查看: 4850|回復(fù): 7
12864字模軟件怎么用?為什么提取出來的代碼和教程中的代碼不一樣,也不能顯示
ID:322094 發(fā)表于 2018-5-12 21:52 | 顯示全部樓層 |閱讀模式
  這是字模軟件提取的,不能顯示
/*--  文字:  普  --*/
/*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
0x40,0x44,0x54,0x64,0x45,0x7E,0x44,0x44,0x44,0x7E,0x45,0x64,0x54,0x44,0x40,0x00,
0x00,0x00,0x00,0xFF,0x49,0x49,0x49,0x49,0x49,0x49,0x49,0xFF,0x00,0x00,0x00,0x00,
/*--  文字:  中  --*/
0x00,0x00,0xF0,0x10,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x10,0xF0,0x00,0x00,0x00,
0x00,0x00,0x0F,0x04,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x0F,0x00,0x00,0x00,
/*--  文字:  科  --*/
0x24,0x24,0xA4,0xFE,0xA3,0x22,0x00,0x22,0xCC,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,
0x08,0x06,0x01,0xFF,0x00,0x01,0x04,0x04,0x04,0x04,0x04,0xFF,0x02,0x02,0x02,0x00,
/*--  文字:  技  --*/
0x10,0x10,0x10,0xFF,0x10,0x90,0x08,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x08,0x00,
0x04,0x44,0x82,0x7F,0x01,0x80,0x80,0x40,0x43,0x2C,0x10,0x28,0x46,0x81,0x80,0x00,
    下面是教程中的代碼,可以顯示出
/*--  文字:  普  --*/
"普",0x00,0x40,0x44,0x54,0x64,0x45,0x7E,0x44,0x44,0x44,0x7E,0x45,0x64,0x54,0x44,0x40,
0x00,0x00,0x00,0x00,0xFF,0x49,0x49,0x49,0x49,0x49,0x49,0x49,0xFF,0x00,0x00,0x00,
/*--  文字:  中  --*/
"中",0x00,0x00,0xFC,0x08,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x08,0xFC,0x08,0x00,0x00,
0x00,0x00,0x07,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x02,0x02,0x07,0x00,0x00,0x00,
/*--  文字:  科  --*/
"科",0x00,0x00,0x00,0xFF,0x00,0x00,0xCC,0x22,0x00,0x91,0x51,0xFE,0x72,0x92,0x12,0x10,
0x00,0x01,0x01,0xFF,0x02,0x02,0x02,0x04,0x04,0x04,0x00,0xFF,0x00,0x01,0x02,0x04,
/*--  文字:  技  --*/
"技",0x00,0x08,0x48,0xC8,0x48,0x7F,0x48,0x48,0xC8,0x00,0x28,0x48,0xFF,0x88,0x08,0x08,
0x00,0x20,0x60,0x21,0x12,0x0C,0x0C,0x13,0x20,0x40,0x40,0x00,0x7F,0x80,0x41,0x01,
ID:303383 發(fā)表于 2018-5-12 23:42 | 顯示全部樓層
提示: 作者被禁止或刪除 內(nèi)容自動(dòng)屏蔽
ID:155507 發(fā)表于 2018-5-13 08:10 | 顯示全部樓層
你好:
不是不能顯示,而是取模的設(shè)置不對(duì)。
漢字取模時(shí),有C51格式和A51格式,上下顛倒、左右顛倒設(shè)置,仔細(xì)看看。
希望我的回答能幫助到你。
ID:322094 發(fā)表于 2018-5-13 12:21 | 顯示全部樓層
angmall 發(fā)表于 2018-5-13 08:10
你好:
漢字取模時(shí),有C51格式和A51格式,上下顛倒、左右顛倒設(shè)置, ...
用的c51格式,然后上下顛倒、左右顛倒都試過了,都和教程中的不一樣,也不能顯示
ID:328365 發(fā)表于 2018-7-18 18:46 | 顯示全部樓層
我和您是一樣的問題,請(qǐng)問最后您解決了嗎?是怎么解決的?
ID:96920 發(fā)表于 2019-7-1 22:36 | 顯示全部樓層
你是用什么取模工具做的
ID:579424 發(fā)表于 2019-7-7 17:10 | 顯示全部樓層
點(diǎn)陣讀取16進(jìn)制是豎著讀,取模軟件是橫著。把要寫的內(nèi)容順時(shí)針90寫就行了
ID:421308 發(fā)表于 2019-7-12 09:04 | 顯示全部樓層
網(wǎng)上有教程的,一般都是倒序,
