查看: 1850|回復(fù): 0
單片機(jī)定時(shí)計(jì)數(shù)器使用
#include <reg51.h>
uchar code num[]={
0x3f,0x06,0x5b,0x4f,0x66,
0x6d,0x7d,0x07,0x7f,0x6f};
uint t=0,x,x1,x2,x3,y;
void delay(uint a)
        uchar j;
        while(--a)
                for(j=0;j<120;j++)
void inint_0()
        TMOD=0x51;
        TH0=0x3c;
        TL0=0xb0;
        TH1=0x00;
        TL1=0x00;
        IE=0x82;
void display(uint c)
        P2=0xfe;
        P1=num[c/1000];
        delay(5);
        P2=0xfd;
        P1=num[(c/100)%10];
        delay(5);
        P2=0xfb;
        P1=num[(c/10)%10];
        delay(5);
        P2=0xf7;
        P1=num[c%10];
        delay(5);
yunsuan()
        x3=x2*256;
        x=x1+x3;
        return x;
        inint_0();
        TR0=1;
        TR1=1;
                y=yunsuan();
                display(y);
void timer0_server() interrupt 1
        TR0=0;
        TR1=0;
        TH0=0x3c;
        TL0=0xb0;
        t++;
        if(t==20)
                t=0;
                x2=TH1;
                x1=TL1;
                TH1=0x00;
                TL1=0x00;
        TR0=1;
        TR1=1;
