查看: 1978|回復: 0
OSRAM 車用頭燈最新LED OBF系列
ID:323602 發表于 2018-5-6 17:31 | 顯示全部樓層 |閱讀模式
OSLON Black Flat S is able to meet a wide range of requirements. The SMT device is very stable, durable and can be used with standard processes. A new solder pad layout allows for high reliability and improved thermal management.The compact chips not only deliver high light output, they are also individually addressable with an ensured chip-to-chip contrast which makes this LED an ideal solution for Adaptive Driving Beam (ADB)
