用這句換掉上面的switch)
        WriteByte(READ_MEMORY);                        //讀數據
        iTempDataL = ReadByte();
        iTempDataH = ReadByte();
        iTempDataH <<= 8;
        iTempDataH |= iTempDataL;
        if (iTempDataH & 0x8000)
                TempData.btNegative = 1;
                iTempDataH = ~iTempDataH + 1;                 //負數求補
        //為了省去浮點運算帶來的開銷,而采用整數和小數部分分開處理的方法(沒有四舍五入)
        btDot = (unsigned char)(iTempDataH & 0x000F);        //得到小數部分
        iTempDataH >>= 4;                                   //得到整數部分
        btDot *= 5;        //btDot*10/16得到轉換后的小數數據
        btDot >>= 3;
        //數據處理
        TempData.btThird   = (unsigned char)iTempDataH / 100;
        TempData.btSecond  = (unsigned char)iTempDataH % 100 / 10;
        TempData.btFirst   = (unsigned char)iTempDataH % 10;
        TempData.btDecimal = btDot;
        return TempData;
//數據處理子程序
void DataProcess()
        m_TempData = ReadTemperature();
        if (m_TempData.btNegative) DisplayOne(1, 6, '-', 0);
        else DisplayOne(1, 6, m_TempData.btThird, 1);
        DisplayOne(1, 7, m_TempData.btSecond, 1);
        DisplayOne(1, 8, m_TempData.btFirst, 1);
        DisplayOne(1, 10, m_TempData.btDecimal, 1);
        //GetROMSequence();
        Clear();
        Init();
        DisplayString(0, 0, "  Temperature");
        DisplayOne(1, 9, '.', 0);
        while (1) DataProcess();
