查看: 3467|回復: 1
溫度報警器程序代碼
ID:329734 發表于 2018-5-14 16:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit DS=P2^2;
uint temp;
uchar flag1;
sbit dula=P2^6;
sbit wela=P2^7;
sbit beep=P2^3;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,
0x87,0xff,0xef};
void delay(uint x)
  uint i;
  while(x)
    i=200;
    while(i>0)
    i--;
    x--;
void dsreset(void)  //初始化
  uint i;
  DS=0;
  i=103;
  while(i>0)i--;
  DS=1;
  i=4;
  while(i>0)i--;
bit tmpreadbit(void)   //寫一個字節
   uint i;
   bit dat;
   DS=0;
   i++;
   DS=1;
   i++;
   i++;
   dat=DS;
   i=8;
   while(i>0)
  i--;
   return(dat);
uchar tmpread(void)   //讀一個字節
  uchar i,j,dat;
  dat=0;
  for(i=1;i<=8;i++)
    j=tmpreadbit();
    dat=(j<<7)|(dat>>1);   //最低位在前
  return(dat);
void tmpwritebyte(uchar dat)   //寫一個字節到18b20
  uint i;
  uchar j;
  bit testb;
  for(j=1;j<=8;j++)
    testb=dat&0x01;
    dat=dat>>1;
    if(testb)     //寫1
      DS=0;
      i++;i++;
      DS=1;
      i=8;while(i>0)i--;
      DS=0;       //寫0
      i=8;while(i>0)i--;
      DS=1;
      i++;i++;
void tmpchange(void)
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);
  tmpwritebyte(0x44);  //單一溫度轉換
uint tmp()         //轉換溫度
float tt;
uchar a,b;
dsreset();
delay(1);
tmpwritebyte(0xcc);
tmpwritebyte(0xbe);
a=tmpread();
b=tmpread();
temp=b;
temp<<=8;
temp=temp|a;
tt=temp*0.0625;
temp=tt*10+0.5;
return temp;
void display(uint temp)
uchar A1,A2,A2t,A3;
A1=temp/100;
A2t=temp%100;
A2=A2t/10;
A3=A2t%10;
dula=0;
P0=table[A1];
dula=1;
dula=0;
wela=0;
P0=0xfe;
wela=1;
wela=0;
delay(1);
dula=0;
P0=table1[A2];
dula=1;
dula=0;
wela=0;
P0=0xfd;
wela=1;
wela=0;
delay(1);
P0=table[A3];
dula=1;
dula=0;
P0=0xfb;
wela=1;
wela=0;
delay(1);
uchar a;
do
  tmpchange();
  for(a=10;a>0;a--)
   display(tmp());
  if(temp>=230)//度數
   P1=0x00;
   beep=0;
   beep=1;
   P1=0xff;
while(1);
ID:909303 發表于 2021-6-5 18:52 來自觸屏版 | 只看該作者
有仿真圖沒
