查看: 2589|回復: 0
16*16點陣顯示名字
ID:310170 發表于 2018-5-8 17:10 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
#define out0 P0
#define out2 P2
#define out1 P1
void delay(uint j)
        uchar i=250;
          for(;j>0;j--)
                  while(--i);
                  i=100;
uchar code string[]= {
0xFF,0xFF,0xF3,0xFF,0x73,0xC0,0x73,0xC0,0xC0,0xF3,0xC0,0xF9,0x73,0x80,0x63,0x80,
0xC1,0x95,0xD1,0x94,0x70,0x92,0x32,0x93,0x93,0x99,0xF3,0x9C,0x73,0x86,0x33,0xCF,
0xFF,0xFF,0x3F,0xFF,0x7F,0xFE,0x01,0x80,0x01,0x80,0xF9,0x9F,0x0F,0xF0,0x0F,0xF0,
0xFF,0xFF,0x01,0x80,0x01,0x80,0x7F,0xFE,0x67,0xF2,0x73,0xC6,0x19,0xCE,0x3F,0xFF,
0xFF,0xFF,0xE7,0xFF,0x27,0xC0,0x27,0xC0,0x33,0xCF,0x33,0xC0,0x31,0xC0,0xF0,0xF9,
0x12,0x80,0x13,0x80,0xF3,0xF0,0x73,0xE0,0x33,0xC9,0x93,0x99,0xD3,0xB9,0xF3,0xF9
        uchar i,j,n;
                for(j=0;j<3;j++)                        //
for(n=0;n<40;n++)                        //
                  for(i=0;i<16;i++)                 //
                out1=i%16;                        //
                out0=string[i*2+j*32];      //
                out2=string[i*2+1+j*32];
                  delay(4);
                  out0=0xff;
                  out2=0xff;
