查看: 9007|回復(fù): 5
STM32 ADC采集,DMA傳輸 DMA中斷處理
ID:324620 發(fā)表于 2018-5-7 22:13 | 顯示全部樓層 |閱讀模式
  1. //============================================
  2. //函數(shù)名稱:ADC1_Mode_Config(void)
  3. //功能描述:配置ADC1的工作模式為MDA模式
  4. //輸入:無
  5. //輸出:無
  6. //============================================
  7. void ADC1_Mode_Config(void)
  8. {
  9.         DMA_InitTypeDef DMA_InitStructure;
  10.         ADC_InitTypeDef ADC_InitStructure;
  11.
  12.         /* DMA channel1 configuration */
  13.         DMA_DeInit(DMA1_Channel1);
  14.
  15.         DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;                    //ADC地址
  16.         DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;        //內(nèi)存地址  ADC_ConvertedValue[15]一個數(shù)組
  17.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  18.         DMA_InitStructure.DMA_BufferSize = 15;
  19.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;                   //外設(shè)地址固定
  20.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                                  //內(nèi)存地址自加
  21.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;        //半字
  22.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  23.         DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;                                                   //循環(huán)傳輸
  24.         DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  25.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  26.         DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  27.
  28.         /* Enable DMA channel1 */
  29.         DMA_Cmd(DMA1_Channel1, ENABLE);
  30.         DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,ENABLE); //傳輸結(jié)束中斷
  31.
  32.         /* ADC1 configuration */
  33.         ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;                        //獨(dú)立ADC模式
  34.         ADC_InitStructure.ADC_ScanConvMode = DISABLE ;                                //禁止掃描模式,掃描模式用于多通道采集
  35.         ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;                        //開啟連續(xù)轉(zhuǎn)換模式,即不停地進(jìn)行ADC轉(zhuǎn)換
  36.         ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //不使用外部觸發(fā)轉(zhuǎn)換
  37.         ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;         //采集數(shù)據(jù)右對齊
  38.         ADC_InitStructure.ADC_NbrOfChannel = 1;                                //要轉(zhuǎn)換的通道數(shù)目1
  39.         ADC_Init(ADC1, &ADC_InitStructure);
  40.
  41.         /*配置ADC時鐘,為PCLK2的8分頻,即9MHz*/
  42.         RCC_ADCCLKConfig(RCC_PCLK2_Div8);
  43.         /*配置ADC1的通道11為55.        5個采樣周期,序列為1 */
  44.         ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);
  45.
  46.         /* Enable ADC1 DMA */
  47.         ADC_DMACmd(ADC1, ENABLE);
  48.
  49.         /* Enable ADC1 */
  50.         ADC_Cmd(ADC1, ENABLE);
  51.
  52.         /*復(fù)位校準(zhǔn)寄存器 */
  53.         ADC_ResetCalibration(ADC1);
  54.         /*等待校準(zhǔn)寄存器復(fù)位完成 */
  55.         while(ADC_GetResetCalibrationStatus(ADC1));
  56.
  57.         /* ADC校準(zhǔn) */
  58.         ADC_StartCalibration(ADC1);
  59.         /* 等待校準(zhǔn)完成*/
  60.         while(ADC_GetCalibrationStatus(ADC1));
  61.
  62.         /* 由于沒有采用外部觸發(fā),所以使用軟件觸發(fā)ADC轉(zhuǎn)換 */
  63.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  64. }
  65. //============================================
  66. //函數(shù)名稱:DMA1_Channel1_IRQHandler
  67. //功能描述:DMA中斷 對AD采集值平均濾波
  68. //輸入:無
  69. //輸出:無
  70. //============================================
  71. void DMA1_Channel1_IRQHandler(void)
  72. {
  73.         BYTE i;
  74.         WORD ADC_ConvertedValue_TEMP=0;
  75.
  76.         for(i=0;i<15;i++)
  77.         {
  78.                 ADC_ConvertedValue_TEMP += ADC_ConvertedValue;        }        ADC_ConvertedValue_average = ADC_ConvertedValue_TEMP/15;     //全局變量ADC_ConvertedValue_average                DMA_ClearITPendingBit(DMA1_IT_TC1);           DMA_ClearFlag(DMA1_FLAG_TC1);}
  79. //============================================//函數(shù)名稱:void GPIO_Configuration(void)//功能描述:ADC引腳配置//輸入:無//輸出:無//============================================void GPIO_Configuration(void){        GPIO_InitTypeDef GPIO_InitStructure;                                  //=======================ADC通道配置========================        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;        GPIO_Init(GPIOB, &GPIO_InitStructure);                                // PB0,輸入時不用設(shè)置速率}
  80. //============================================//函數(shù)名稱:void NVIC_Configuration(void)//功能描述:中斷配置//輸入:無//輸出:無//============================================void NVIC_Configuration(void){       NVIC_InitTypeDef NVIC_InitStructure;            /* Configure the NVIC Preemption Priority Bits */         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);                NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  81.         NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;        NVIC_Init(&NVIC_InitStructure);        }
ID:325935 發(fā)表于 2018-5-9 15:00 | 顯示全部樓層
你好  這個程序恨我的差不多  能看看完整的轉(zhuǎn)換嗎
ID:325935 發(fā)表于 2018-5-9 15:01 | 顯示全部樓層
厲害了    還有具體的 嗎
ID:275094 發(fā)表于 2018-11-15 14:16 | 顯示全部樓層
厲害了    還有具體的 嗎
ID:285416 發(fā)表于 2020-3-9 12:40 | 顯示全部樓層
也在搞這個,怎么也不進(jìn)中斷,有人幫我看看嘛,
代碼在見附件,只不過我是407的,
ADC多通道DMA傳輸實(shí)驗(yàn).7z
299.44 KB, 下載次數(shù): 23, 下載積分: 黑幣 -5
ID:159441 發(fā)表于 2020-3-10 15:22 | 顯示全部樓層
少了一句開啟端口時鐘
